TR4/4A Alternator Conversion complete- '64 TR4
thechileman
Just finished my Alternator conversion on my TR4. I used the Moss kit. I started with positive ground. Moss directions on converting the car to Negative ground were clear and concise. The Alternator kit fit well, no mods required. Their installation, and wiring instructions were also clear and concise. (They included wiring diagrams as well, which I found helpful). Total time for entire conversion, Less than 2 hours. For those that don't want to go the "create your own kit" route, I would highly recommend the Moss kit. By the way, the alternator is a Lucas alternator, which I liked for some reason... :highly_amused:
mcmillal
Member
That's great! Would you be able to post some pictures?
RedTR3 Alternator Conversion Complete Triumph 4
K TR2/3/3A British Wiring alternator conversion kit question. Triumph 3
K TR2/3/3A TR3 with alternator conversion... red light stays on and low voltage on the voltmeter gauge? Triumph 1
R TR2/3/3A Amp Gauge-erratic reading after alternator conversion Triumph 39
PAUL161 T-Series Dynamator Alternator conversion. MG 23
S Stag Lucas 18ACR alternator conversion Triumph 5
I Bugeye generator/alternator conversion question Spridgets 7
longbridgehealey Alternator conversion and tach Austin Healey 9
BoyRacer Wiring question for alternator conversion Austin Healey 3
M TR2/3/3A Water Pump Belt After Alternator Conversion Triumph 6
G TR2/3/3A Wiring ammeter with the British Wiring alternator conversion. Triumph 13
Got_All_4 TR2/3/3A Just Discovered These Alternator Conversion Anyone Do One Triumph 15
D BT7 conversion to alternator Austin Healey 14
R TR6 Generator to alternator conversion Triumph 6
J Conversion to alternator Austin Healey 15
TR3driver TR2/3/3A Mea Culpa - TR3 Alternator conversion Triumph 1
M TR2/3/3A Ford Alternator Conversion Problems Triumph 10
roscoe BN1/BN2 Alternator Conversion Austin Healey 7
M TR2/3/3A Two black wires on control box E where do they g0 after alternator conversion? Triumph 9
D BN1 alternator conversion Austin Healey 4
mgedit TR2/3/3A Alternator Conversion TR3 Triumph 7
V alternator conversion Spridgets 10
GTP1960 TR2/3/3A Moss alternator & narrow belt conversion questions Triumph 22
J Alternator Conversion - Gutting the RB340 Regulator What must be done? Austin Healey 16
T TR2/3/3A TR3A Alternator conversion Triumph 15
richie Alternator conversion Triumph 16
J Moss / Lucas Alternator Conversion..... Spridgets 17
I generator/alternator conversion Spridgets 25
jhorton3 GM Alternator Conversion Spridgets 21
bugedd Alternator Conversion Spridgets 16
C Alternator Conversion ??'s Triumph 17
Patrick67BJ8 Alternator Conversion & Regulator Wiring Help Need Austin Healey 11
gubba Alternator conversion Question Triumph 25
hondo402000 Bosch alternator conversion Triumph 3
JKent one-wire alternator conversion Austin Healey 6
C Wedge TR8 alternator conversion Triumph 12
Jeepster Dynamo to alternator conversion Austin Healey 10
C Alternator conversion Austin Healey 1
N Festiva Alternator conversion!! Spridgets 3
J Alternator conversion for 71 Midget Spridgets 17
bigjones 1500 Alternator conversion woes Spridgets 21
T TR4/4A What narrow belt on alternator conversion TR4a? Triumph 7
RedTR3 TR2/3/3A TR3 Alternator Conversion Triumph 3
T TR4/4A How did you do your TR4 alternator conversion? Triumph 7
Starbuck Generator/alternator conversion...what's involved? MG 4
T TR4/4A TR4A alternator conversion wiring question Triumph 28
T TR2/3/3A TR3 alternator conversion Triumph 19
deadair TR2/3/3A TR3A Alternator Conversion Triumph 14
T Delco Alternator Conversion Spridgets 4
losmorob Info on Generator to Alternator conversion Spridgets 5
