For Sale Tri-Carb Complete Set including manifolds
HealeyPassion
Complete set of DWR (Denis Welch Racing) tri-carb manifolds which have been professionally polished, DWR linkage kit, DWR SS vacuum balance tube for manifolds, 3 rebuilt (like new) HS6 (1 3/4") carbs which have proper front, middle, rear configuration, correct insulator blocks, and original tri-carb exhaust manifolds ceramic coated inside and outside - SEE PICTURES More pictures available. DWR manifolds are a duplicate of the original tri-carb manifolds. Located in Denver CO area. Price - $3,000.
Looking at that price: DWM Triple Carb. Kit gas flowed is $640 (US) (look them up on DWM website), Triple SU's New run at about $800 (US) or $2,400 for 3 (DWM, other suppliers differ a little bit on price but right in this area) = $3,040ish ... before polishing. The tri-carb exhaust manifolds are near extinction they are unique to the tri-carb manifold option. These have been ceramic coated inside and out at a value of easily $800 for set. So market value is right around $3,800 - $4,000 if you can find a full set.
HealeyPassion
HealeyPassion
I'm in Larkspur. I'm going to be at Ax and Allies today if you can come by today I could bring them with me.
HealeyPassion
HealeyPassion
Ax and Allies 5890 Washington St #8, Denver, CO 80216l I'll be there from about 11:00 until about 2:30 today Mon. 2/21
HealeyPassion
HealeyPassion
Price reduction .... $2,800 ..... read description above.
BobHaskell
Does Dennis Welch assume that you're not going to use the choke? The choke cables for the factory tri-carb set up attach to a bracket spot welded to the balance tube. I didn't find anything on their website in the 3000 fuel section.
HealeyPassion
HealeyPassion
Bob, I really couldn't say what DW is thinking on this issue. I do think I may have an original OEM balance tube, which I guess should have the attachment point.... if so it can go with the package. If you are interested, I'll look into it.
Thanks,
Steve
HealeyPassion
HealeyPassion
Attached is picture of OEM Tricarb balance tube with original choke attachment brackets .... goes with the package.
Steve
Zitch SOLD!! SOLD - Tri-Carb Exhaust manifold for a 3000 Austin Healey Classifieds 0
T Air Filter Recommendations for My Tri-Carb Austin Healey 7
Healey Nut Tri-Carb Throttle Controls Austin Healey 4
D Tri carb: order of installation question. Austin Healey 5
Healey Nut Tri-Carb Project Austin Healey 213
CLB62 1962 BT7 Tri-Carb for sale on BaT Austin Healey 2
D 62 tri-carb upper fulcrum pins Austin Healey 4
M engine stutter of rebuild BT7 engine [tri-carb] above 2500 rpm Austin Healey 27
lbcspinners 1962 Austin-Healey 3000 Mk II BN7 Tri-Carb 2-Seat Roadster: for sale on BaT Austin Healey 2
D Grose valves / Tri-carb Austin Healey 11
D Tri-carb PCV valve Austin Healey 61
D 62 tri-carb fuel line connection Austin Healey 10
C Tri carb Austin Healey 7
T Tri-carb questions. Austin Healey 10
J BT7 [Tri-Carb] Restoration Upgrades Austin Healey 2
D 62 tri-carb tuning question Austin Healey 8
D BT7 Tri-Carb Distributor Cap Austin Healey 9
D BT7 tri-carb linkage set up Austin Healey 23
D BT-7 tri-carb Two more questions Austin Healey 18
D BT-7 tri-carb ring gap Austin Healey 10
D BT7 tri-carb installing my crank Austin Healey 4
D 62 / BT7 tri-carb engine Austin Healey 16
D 62 tri-carb wiring harness Austin Healey 10
HealeyPassion Tri-carb intake manifold balance tube size Austin Healey 10
steveg Rare colored tri-carb BT7 on eBay Austin Healey 13
davidb AH 3000 tri-carb throttle shafts Austin Healey 13
W Barrett Jackson Auction 62 2 Seater Tri-carb only brings 48k Austin Healey 19
Norman Tri carb - overheating issue ???? Austin Healey 10
K Tri-carb help Austin Healey 11
K Tri-carb help please Austin Healey 0
AH67 62 MKII Tri Carb, done with some pictures Austin Healey 9
M WTB: Tri Carb Choke Linkage Parts Austin Healey 8
BoyRacer What are MK II [tri-carb] 2 seaters selling for? Austin Healey 12
D BT7 Tri carb Backfire Austin Healey 2
M Tri Carb Camshaft Austin Healey 4
B tri carb problems Austin Healey 17
B Gas mileage Tri-Carb Austin Healey 2
A tri carb on ebay Austin Healey 14
C Cold air box for Tri Carb 3000 BT7 ??? Austin Healey 9
G tri carb vapor lock Austin Healey 30
J Seeking tri carb help Austin Healey 16
M 100-6/ 3000 tri carb set up Austin Healey 13
Patrick67BJ8 Ruddspeed Tri-Carb Set-up Austin Healey 9
6 BN7 tri-carb will not start Austin Healey 7
6 BJ8-BT7 Tri-carb Conversion? Austin Healey 7
B PCV Valve Tri Carb Austin Healey 11
C Tri - Carb assistance ! Austin Healey 5
Dave Richards WOW! a "RARE" tri-carb Austin Healey 12
C AH 3000 Tri-Carb conversion. Austin Healey 4
V Choke cables for tri-carb Austin Healey 5
