TR6 Generator to alternator conversion
rjsmtech
Hi all, I'm new here so please bare with me. I'm trying to convert my 1970 tr6 from a generator to alternator. From reading some threads before signing up to this forum, I guess the way to go is a Bosch set up from a 78-80 Ford Fiesta. A couple of users said this should be a direct install including the plug connector....Is that true and if so, how can that be? I have absolutely zero information on this, outside of reading some stuff on the web. Some people are saying there is some wiring changes that has to be done?... Your help is greatly appreciated :smile:
M_Pied_Lourd
Are you sure that you have a generator? For a 70 TR6, it should have an alternator already installed.
Cheers
Tush
poolboy
Right.
None of the TR6's had generators. What is happening that causes you to think what you have has gone bad and needs replacement ?
However if you do want an alternator that can produce a few more amps than the original Lucas alternator, the Bosch for a 78 to 80 Ford Fiesta with A/C and rear window defrost should be pretty much a 'plug and play'...you may have to use a metric bolt on the adjustment and about a 3/4 inch longer fan belt so you can have better access to the #1 spark plug....but other than that it's 'plug and play'
dklawson
If you opt for the Bosch/Fiesta conversion, make sure the one you purchase comes with the fan and pulley. Rebuilt models often do not include those items. The Bosch is metric, the parts off your old Lucas alternator will not fit.
There are a lot of other possible conversions. Each involves one tweak or another. For years many people used the Delco 10SI or 12SI. Those are rather dated now. For a while people were using the Saturn alternator conversion. Those are also getting "old" so something newer from Denso may be preferred now.
Regardless, don't let the plug-and-play functionality be your only deciding factor. It is easy to remove the wires from the stock alternator plug so they can be used with an aftermarket alternator that uses different connectors.
Read more about the Fiesta and Saturn conversions in the link below.
https://www.britishcarforum.com/bobmuenchausen/17901.html
R
rjsmtech
Sorry for the slow response guys, been working my tail feathers off. Ok, here's my problem, red ign. light on tach gauge is on. I was told that is the generator light in this car. The battery goes dead slowly, so I was trying to put 2 and 2 together. This does have an external regulator which is why I thought it was a generator. There is an AMP gauge as well that stays towards the negative side all the time. Again, sorry for sounding like an idiot but this is my first Triumph and literally know nothing about them. I have running issues as well but will save that for another time. You guys are great with your response times, I'll try and keep up with the same courtesy. Thanks again guys!!!
Tybalt
Digging back into the far recesses of my memory, I seem to recall that the TR250 and the earliest TR6s used the 15AC alternator which did have an external regulator. By 1970, the change over should have been well past completion to the 15ACR which featured the internal regulator. Officially, by somewhere in the 1972 time frame, the spares supplied for the 15AC were to use the 15ACR and punt the external regulator. By the same token, spare parts supply could get rather spotty in that early and mid seventies time frame. I recall many a TR250 and TR6 just sitting because you couldn't buy a TR6 brake master kit or cylinder due to a backorder issue. Dealers and outside shops were known to use whatever acceptable alternates out of their inventory or that they could get their hands on, then play mix and match to keep customer's cars on the road. It would not surprise me if a 15 ACR was replaced with a 15AC and the 4TR series (37588) external voltage regulator at some point if that was what it took to get the car on the road and they could their hands on it. After all, when MGB clutch master cylinder kits went on what seemed like terminal backorder in 1973, shops were using 1967 back MGB brake master cylinder kits and just tossing the extra bits until those kits too went on what seemed to be terminal backorder. Then it was on to using clutch master cylinders until they went on .... yea, you guessed it.
Having grown up around these, it just amazes me how much better and more consistent the parts supply is forty plus years after the fact plus given the time value of money, relatively speaking the parts don't seem to cost as much either.
P Generator to alternator conversion Austin Healey 3
I Bugeye generator/alternator conversion question Spridgets 7
I generator/alternator conversion Spridgets 25
Starbuck Generator/alternator conversion...what's involved? MG 4
losmorob Info on Generator to Alternator conversion Spridgets 5
6 generator-alternator conversion Spridgets 2
B 100-4 generator to alternator conversion? Austin Healey 6
R MGA Generator to Alternator Conversion MGA MG 7
VelodromeRacer Generator to alternator conversion Austin Healey 4
dklawson Alternator Conversion - Generator Control Box? Triumph 4
G TR4/4A TR4A generator to alternator conversion Triumph 2
P Generator to Alternator Swap Austin Healey 2
W Generator or Alternator? Austin Healey 18
DrEntropy MGB Generator to alternator swap MG 1
M TR2/3/3A Generator Warning Light on with the Alternator Charging the Battery Triumph 4
K TR2/3/3A Can anyone confirm that if you replace the ammeter with a voltmeter ( generator removed and alternator added) that you...... Triumph 5
K TR2/3/3A Red ignition light stays on...car has alternator not generator. Triumph 17
AUSMHLY Generator to Alternator Swap Austin Healey 20
Merlin63Tr4 TR4/4A Alternator or alternator in a generator case? Triumph 4
R TR2/3/3A generator to alternator Triumph 5
G TR4/4A New Generator vs Alternator vs BPNW Alternator/Generator Triumph 13
D TR4/4A two questions- converting generator to alternator and breather cap query Triumph 17
tinman58 generator to alternator Triumph 8
RedTR3 Generator or Alternator? Triumph 8
HerronScott Alternator in generator case project? Triumph 2
jlaird alternator in your generator Spridgets 10
Z MGB MGB1964 what i have?Dynamo,alternator,generator. MG 8
T TR2/3/3A Rebuild generator or go w/ alternator for TR3a Triumph 24
M Generator to Alternator MG 20
19_again alternator vs generator MG 11
Dave Richards Alternator that looks like a generator Austin Healey 20
T Upgrade from Generator to Alternator - thoughts? Triumph 5
KVH TR4/4A TR4 Alternator/Generator Triumph 19
Y Positive Vs Negative ground + Alternator Vs Generator Austin Healey 1
MGTF1250Dave T-Series Lucas Generator MG 1
T Spitfire MK2 Generator Triumph 3
W Generator and Starter Long Bolts Spridgets 0
B Generator Parts Austin Healey 6
P BN4 Generator Woes Austin Healey 7
TR3MT TR2/3/3A Generator Output Triumph 18
Dnickels Spitfire Generator fan rubbing/scraping Triumph 3
AUSMHLY Lucas Generator C42 End Caps Austin Healey 3
vette Need BugEye Generator Austin Healey 7
vette Need BugEye Generator Spridgets 4
S For Sale Early Sprite & Midget Speedometer/Tachometer/Generator etc. Spridgets Classified 2
J Wanted WTB TR 3-4 Generator pedestal Triumph Classifieds 3
S TR2/3/3A Generator Pulley Bolt Removal Triumph 12
O Generator Question Austin Healey 2
TAS525 TR2/3/3A Brand New Generator Low Voltage Triumph 25
K What to do for coil bracket on upgraded generator? Austin Healey 8
