Dynamo to alternator conversion
Jeepster
I am having trouble getting my BJ8 to charge. I now have the dynamo generating but still no charge to the battery. I have cleaned up the contacts on the regulator but no luck. The ignition light does go off after a few seconds of start up.
I did consider buying a new regulator but would still have to set it up.
What is required to do an alternator conversion? CAn I only do this if the car is converted to negative earth?
Keoke
Google" Generator to alternator conversion.
Select the first entry that appears on the page.
-----------------------------OR
Google MGAgaru.com
No there are a limited number of POS earth alternators available for you to use.
Coastalman
Check out Hendrix Wire Wheels web site. Allen has a great kit with everything but the alternator. I went through the same pain of trying to make my generator and regulator work. I put the kit on my BJ8 and think it is one of the best things I have done to my Healey for reliability.
I did take the guts out of my regulator, which is one of the options for grounding, and it is the common point for several wires. It just sits there looking correct, but is connected to the alternator.
Yes, my car is negative ground now.
Charlie
dcarlg
I was in your situation recently and decided to install an alternator due to the additional electrical demands of a radio, radiator cooling fan, cold air vent fan and future placement of driving / fog lamps. Since I chose to not place Chevy parts on my Healey I purchased the alternator coversion kit from AH Spares in the UK. So far so good.
Car was already negative ground.
IanIrving
I'd suggest you change to negative earth at the same time. It is an easy job and you will find that negative earth alternators are much more easily available and alot less expensive. Another advantage is anything you fit later, GPS, Radio, CD etc is straight off the shelf. Google conversion to negative earth, the only thing I had to change on my BJ8 was to swop two wires in the rev counter and reverse the coil wire on the back of it. The whole job took a lot less than an hour.
Ian
BipBip
I make that change last year. It's very important also to buy the ALTERNATOR MOUNTING BRACKET specifique, i bought it in AH spares - not forget to buy also the joint, I did - so the original mounting can be broken so it doens't work equal and the consequences can be dramatiques....
Johnny
Did you do the test for the dynamo in the shop manual?
RAC68
Hi Jeepster
Wiring an alternator into a BJ8 is relatively easy but is dependant upon your selection of alternator for mount or hook-up. As I am not completely aware of the most common alternators available in the UK, I would suggest you consider a 2 or 3 wire units with output in the range of 50 amps to 100 amps as this will provide more than enough power for anything you have installed or plan for the future.
https://docs.google.com/viewer?a=v&p...cy&hl=en_US
The link above will take you to an article I wrote for our club news letter. It describes the easy assembly of a very low cost (relative to those available on the market) mount utilizing the original generator mounting plate along with the wiring hook-up. Let me know if you have any questions.
Ray
RAC68 (64BJ8P1)
Walter74 Dynamo to alternator Austin Healey 2
Z MGB MGB1964 what i have?Dynamo,alternator,generator. MG 8
woolfman C39 vs C40 Dynamo rebuild/parts Spridgets 0
S Wanted Wanted - C39 Dynamo [22258D] Triumph Classifieds 1
M Dynamo to "Dynamator" Conversion Austin Healey 2
F Dynamo not charging [BT7] - replace brushes or buy new? Austin Healey 24
T Which Lucas dynamo does a BJ7 have? A C45?? Austin Healey 6
SASSAMON TR2/3/3A WTB Pulley and Fan for TRactor Dynamo Triumph 3
J Dynamo and Stereo Other British Cars 1
F Generator/dynamo bushing replacement Spridgets 2
R TR2/3/3A C40 dynamo terminal identification Triumph 4
angelfj1 C39 Lucas Dynamo rebuild - Moss armature does not fit Triumph 9
O Dynamo with a mind of its own ! Austin Healey 8
angelfj1 TR2/3/3A TR3A - Dynamo Fan is loose! Triumph 3
ArcticOne GT6 WANTED - LUCAS C40L DYNAMO / GENERATOR [1968 GT6] Triumph 4
P Generator/Dynamo Problems MG 3
Geo Hahn TR2/3/3A TR3/4 Dynamo Bolt Triumph 10
6TTR3A Dynamo numbers Triumph 7
J Burning Dynamo Austin Healey 2
MGTF1250Dave Lucas 12V Dynamo / Generator Specifications Triumph 2
Indnrdr Did I cook the control box and the dynamo? Austin Healey 2
K TR2/3/3A TR3..Red light On...Dynamo Connector Triumph 5
tj_tr3_tr6 TR2/3/3A 59 TR3A dynamo problem Triumph 12
pan Generator [Dynamo] bearings Austin Healey 3
D Dynamo - distance between mounting faces Austin Healey 5
C austin seven dynamo brushes Other British Cars 7
A BJ8 / C42 dynamo bearing specification Austin Healey 3
T TR6 Alternator wiring Triumph 6
I MGB Alternator help MG 0
P Alternator Installation Pic Austin Healey 4
P Generator to Alternator Swap Austin Healey 2
W Generator or Alternator? Austin Healey 18
Writer2022 GT6 GT6 MK3 Alternator Problem Triumph 4
K TR2/3/3A Is it time for a new alternator??? Triumph 8
M Smog pump and alternator brackets Spridgets 0
V MGB Never occurred to me that my '66 would be positive ground. Does the presence of an alternator show that it's been converted? MG 22
A General MG 78 MG MIDGET ALTERNATOR SMOKES MG 5
E MGB external alternator regulator MG 2
DrEntropy MGB Generator to alternator swap MG 1
M TR2/3/3A Generator Warning Light on with the Alternator Charging the Battery Triumph 4
K TR2/3/3A Overtightening the alternator belt? Triumph 14
B TR6 Swapped Lucas to GM alternator Triumph 9
M TR6 Alternator Issue for 72 TR6 Triumph 7
K TR2/3/3A Can anyone confirm that if you replace the ammeter with a voltmeter ( generator removed and alternator added) that you...... Triumph 5
K TR2/3/3A British Wiring alternator conversion kit question. Triumph 3
K TR2/3/3A Red ignition light stays on...car has alternator not generator. Triumph 17
K TR2/3/3A TR3 with alternator conversion... red light stays on and low voltage on the voltmeter gauge? Triumph 1
G Spitfire Alternator troubles Triumph 2
jehuie Help...replaced my alternator and now my water pump is leaking. Spridgets 16
TheRealDestrux MGB Unknown connector on alternator MG 6
