Spitfire spitfire 1500 refuses to awake after 10 years
ian_h
Hi
I am trying to help my son get a spitfire 1500 running after a 10 year hibernation but it refuses to play.
When we first got it we drained all fluids and fuel, replaced fuel lines/pump, rebuilt carbs (removed waxstats for alternate type), all new ignition components (plugs,points,condenser, coil,leads) and gapped the tappets. We also checked compression (155/155/155/125 psi, although number 4 did come upot 140 after oiling the bore so may be just stuck ring. We set static timing to 10 degrees before tdc at the point the plugs open for Cyl 1. For the inital carb. set-up the jets are 2 full turns below bridge level and the slow running screw is 1.5 turns after it begins to move the butterfly
It would fire but only run roughly for a short period at high revs on the choke and immediatley die upon opening the throttle. This was exactly the same as before we did all the work.
I assumed we had an inlet manifold leak since there seemed to be plenty of fuel at the carbs (albeit a large vapour lock in the in line fuel filter) so we replaced the manifold. No change.
Having now rechecked fuel flow (good to carbs but still vapour lock in filter), timing, plug lead order and swapped back to old coil it refuses point blank to play. After cranking on the starter for ~5 secs it will fire to disengage starter but not run on. Even a healthy dose of damp start would not elicit any response. Having re checked compression we seem to be down to 60 on cycl 4 but that may be due more to a low battery and slow cranking speed. The plugs seem wet/oily now upon checking but there seems to be a weak spark when held against the engine.
Any insights/ideas greatly appreciated because I am all out of ideas.
Many thanks
Ian
Gliderman8
Ian,
You posted your question in the "Triumph Classifieds" forum.
I suggest you repost your question in the "Triumph section" and I know you will get the help you require.
Bob Claffie
There are lots of fittings in Triumph intakes. It only takes one open to make the mixture grossly lean If all the vacumn ports do not have a hose connected to each one that could be your problem.
I Spitfire Triumph Spitfire 1500 refuses to awake after 10 year hibernation Triumph 6
G Spitfire Spitfire 1500 differential whining Triumph 6
W Spitfire 1975 Spitfire 1500 shifting problems when hot Triumph 8
M Spitfire 1500 LH Door Triumph Classifieds 0
M 1976 Spitfire 1500 (RHD) Triumph Classifieds 2
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
R Spitfire Spitfire 1500 Triumph 3
A Spitfire Need help with 1980 Spitfire 1500 Triumph 5
M Wanted Twin carb manifold for 1500 Midget or spitfire Spridgets Classified 3
aseriesspares Spitfire What Gearbox are you using. Spitfire / Midget 1500 Triumph 2
T Putting a Spitfire 1500 into a 1972 Midget Spridgets 6
dklawson Spitfire Spitfire 1500 Block Decking Following Boring ??? Triumph 4
dklawson Spitfire Spitfire 1500 - Front Pulley Nut Removal? Triumph 2
F Spitfire Spitfire 1500 Mechanical Fuel Pump & Spacer Triumph 6
B Spitfire Advice on swapping to J Type OD with 1500 engine in 69 Spitfire Triumph 13
T Spitfire 1979 Triumph Spitfire 1500 Triumph 3
S Spitfire 1973 Spitfire 1500 Dashboard question about warning light Triumph 3
T Spitfire 1979 Triumph Spitfire 1500 rear wheel alignment Triumph 4
F Spitfire Spitfire 1500 Dash Lights Triumph 1
W Spitfire Spitfire 1500 Steering Column Triumph 3
dklawson Spitfire Clutch Kit Preference - 1500 Spitfire Triumph 3
Anthony_S Spitfire Spitfire 1500 for sale in my area Triumph 1
S Spitfire Is a 1973 spitfire a 1500 or a mark IV? Triumph 7
dklawson Spitfire Spitfire MkIV/1500 - Factory Front Spoiler? Triumph 3
dklawson Spitfire Spitfire MkIV/1500 Body Gaps - Bonnet to Bumper Triumph 2
F Spitfire Spitfire 1500 Door Handle Removal Triumph 1
F Spitfire SUs On a Spitfire 1500 Triumph 14
Scott_Hower Spitfire Late Spitfire 1500 CV driveshaft Triumph 3
F Spitfire Spitfire 1500 - Stromberg CD 150 Question Triumph 9
F Spitfire 1500 Spitfire Windshield Glass, Gasket and Install Triumph 12
Don_R Spitfire Spitfire MKIV/1500 parts book Triumph 2
F Spitfire Spitfire 1500 Electrical Question?????? Triumph 4
F Spitfire 77 Spitfire 1500 Questions Triumph 3
mikecyc72usa Spitfire Spitfire 1500, SU HS4 major issue Triumph 14
mikecyc72usa Spitfire First Autocross in my Spitfire 1500 Triumph 29
F Spitfire 1500 Spitfire Engine Noise Triumph 14
A Spitfire TRIUMPH SPITFIRE MKIV 1500 Triumph 2
K Spitfire 60’s spitfire body swapped onto a 1500 cassis Triumph 3
M Spitfire Spitfire 1500 OD transmission Triumph 9
A Spitfire Triumph Spitfire 1500 Triumph 8
K Spitfire Spitfire Mk IV tonneau =Spitfire 1500 tonneau? Triumph 2
dklawson Spitfire Crank Endfloat and Oil Pumps - Spitfire 1500 Triumph 9
bowiderberg Spitfire Whitworth on a Spitfire 1500? Triumph 8
This14u Spitfire 1500 Spitfire Header Recommendation Triumph 0
pjsmetana Spitfire Spitfire 1500 TC Triumph 2
frankenstang57 Spitfire Spitfire 1500 fast road cam question Triumph 4
1965_MGB Spitfire Junkyard Find, Spitfire 1500 I think Triumph 6
JodyFKerr Spitfire 1978 Spitfire 1500 Triumph 32
roofman Spitfire Anti run on valve ? spitfire 1500 Triumph 3
c5racer Fit an exhaust manifold from a 1500 Spitfire? Spridgets 2
