Spitfire Spitfire MkIV/1500 - Factory Front Spoiler?
dklawson
Our project MkIV Spitfire came with an unmounted, used, OEM front spoiler. It clearly was mounted at one time as there are extra mounting holes in it that line up with holes in our car's valence corners.
I'd like to clean up spoiler and install it. However, when lifting the spoiler up to the car body, it seems to interfere with the filler panel that goes between the valence corners. When the spoiler is installed is that filler panel removed? If the filler panel is left in place, is the spoiler supposed to push against the filler panel? Lastly, there appear to be two captive nuts molded into the back of the spoiler. If those bolt holes are used, what do they line up with?
Andrew Mace
By "filler panel," do you mean the little black plastic grille pieces in the quarter valences? They go away when the spoiler is fitted (which, as I recall, first happened around the 1974 model year, btw), as does the front valence (oh, maybe THAT'S what you meant?). If your car had the spoiler mounted at one time, it was a replacement due to collision damage or, perhaps more likely, due to personal preference.
dklawson
dklawson
Andrew Mace said:
By "filler panel," do you mean the little black plastic grille pieces in the quarter valences? <span style="font-weight: bold">They go away </span>when the spoiler is fitted (which, as I recall, first happened around the 1974 model year, btw), <span style="font-weight: bold">as does the front valence</span> (oh, maybe THAT'S what you meant?).
This is all beginning to make sense! After your post I went to Spitbits and compared your descriptions to their parts diagrams.
Our car is a '72 but a PO did a lot of conversion work on the car so it's a bit of a Frankenspit. Our car did not come with the plastic grille pieces in the quarter valences. The spoiler appears to have been attached to those panels using coarse "lag bolts". The panel you referred to as the valence is what I was asking about.
You have confirmed what I suspected, that the valence panel is not retained if the spoiler is installed.
Thanks Andy!
rikiwho123
i have a 71 spit and added a spoiler to the car and yes i had to remove the front valence to make it fit and with the spoiler in place you wouldn't be able to see the valence anyway.
dklawson Spitfire Spitfire MkIV/1500 Body Gaps - Bonnet to Bumper Triumph 2
Don_R Spitfire Spitfire MKIV/1500 parts book Triumph 2
A Spitfire TRIUMPH SPITFIRE MKIV 1500 Triumph 2
zedvictor1 Spitfire 1971 MkIV Spitfire Triumph 3
dklawson Spitfire MkIV Spitfire Convertible Top - Window Seals? Triumph 2
D Spitfire Elec wire connection for wiper - 71 Spitfire MkIV Triumph 1
dklawson Spitfire Brake Master Cylinder Quality - Spitfire MkIV Triumph 2
dklawson Spitfire Spitfire MkIV - Rear Hub Questions Triumph 4
C Wanted Spitfire 1500 diff rebuild Triumph Classifieds 0
L Spitfire New Acquisition, 1976 Spitfire Triumph 5
motzart007 Wanted In search of used seats for 1969 Triumph Spitfire MKIII Triumph Classifieds 1
B For Sale GT6/Spitfire License Plate Light Assembly Triumph Classifieds 0
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
A Spitfire Spitfire Diff Pinion Seal? Triumph 2
3798j General TR Spitfire up in the Tree Triumph 2
E Spitfire '69 Spitfire hard top Triumph 2
D For Sale 1966 Spitfire 4 MK 2 for sale, Triumph Classifieds 1
R For Sale Spitfire MKIII projects Triumph Classifieds 0
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
G Spitfire Spitfire 1500 differential whining Triumph 6
T Spitfire Spitfire MK2 Clutch Hydraulics Triumph 2
A Spitfire Spitfire Fuel pump issues Triumph 5
P Spitfire 1979 Triumph Spitfire starts then runs rough Triumph 2
Lairhead52 Wanted 78 Spitfire instrument panel lights / lenses Triumph Classifieds 3
D Spitfire 1980 California Spitfire, Help Figuring What To Do With It? Triumph 15
W Spitfire 1975 Spitfire 1500 shifting problems when hot Triumph 8
K Spitfire 1978 Spitfire possible Vapor Lock? Triumph 16
R Spitfire Turn signal wiring Spitfire Triumph 5
S Spitfire Spitfire 1296 engines Triumph 1
D Wanted WTB: Late Triumph Spitfire Top Frame Triumph Classifieds 8
C Spitfire 1967 Triumph Spitfire Triumph 2
Dnickels Spitfire Spitfire mk2 front suspension too soft Triumph 2
T For Sale One Owner 1969 Spitfire for sale Triumph Classifieds 0
Dnickels Spitfire Spitfire lighting issues Triumph 4
SteveTheBrewer Spitfire Spitfire Rebuild Update Triumph 5
Basil Spitfire 74 Spitfire Barn Find Triumph 1
I Spitfire Triumph Spitfire 1500 refuses to awake after 10 year hibernation Triumph 6
I Spitfire spitfire 1500 refuses to awake after 10 years Triumph 2
B Spitfire Mk3 seat rails Triumph Classifieds 0
M Spitfire 1500 LH Door Triumph Classifieds 0
P Spitfire Bits Triumph Classifieds 1
M 1976 Spitfire 1500 (RHD) Triumph Classifieds 2
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
FlyingCat Wanted 1980 Spitfire Rear Bumper Triumph Classifieds 2
SteveTheBrewer Spitfire Triumph Spitfire Restoration Blog Triumph 22
R Spitfire Spitfire 1500 Triumph 3
T Spitfire Spitfire lights Triumph 7
Basil Spitfire How do I adjust SU carbs on my Spitfire? Triumph 5
