General MG 78 MG MIDGET ALTERNATOR SMOKES
ARRIS
Regrettably, I made a rookie mistake the other day installing a new battery in the 78 MG Midget. I installed the battery the wrong way and u know the rest. When I connected the POS to the NEG battery post, the rear of the Alt began to smoke from the rear immediately. I recognized the mistake and immediately removed the POS. I reversed the battery and connected it properly, but when I connected the POS CLAMP to the POS BATTERY POST the ALT began to smoke from the front. My gut tells me the ALT is FUBAR. Is there anything I can do or test before ordering a new one? Thank you in advance.
Darcy
Platinum
Your gut is likely correct.
Sorry too hear of the bad luck, but welcome to the forum!
JPSmit
I expect you are correct. There is likely an auto electric place in Medicine Hat that could likely rebuild it. On the other hand, this might be a splendid time to switch to an upgraded alternator. I have a delco in min and it works great. The only downside is that it is a little on the large side. Denso alternators are smaller and there are those who are using them off thing like John Deere Gators.
mezy
100% chance you have melted the diode pack / bridge rectifier, they dont like being reverse connected,
A
ARRIS
A new ALT it is. Ty for your reply.
AngliaGT Early '74 Midget Water Pump Bolts/Alternator Bracket? Spridgets 1
J Alternator conversion for 71 Midget Spridgets 17
tweety Midget Mystery.... terminals on alternator Spridgets 0
bcliff 74 Midget alternator light question Spridgets 10
mylillooker midget Alternator pic Spridgets 17
G My Midget Alternator is reading 12.5 volts. INOP? Spridgets 2
R MG Midget beginner (1978) Spridgets 1
D Trying to get back working on the 1974 Midget Spridgets 11
C For Sale Selling MG Midget MG Classifieds 2
L Little1's 75 Midget 1500 Thread Spridgets 14
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
K 68 midget. No horn, headlights, turn signals Spridgets 9
TunaJ Will MGB Upper Seat Runners work with Midget seat rails? Spridgets 1
K 1968 Midget Steering wheel Spridgets 1
K General MG 1968 Midget Questions MG 1
dwpirkeyjr Red? Bue? Purple? Yellow? Poly Bushings Complete Set For 1979 MG midget 1500 Spridgets 6
M 1500 Midget water pump weep hole Spridgets 2
M 1977 MG Midget 1500 Problem Spridgets 8
M Midget steering column Spridgets 3
B General MG 77 MIDGET Gas tank sending unit MG 1
shadowfever Midget seat nuts and bolts Spridgets 2
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
shadowfever Moss Motors MG Midget seat covers Spridgets 6
B 1977 Midget - Sandglow Paint Restoration & Tools 3
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
T MG Midget 1500 crank shaft pulley Spridgets 0
B For Sale '69 Midget MG Classifieds 0
M Wanted Midget 1500 exhaust manifold MG Classifieds 0
D I have doubled the value of my MG Midget. Spridgets 2
fordmstr 73 Midget rocker panel end caps and door handle gaskets advise Spridgets 3
A 78 MIDGET BUMPERLESS Spridgets 4
A 78 MG MIDGET EMMISIONS REMOVAL Spridgets 1
A 1978 MIDGET 1500cc engine oil leak Spridgets 4
D MG Midget 1275 rear oil seal. Spridgets 0
D Engine Colour for a 74 Midget. Spridgets 8
B 1977 Midget Bra Spridgets 9
B Midget Differential Capacity Spridgets 5
B For Sale Replacement Panels BE/Midget Spridgets Classified 0
G Best fuel option for a 72 Midget Spridgets 5
AngliaGT Need Ideas on Selling Our Midget Spridgets 10
NutmegCT General MG MG Midget on Route 66 MG 3
D Back on the Midget after a vacation and work break. Spridgets 48
AngliaGT RB Midget - Finally tracked it Down! Spotted 3
AngliaGT For Sale MGB /Midget Wooden Shift Knob MG Classifieds 0
J Midget front shocks Spridgets 4
johntennyson Anyone Know These Guys? Or Remember Sprite-Midget Owners' Group? Spridgets 29
B General MG 1275 Midget CamShaft Slot / Star drive to Oil Pump MG 2
M MG Midget decoding Spridgets 1
JPSmit 60 years - Mg Midget Spridgets 0
M 1972 Midget Seat Belt Replacement Spridgets 4
