complete trim kits
dh100m
Member
advise on where to purchase a complete interior, carpets seats ect and to quality of them who produces the most original items
Cheers tony for bn2
stevebn2bj7
I have purchased three complete interior kits from Heritage in Vancouver. Very happy with them and one of them was for a BN2. The only thing to question them on is the heel pad for the drivers carpet. Mine is incorrect but I bought it six or eight years ago. Overall quality is superb.
Tech396
After a painstaking attempt to deal with Heritage, I can only advise avoiding them at all cost..
I was given back broken parts, rear seats made from the wrong material, heel pad incorrect, wrong year door trim,lost original parts, and the list goes on after a 9 month ordeal.
Granted, it's a lower cost, and likely not as authentic as Heritage, but I am completely satisfied with the complete__carpet, seat covers & panel kit__from Moss Motors.
Five (>5) years later, the material is still holding up well, with no evident wear (except where the stowed soft top rubbed rear qtr pnls, but, that's the fault of the aluminum trim on the top than the interior).
"... completely satisfied with the complete__carpet, seat covers & panel kit__from Moss Motors"
Very nice! Did you do the interior yourself? I too am mostly satisfied with the full kit we got from Moss. Couple things were slightly mis-cut, and they sent two floor mats for one side instead of one of each, but a phone call solved that. Also noticed that some of the Moss pieces aren't trimmed--like your footwell pieces are--like some of the pricier kit.
Moss has regular sales on upholstery kits, and if you buy the whole shebang you should qualify for their lifetime 'good customer' discount of 10% on all subsequent purchases. NFI; I've just been buying from Moss for years and generally been happy with quality and service. Their lead customer technical support person--Michael Grant--does his very best to ensure quality parts (unfortunately, sometimes their suppliers aren't so conscientious--can we say 'County' here without getting censored?).
Someone commented on another thread that the battery cover--of a BN1/2--was the hardest part, but it looked to be the simplest to me so I started with it to get the hang of the stretching, gluing, etc. To me, the trickiest part was the parcel shelf--like doing origami.
Bob: I did do the interior myself__first time ever doing seat covers__so there were things I had learned, and would do differently the next time around! I'd already done carpet & door/side panels sets in other LBCs (MGB & MGBGTs and a TR4) so those areas went really well on the Healey, but I should've used some upholstery foam between the seat covers and the molded cushions (instead of carpet padding__SMH__) to get smoother lines.
I considered those to be my starter seats all along, so they're vinyl instead of leather. At some point, I'll redo them with leather, correct padding, etc.
I had a single issue with Moss on the 2-seater specific rear side panels, in that the wooden pieces were assembled incorrectly__the RH structural piece was fitted upside down to the LH panel board and vice versa. ONE (1) phone call, with a detailed explanation and new pieces were shipped out pretty quickly__they're not "stocked items" so they had to be made again__but still done as a First Priority and I'm sure I received them inside of two (<2) weeks. I was satisfied with their quality, initial shipping time__again, kits were made to order, and it was during one of their frequent upholstery sale promotions__and how well AND QUICKLY they handled my problem.
For anyone else doing a 6-cyl 2-seater, the rear quarter trims are unique (to the BN6/7) and did require some additional shaping (by cutting & sanding) the wooden pieces adjacent to the door's B-pillar. My only real complaint was that the vinyl was already glued down, so that required some careful peeling back before I could whittle away at the wood (a little bit at a time, so as to not go too far...). Had I known that before the replacement qtr pnls were sent, I would've requested them in a partial state of assembly. It really wasn't a big deal to correct, and after spending time on the first side, an hour at most, I was able to sail through the second one.
I took A TON of pictures while doing the interior, so may be of benefit to someone else doing the same job: https://spcarsplus.com/gallery3/index.php/Healey-at-home/Interior_Makeover?page=1
The masking and books for when the seat cushion pleats were glued down, and 50Lb sack of corn for the backrest pleats should be the best take-aways of the pictures! And DON'T use the carpet padding foam__all I could find local on a Friday night__between the seat covers and foam cushions (you'll see what I mean if you think you can put the covers directly on the molded foam__the originals had some sort of padded cotton/linen between them for smoothing).
You'll want to have a huge assortment of spring-loaded gluing clamps on hand, in lots of sizes, and I used a large quantity of paint-stirrer sticks to "pad" between the clamps and vinyl.
Trimming the wood to get the rear qtrs to fit...
Taking a little slice at a time!
Finished and fitted (what looks like a lump is a reflection off the chrome s/screen wingnut)
Masking and gluing pleats
Weighting them down overnight, before continuing assembly
Ditto the backrests (I had the corn on hand for feeding our ducks...)
You have to be in the right frame of mind doing the interior, and if you get frustrated, WALK AWAY for an hour or so; for the best results, I needed to be patient, and take my time.
I sprung for leather seats but paid a pro to do them (83-year-old who's been doing car upholstery since he was 13). He said they were a real PITA because he had to do a lot of trimming of the foam. One flaw in one seat bottom was a seam that wasn't cut or sewed exactly right, so there's a slight 'dogleg' on the edge of it (I think this might even out a little after my 190lb corn sack has sat in it for a few thousand miles).
Jerry
I also used the MOSS kit on my car. No complaints. I have leather, and comparing it to my TR3A, the leather is thinner, but holds up well. No problems after 6 years. I like the TR3A color better, but I got to choose the leather skin for that. One of the guys in our local club does upholstery, he said, buy a kit and let him install it. He will make it look perfect. I have not used his skills yet, but he basically says he can't make the kit for the price they sell.
healeyblue
Another vote here for Moss. I did it all myself and again the only thing that was not plug and play was the fine fitting of the foam to match the contours of the seat pleats. I actually added and sculpted some foam on the back rests. If I wouldn't it would have felt deflated. All in all was fairly straight forward just think the installation through and test fit every thing as you go.
John Turney
My interior is also from Moss. The BN4 seats are the same as the BN2 seats. They don't have as many colors as some suppliers, but they worked just fine for me.
bighealeysource
Bronze
I have used kits from Moss, Heritage, AH Spares and John Skinner. Highly recommend the two Brit firms and very pleased with the interior I got from John Skinner for my 100M. Pricing is competitive to Moss even with the freight costs from UK and I feel the quality is a bit better. Check them out before you decide.
Regards
Mike
dwpirkeyjr Red? Bue? Purple? Yellow? Poly Bushings Complete Set For 1979 MG midget 1500 Spridgets 6
CARSINC Follow My Spriget Blog As I Complete SpyderMite Spridgets 24
ROARRR For Sale 1930-40's AUSTIN 10 SALOON! straight, good glass, no through rust, very complete Austin Healey Classifieds 0
A For Sale Supercharger setup complete for Rover V8 3.9/4.0/4.2 Other British Classifieds 3
HealeyPassion For Sale Tri-Carb Complete Set including manifolds Austin Healey Classifieds 13
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
9 For Sale: Thermocarb - complete setup including special manifold Austin Healey Classifieds 1
H Wanted BJ8 Jack and complete Tool Kit Austin Healey Classifieds 0
K For Sale Original Grease gun and jack....complete your TR3 collection. Triumph Classifieds 0
K For Sale TR3 SU's For rebuild...complete Triumph Classifieds 1
maxwedge5281 Removing Complete Rear End From BN6 Austin Healey 5
E For Sale Austin healy 100/4 complete engine Austin Healey Classifieds 4
Got_All_4 For Sale Triumph Austin Healy Jaguar 15"x5.5" Complete Wire Wheels Set & Hubs Triumph Classifieds 1
K TR2/3/3A Value of a Complete Motor disassembled? Triumph 8
2billydavies TR2/3/3A Timing, fuel mixture, complete headache and total misunderstanding of it all Triumph 51
E How much should i pay for a complete 100/4 engine ? Austin Healey 4
6TTR3A TR2/3/3A Complete firewall hole illustration Triumph 3
anarchy99 A place to buy sprite interior panels not in a complete set... Spridgets 2
C MGB Fairly complete 1980 MGB with O/D in Stanton, CA Pick your part MG 3
thechileman TR4/4A Alternator Conversion complete- '64 TR4 Triumph 1
steveg Front Toyota disc conversion now complete - photo essay Austin Healey 0
D 1963 BJ7, I found a complete car Austin Healey 8
aseriesspares MGB MGB / Midget Complete Hardware Sets 30% OFF MG 0
aseriesspares SPRIDGET Complete Hardware Sets 30% OFF Spridgets 0
aseriesspares LAND ROVER SERIES 3 Complete Hardware Sets 30% OFF Rover / Land Rover 0
aseriesspares Classic Mini Complete Hardware Sets 30% OFF British Motor Corp 0
aseriesspares AH Sprite Complete Hardware Sets 30% OFF Austin Healey 0
C BN6 Complete Running Gear - What's it worth? Austin Healey 18
Gerard I'm looking for a complete rear axle housing Spridgets 11
aseriesspares Triumph - Complete Hardware Sets! SPECIAL OFFER! Triumph 0
aseriesspares Spridget - Complete Hardware Set! SPECIAL OFFER! Spridgets 0
aseriesspares MG - Complete Hardware Sets! SPECIAL OFFER! MG 6
aseriesspares AH Sprite -Complete Hardware Set! SPECIAL OFFER! Austin Healey 4
Gliderman8 Winter Project complete.... Triumph 9
Tr4dude TR4/4A tr4 sell complete or part out? Triumph 6
M can't complete my brake job! Austin Healey 15
Jim_Gruber Complete Spridget Front Clip Spridgets 1
RedTR3 Alternator Conversion Complete Triumph 4
J Spitfire 90% complete 78 spitfire at recycler, good co Triumph 3
C GT6 complete GT6 for sale in PA $1000 Triumph 6
C 69 midget PERFECT dash panel...COMPLETE 100 bucks Spridgets 3
C 2 manuals for sale. 1275 complete manual and book Spridgets 3
pjsmetana Gauges - 4 & 5 of 7 complete [pics] Triumph 0
pjsmetana Gauges - 3 of 7 complete [pics] Triumph 0
pjsmetana Gauges - 2 of 7 complete [pics] Triumph 10
M Supra 5spd conversion complete Triumph 21
Tabcon TR4/4A Price of Complete TR4 Engine? Triumph 6
H Help with Complete Dashboard Removal Austin Healey 1
LastDeadLast Hardtop finally complete!! Triumph 11
MCNX_BFF Interior almost complete Triumph 2
