68 midget. No horn, headlights, turn signals
K
kbrown1752
The running lights and tail lights work. Dash lights work. No wipers, headlights, signals, or horn. My guess is to replace the signal cluster but is there anything I should check before I replace these?
Bayless
Funny thing, each of those you mentioned not working are all on separate circuits. I think you 68 is essentially the same configuration as my 67 anyway and that is how it works. Is this a sudden change or are you restoring one that you don't know the history? Do you have a decent wiring diagram?
JPSmit
always check the grounds first - black wires
K
kbrown1752
The Car is new to me. Just started tinkering with it. All the things not working have the steering column switches in common. the 4 fuses are good. That's why I was thinking that the switches are the culprit.
bobhustead
Bayless' point is that 4 switches, or 4 electrical devices or the separate power supplies to them almost couldn't have failed at the same time. Thus a ground is likely the culprit. Crank into the mix that the horn switch completes the ground (horn devices always hot), and you have a probable ground issue. Make sure all grounds are clean and tight, including body. The body, engine, and frame are all connected together by substantial cables and one or another of them is connected to the ground side of the battery.
Bob
K
kbrown1752
Bob
Thank you sir.
Bayless
All the comments about "check the grounds" are spot on, especially for these cars. The headlight switch is fed directly from the voltage regulator by a brown/blue wire and is not fused, at least from the factory. In first position it feeds the side (parking) lights, tail lights and panel lights, all of which seem to be working. In second position it also feeds the headlights through the dimmer switch. The ground for that is on the right side inner fender, again on my '67. The ground for the wipers should be a black wire at the wiper switch. I'm pretty sure this is true even if you have 2 speed wipers. The horn is a purple wire from the fuse box to the horn then a purple/black wire back to the horn button. There is a contact ring inside the cover that connects to the turn signal switch and from there is a black wire that goes to ground for the horn and turn indicators. There probably is a ground wire at the turn signal flasher too. Hope this helps.
K
kbrown1752
Bob
That will be the first place I start. Thanks guys.
K
kbrown1752
As soon as I get back Home I will look into this. Thanks Bayless.
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
Joe Reed General MG Early Midget horn push on Personal wood rim steering wheel... MG 3
C Wiring new Mota Lita horn push into my MG Midget Spridgets 6
B Looking for 64-67 midget horn button parts MG 0
R MG Midget beginner (1978) Spridgets 1
D Trying to get back working on the 1974 Midget Spridgets 11
C For Sale Selling MG Midget MG Classifieds 2
L Little1's 75 Midget 1500 Thread Spridgets 14
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
TunaJ Will MGB Upper Seat Runners work with Midget seat rails? Spridgets 1
K 1968 Midget Steering wheel Spridgets 1
K General MG 1968 Midget Questions MG 1
dwpirkeyjr Red? Bue? Purple? Yellow? Poly Bushings Complete Set For 1979 MG midget 1500 Spridgets 6
M 1500 Midget water pump weep hole Spridgets 2
M 1977 MG Midget 1500 Problem Spridgets 8
M Midget steering column Spridgets 3
B General MG 77 MIDGET Gas tank sending unit MG 1
shadowfever Midget seat nuts and bolts Spridgets 2
shadowfever Moss Motors MG Midget seat covers Spridgets 6
B 1977 Midget - Sandglow Paint Restoration & Tools 3
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
T MG Midget 1500 crank shaft pulley Spridgets 0
B For Sale '69 Midget MG Classifieds 0
M Wanted Midget 1500 exhaust manifold MG Classifieds 0
D I have doubled the value of my MG Midget. Spridgets 2
fordmstr 73 Midget rocker panel end caps and door handle gaskets advise Spridgets 3
A 78 MIDGET BUMPERLESS Spridgets 4
A 78 MG MIDGET EMMISIONS REMOVAL Spridgets 1
A 1978 MIDGET 1500cc engine oil leak Spridgets 4
A General MG 78 MG MIDGET ALTERNATOR SMOKES MG 5
D MG Midget 1275 rear oil seal. Spridgets 0
D Engine Colour for a 74 Midget. Spridgets 8
B 1977 Midget Bra Spridgets 9
B Midget Differential Capacity Spridgets 5
B For Sale Replacement Panels BE/Midget Spridgets Classified 0
G Best fuel option for a 72 Midget Spridgets 5
AngliaGT Need Ideas on Selling Our Midget Spridgets 10
NutmegCT General MG MG Midget on Route 66 MG 3
D Back on the Midget after a vacation and work break. Spridgets 48
AngliaGT RB Midget - Finally tracked it Down! Spotted 3
AngliaGT For Sale MGB /Midget Wooden Shift Knob MG Classifieds 0
J Midget front shocks Spridgets 4
johntennyson Anyone Know These Guys? Or Remember Sprite-Midget Owners' Group? Spridgets 29
B General MG 1275 Midget CamShaft Slot / Star drive to Oil Pump MG 2
M MG Midget decoding Spridgets 1
JPSmit 60 years - Mg Midget Spridgets 0
M 1972 Midget Seat Belt Replacement Spridgets 4
D MG Midget in distress. Spridgets 155
D Is it a 1965 or a 1966 MG Midget? Spridgets 2
G 79 Midget 1500 overheating Spridgets 2
