TR4/4A tr4 sell complete or part out?
Tr4dude
i need relieve myself of one project (black plated Tr4) that has sat for 28 years, sad to say but i will not be able to keep it, i want to finish the Tr6 but the funds are just not there right now. the engine is not original and it has no top, body rust is minimal, but it has a couple pieces of metal welded into the frame from a front accident. I tore down the engine in the car after i got it running because of low compression so it is not assembled.
Do you think this would be better to part out or sell whole with the pink slip? I just need a push in the right direction!!!
also what would be the best media to sell on, BCF, craigslist, ebay, etc..
TR4nut
Just depends on how fast you want to pull out of it - most times the parts are unfortunately worth more than the whole car, but it takes a while to sell them. If you still have the overdrive, that's a pretty easy sell, fenders will go easy too if they are in decent shape.
tr8todd
Project cars are very hard to sell and never command their true value. An easy way to make some money is to buy other people's projects and parts collections, sell off the choice pieces, and then relist what's left as a project for sale. Done this many times with MGBs and older BMWs, unfortunately I never have the will power to do that with the TR8s. Every one I drag home ends up getting a full resto.
tdskip
Me too Todd.
Not sure fenders are an easy sale right now. I have a bunch of 4 & 6 fenders that people only want to pay $200 for even though they ate straight and solid. No way they are going anywhere for that.
Post a bunch of pictures here and we'll be able to make better recommendations.
KVH
I'd urge you to sell it in one piece. Easy on you. Easy on the car. Good for an energetic and eager TR enthusiast. Good for the Marque.
I'd go EBAY and sell that Black Plate!
Tinkerman
I kind of have to agree with KVH. I've done a bunch of part selling on Ebay and while you can do real well (sometimes) shipping is a constant hassle, particularly on the large sheet metal parts.
Good luck on whichever way you decide to go.
Tinkerman
R TR4/4A 1963 TR4 soft hood cover with attached plastic stiffeners Triumph 2
T TR4/4A TR4 seat buffer problem Triumph 5
KVH TR4/4A TR4 Movie Showcase Triumph 3
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
oldbagpipe For Sale '2' Triumph TR4 engines Triumph Classifieds 9
scottkilpatrick TR4/4A Send Unit Issues - 62 TR4 Triumph 4
EvansClassicCars For Sale 1966 TR4 Triumph Classifieds 0
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 - Part 2 Triumph 8
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 Triumph 10
mctriumph TR4/4A earliest Tr4 ?? Triumph 0
D TR4/4A TR4 inner ball joints Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
mctriumph For Sale hood for early Tr4 Triumph Classifieds 0
Rod-H TR4/4A TR4 Body Number Plate Supplier Triumph 6
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
Tim Tucker TR4/4A Konig 16x7 wheels and leaf spring clearance for TR4 Triumph 5
MTr4 TR4/4A In search of a 1962 TR4 Triumph 2
A For Sale 1963 TR4 for sale Triumph Classifieds 0
Cokerair TR4/4A Searching for "How To" instructions for TR4 Tonneau Triumph 5
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
mctriumph For Sale Tr4 Short bubble Bonnet Triumph Classifieds 2
K TR4/4A TR4 no start Triumph 26
L For Sale TR6 1976 (restorable project) and TR4 1966 for parts Triumph Classifieds 4
G TR4/4A TR4 Lacks Spark! Triumph 22
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
tj_tr3_tr6 TR4/4A looking for Machine Shop TR4 Valve Job Ventura - Los Angeles area Triumph 4
K For Sale TR2-TR4 Camshaft Sprockets...New...1/2 Price Triumph Classifieds 0
P Wanted WTB Restorable TR4 Triumph Classifieds 7
A TR4/4A TR4 Overdrive Solenoid Triumph 19
J For Sale 1965 TR4 + TR3 Parts - floors, gauges, misc. Triumph Classifieds 14
D TR4/4A Automatic transmission in a TR4 A Triumph 13
Twit TR4/4A First startup of TR4 Triumph 4
Twit early TR4 Crank Handle wanted Triumph Classifieds 0
Lotuswins TR4/4A Is this normal? TR4 gap between door and cowl Triumph 10
R Tr4 restoration books Restoration & Tools 2
M TR6 EZ EPAS Steering Column Fitment to TR4-6. Triumph 0
Kurtis TR4/4A TR4 Wiper Arm Remval Triumph 2
Twit TR4/4A early tr4 check straps Triumph 4
Twit TR4/4A restoring TR4 sun visors Triumph 0
