COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED
baloo
COMPLETE DROP-IN: Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans $4000
This is a complete newly rebuilt 1975 engine and Spitfire OD transmission for sale, will all accessories. $4000
Will only sell as an engine/trans unit.
You must pickup – unless you have some easy way to ship. I live in the Louisville, KY, area
THIS EVEN INCLUDES ALL accessories (Alternator, High torque starter, distributor, mechanical fan, clutch, gear shift, trans solenoid, Weber DGV carb and intake manifold, stock exhaust manifold PLUS two sets of tubular headers (one is stainless and never mounted).
Ready to drop in. Here are the details:
ENGINE
1500cc engine, newly rebuilt engine, NEVER INSTALLED
• New oil pump;
• Crank trued (std main bearings; .010-over conn rod bearings);
• New pistons and rings;
• Head rebuilt with new guides and valve job;
• Oil line installed to directly feed rocker arms;
• Crankcase ventilation system installed: line goes from crankcase side (in place of mechanical fuel pump) up to air-oil separator, then pulled by intake manifold vacuum thru carb -- avoids smoke or pollution onto the street, and no pressure buildup inside crankcase.
• New Weber DGV carb and new Pierce intake and free flow air filter – never installed;
o Specially fabricated heat shield between carb and exhaust manifold;
• 2 sets of tubular headers; one stock cast exhaust manifold in VGC
• Electronic ignition;
• Oil cooler with oil thermostat.
• New Isuzu Hi-Torque starter modified to fit
• This engine was rebuilt by a local race mechanic, and was assembled the Right Way:
o All bearing and cam lobes coated with break in grease;
o Special Joe Gibbs Break-In oil pumped through oil galleys and engine rotated by hand (break in oil has high Zinc/Phosphorus content to ensure metal to metal surfaces are coated) – change this oil AFTER driving the car about 200 miles (break-in guidance varies widely, so check the internet and exp[erts);
TRANSMISSION
• 4 Speed OVERDRIVE Transmission rebuilt (from Spitfire); NEVER DRIVEN SINCE REBUILD
o Trans opened, cleaned and inspected
o New rubber sealing rings, oil seals
o New clutch and throw out bearing
o The input shaft insert on the bell housing was machined for a rubber-lip seal, replacing the scroll-type seal
o Synthetic trans fluid installed
o Overdrive solenoid tested – output shaft speed changes with solenoid activation
o Overdrive circuit rewired; Overdrive “ON” warning light to be mounted on dash;
o Special custom rear trans support fabricated with space for brake and gas lines;
The assembly is out of the car, hanging from an engine hoist, ready to lift up onto your pickup bed to haul away.
Located in the Louisville, KY, area.
Thanks for looking.
PAUL161
Sounds like a very fair price with all the work being done! (y)
mine TR2/3/3A Price drop on almost complete TR3a going to ebay Triumph 4
dwpirkeyjr Red? Bue? Purple? Yellow? Poly Bushings Complete Set For 1979 MG midget 1500 Spridgets 6
CARSINC Follow My Spriget Blog As I Complete SpyderMite Spridgets 24
ROARRR For Sale 1930-40's AUSTIN 10 SALOON! straight, good glass, no through rust, very complete Austin Healey Classifieds 0
A For Sale Supercharger setup complete for Rover V8 3.9/4.0/4.2 Other British Classifieds 3
HealeyPassion For Sale Tri-Carb Complete Set including manifolds Austin Healey Classifieds 13
9 For Sale: Thermocarb - complete setup including special manifold Austin Healey Classifieds 1
H Wanted BJ8 Jack and complete Tool Kit Austin Healey Classifieds 0
K For Sale Original Grease gun and jack....complete your TR3 collection. Triumph Classifieds 0
K For Sale TR3 SU's For rebuild...complete Triumph Classifieds 1
maxwedge5281 Removing Complete Rear End From BN6 Austin Healey 5
E For Sale Austin healy 100/4 complete engine Austin Healey Classifieds 4
Got_All_4 For Sale Triumph Austin Healy Jaguar 15"x5.5" Complete Wire Wheels Set & Hubs Triumph Classifieds 1
K TR2/3/3A Value of a Complete Motor disassembled? Triumph 8
D complete trim kits Austin Healey 12
2billydavies TR2/3/3A Timing, fuel mixture, complete headache and total misunderstanding of it all Triumph 51
E How much should i pay for a complete 100/4 engine ? Austin Healey 4
6TTR3A TR2/3/3A Complete firewall hole illustration Triumph 3
anarchy99 A place to buy sprite interior panels not in a complete set... Spridgets 2
C MGB Fairly complete 1980 MGB with O/D in Stanton, CA Pick your part MG 3
thechileman TR4/4A Alternator Conversion complete- '64 TR4 Triumph 1
steveg Front Toyota disc conversion now complete - photo essay Austin Healey 0
D 1963 BJ7, I found a complete car Austin Healey 8
aseriesspares MGB MGB / Midget Complete Hardware Sets 30% OFF MG 0
aseriesspares SPRIDGET Complete Hardware Sets 30% OFF Spridgets 0
aseriesspares LAND ROVER SERIES 3 Complete Hardware Sets 30% OFF Rover / Land Rover 0
aseriesspares Classic Mini Complete Hardware Sets 30% OFF British Motor Corp 0
aseriesspares AH Sprite Complete Hardware Sets 30% OFF Austin Healey 0
C BN6 Complete Running Gear - What's it worth? Austin Healey 18
Gerard I'm looking for a complete rear axle housing Spridgets 11
aseriesspares Triumph - Complete Hardware Sets! SPECIAL OFFER! Triumph 0
aseriesspares Spridget - Complete Hardware Set! SPECIAL OFFER! Spridgets 0
aseriesspares MG - Complete Hardware Sets! SPECIAL OFFER! MG 6
aseriesspares AH Sprite -Complete Hardware Set! SPECIAL OFFER! Austin Healey 4
Gliderman8 Winter Project complete.... Triumph 9
Tr4dude TR4/4A tr4 sell complete or part out? Triumph 6
M can't complete my brake job! Austin Healey 15
Jim_Gruber Complete Spridget Front Clip Spridgets 1
RedTR3 Alternator Conversion Complete Triumph 4
J Spitfire 90% complete 78 spitfire at recycler, good co Triumph 3
C GT6 complete GT6 for sale in PA $1000 Triumph 6
C 69 midget PERFECT dash panel...COMPLETE 100 bucks Spridgets 3
C 2 manuals for sale. 1275 complete manual and book Spridgets 3
pjsmetana Gauges - 4 & 5 of 7 complete [pics] Triumph 0
pjsmetana Gauges - 3 of 7 complete [pics] Triumph 0
pjsmetana Gauges - 2 of 7 complete [pics] Triumph 10
M Supra 5spd conversion complete Triumph 21
Tabcon TR4/4A Price of Complete TR4 Engine? Triumph 6
H Help with Complete Dashboard Removal Austin Healey 1
LastDeadLast Hardtop finally complete!! Triumph 11
