J
jeffsautomobilia
I am seeking some help with my 62 Tri-carb. I restored the car apprx. 10 years ago and have had trouble getting it to run correctly. Staring with the basics,It has 150 pound compression on all 6 cylinders. It starts right up and idles smooth but when I lift the suction piston on the front carb, it has no running effect on the engine whereas the rear carbs the engine will stumble. I can pull off the plug wires off of the front two cylinders (which have great spark) and it does not effect the running.I have checked everything for a vacuum leak, float adjustment,installed new needle and jet head. There is no restriction in the fuel supply from the float chamber to the jet head. I am running out of ideas, any help would be appreciated.
