can't complete my brake job!
markclark1556
Member
The wheel cylinder housing is stamped Girling 304180 and it contains(in descending order)1)a flat bottomed piston that is covered by a rubber dust cover,2)a rubber seal that is flat on the side facing the bottom of the piston and concave on its' bottom side,3)a metal seal support with a convex top that compliments the rubber seal's concave bottom 4)a metal spring. The set up is almost like the picture on page M.1 in the "green shop manual" BUT Here's the rub - the manual is showing a front drum brake but my wheel cylinder is from a rear wheel of my '63 BJ7. The Moss Cat. (Fall-Win., 2011)pg.82 wheel cylinder repair kit (part 583-020)only works if your wheel cylinder piston has a nipple like protrusion on it's bottom. My piston has a flat bottom! I cant use the front drum brake wheel cylinder repair kit sold by Moss because my bore is 3/4" and they have 1" and 7/8". I might try the BN1 repair kit (pg.82, #513-015), it shows a rubber seal w/a concave bottom and a seal support with a convex top- I just dont know the bore size. Anybody out there ever had to deal w/this? If so, how did you get the right parts to rebuild the wheel cylinder and complete the brake job?
drambuie
My advice, Don't bother rebuilding those old brake cylinders, Just get new ones as they are not that expensive, I stopped rebuilding those things a long time ago! Just not worth it!
Keoke
:iagree:
----Keoke----------------------------- :laugh:
Healeysince59
I agree with new cylinders. It's a good idea, however, to take them apart and clean and lube them before you install them. A lot of the new ones come with machining debris.
Marv J
B
Big6Mark
Since it sounds like you have a mis-matched combination of parts, that would be the best thing to do: Replace with the correct parts and forget about the old stuff.
And the rear wheel cylinders on a 3000 should be 3/4" (100-Six used 1" cylinders.)
C Ya,
Mark
M
markclark1556
Member
I am such a cheap perfectionist so today I put them back together after a lot of cleaning and tomorrow I will start the front disk brakes. I may have to buy the new wheel cylinders next week if it doesn't want to stop. Thanks for the advice.
M
markclark1556
Member
also, wondering what is the trick to adjusting the parking brake. I cant shorten the brake cable and that seems to be what I need to do. Any suggestions?
Have you adjusted the "square" screw on each rear backplate? That's usually all that's required on the cars I've worked on.
Of ALL the assemblies on a car, brakes are the last thing you should go cheap on.
M
markclark1556
Member
Well, I located the end of the handbrake cable (it has a threaded steel 2 inch long end) where it attaches to the lever that both parking brake cross rods are attached to BUT there seems to be no way to slack. Can you tell me how this juncture is adjusted? Thanks
Sometimes called a turnbuckle--they're usually threaded on both ends--but I think the Brits call this a 'trunnion.' The 'turnbuckle/trunnion' is attached to the crossrod pivot with a clevis pin, which should be secured with a flatwasher and a cotter. Remove the cotter and the clevis pin. Then, turn the turnbuckle one way to slacken the cable, and the other to tighten (there may be a locknut on the end of the turnbuckle, can't remember for sure but if there is you'll need to loosen it). Replace the flatwasher and install a new cotter.
Adjust your drum shoes first, then take up excess slack in the cable with the turnbuckle. It's tempting to pull the cable tight--make sure the brake lever is all the way down--but leave enough slack so the brakes don't drag. The emergency brake shouldn't start to engage until 3-4 clicks on the lever; you need some slack to keep the e-brake from dragging.
JP_Furble
Marv J,
Above you said to take new cylinders apart to clean and lube them. I'm at this point in my BJ7 restoration (installing the new brake components) and was wondering what you, and others, would use to lubricate the cylinders/calipers? It will likely be several months or more before I actually charge the complete system with brake fluid and I don't want to risk the components drying out.
Thanks,
JPF
Girling (Lockheed?) markets a red rubber grease; it's the only lubricant that should come in contact with parts wetted brake fluid.
hondo402000 TR6 TR6 Third brake light Complete, new link to photos Triumph 9
dwpirkeyjr Red? Bue? Purple? Yellow? Poly Bushings Complete Set For 1979 MG midget 1500 Spridgets 6
CARSINC Follow My Spriget Blog As I Complete SpyderMite Spridgets 24
ROARRR For Sale 1930-40's AUSTIN 10 SALOON! straight, good glass, no through rust, very complete Austin Healey Classifieds 0
A For Sale Supercharger setup complete for Rover V8 3.9/4.0/4.2 Other British Classifieds 3
HealeyPassion For Sale Tri-Carb Complete Set including manifolds Austin Healey Classifieds 13
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
9 For Sale: Thermocarb - complete setup including special manifold Austin Healey Classifieds 1
H Wanted BJ8 Jack and complete Tool Kit Austin Healey Classifieds 0
K For Sale Original Grease gun and jack....complete your TR3 collection. Triumph Classifieds 0
K For Sale TR3 SU's For rebuild...complete Triumph Classifieds 1
maxwedge5281 Removing Complete Rear End From BN6 Austin Healey 5
E For Sale Austin healy 100/4 complete engine Austin Healey Classifieds 4
Got_All_4 For Sale Triumph Austin Healy Jaguar 15"x5.5" Complete Wire Wheels Set & Hubs Triumph Classifieds 1
K TR2/3/3A Value of a Complete Motor disassembled? Triumph 8
D complete trim kits Austin Healey 12
2billydavies TR2/3/3A Timing, fuel mixture, complete headache and total misunderstanding of it all Triumph 51
E How much should i pay for a complete 100/4 engine ? Austin Healey 4
6TTR3A TR2/3/3A Complete firewall hole illustration Triumph 3
anarchy99 A place to buy sprite interior panels not in a complete set... Spridgets 2
C MGB Fairly complete 1980 MGB with O/D in Stanton, CA Pick your part MG 3
thechileman TR4/4A Alternator Conversion complete- '64 TR4 Triumph 1
steveg Front Toyota disc conversion now complete - photo essay Austin Healey 0
D 1963 BJ7, I found a complete car Austin Healey 8
aseriesspares MGB MGB / Midget Complete Hardware Sets 30% OFF MG 0
aseriesspares SPRIDGET Complete Hardware Sets 30% OFF Spridgets 0
aseriesspares LAND ROVER SERIES 3 Complete Hardware Sets 30% OFF Rover / Land Rover 0
aseriesspares Classic Mini Complete Hardware Sets 30% OFF British Motor Corp 0
aseriesspares AH Sprite Complete Hardware Sets 30% OFF Austin Healey 0
C BN6 Complete Running Gear - What's it worth? Austin Healey 18
Gerard I'm looking for a complete rear axle housing Spridgets 11
aseriesspares Triumph - Complete Hardware Sets! SPECIAL OFFER! Triumph 0
aseriesspares Spridget - Complete Hardware Set! SPECIAL OFFER! Spridgets 0
aseriesspares MG - Complete Hardware Sets! SPECIAL OFFER! MG 6
aseriesspares AH Sprite -Complete Hardware Set! SPECIAL OFFER! Austin Healey 4
Gliderman8 Winter Project complete.... Triumph 9
Tr4dude TR4/4A tr4 sell complete or part out? Triumph 6
Jim_Gruber Complete Spridget Front Clip Spridgets 1
RedTR3 Alternator Conversion Complete Triumph 4
J Spitfire 90% complete 78 spitfire at recycler, good co Triumph 3
C GT6 complete GT6 for sale in PA $1000 Triumph 6
C 69 midget PERFECT dash panel...COMPLETE 100 bucks Spridgets 3
C 2 manuals for sale. 1275 complete manual and book Spridgets 3
pjsmetana Gauges - 4 & 5 of 7 complete [pics] Triumph 0
pjsmetana Gauges - 3 of 7 complete [pics] Triumph 0
pjsmetana Gauges - 2 of 7 complete [pics] Triumph 10
M Supra 5spd conversion complete Triumph 21
Tabcon TR4/4A Price of Complete TR4 Engine? Triumph 6
H Help with Complete Dashboard Removal Austin Healey 1
LastDeadLast Hardtop finally complete!! Triumph 11
