BN7 tri-carb will not start
66ejag
Member
My BN7 will not start if the engine is warm, i.e., temperature above 90F. However, it will start easily when cold if choked and released immediately. Even though it runs satisfactorily once started, I am reluctant to drive since it takes several hours to cool down sufficiently if I stop. I checked the carb floats and they appear OK. I'm baffled.
Thanks and have a good day,
Ed
Keoke
Hi 66ejag, do you have the automatic choke on your tricarb?
R
RonMacPherson
Just for kicks, next time the hard starting hot occurs, open the gas cap and see if it starts.
AlanT
Two big Healeys acted as you describe this past weekend at the show. One was a coil breaking down when hot and the other was a condenser shorting when hot. Both would restart after cooling for a while. The carburetors were the first suspects of course. But then someone remembered the age-old rule...'Most carburetion problems are ignition'
Alan T
healeynut
Ed -
That is a classic symptom of either a bad condensor or coil.
Check for spark when the car is hot and see if the dizzy is sparking at the plug. If not - coil or condensor.
66ejag
Member
I replaced the coil with a used spare that I had. I also regapped the ignition points which were almost closed, a condition which I can not explain since the bolts were still tight. However, the Healey now starts at any engine temperature.
I intend to buy a new coil but would like some recommendations, e.g., original type or higher voltage type. My dizzy is original.
Thanks again to everyone,
Ed
Dave Russell
Yoda - R.I.P
Hi Ed,
It could have been the coil or the points or both. Most likely the points.
Depending on point brand & construction, the rubbing block (part on the movable contact that contacts the cam) can wear rather quickly which closes the gap, retards the ignition timing, & can cause a weak spark.
The distributor cam should be polished very smooth & a distributor cam lube helps reduce the wear rate. You still need to check the gap frequently & reset it if needed.
A higher voltage coil will only be a benefit "if" the plug gaps are increased. If the plug gaps are increased very much, it may cause the insulation of the rotor to fail. Quite a few rotors seem to fail anyway. The old Lucas cap & rotor design was just not up to handling higher voltages very well.
lbcspinners 1962 Austin-Healey 3000 Mk II BN7 Tri-Carb 2-Seat Roadster: for sale on BaT Austin Healey 2
R For Sale 1960 Healey BN7 Oil Pan For Sale Austin Healey Classifieds 0
H BN7 and BN2 Lengths Austin Healey 3
A BN7 Front Hub Stud Nuts Austin Healey 5
rgfrey 1959 BN7 Throttle Control Linkage Austin Healey 2
B Roof vent position on BN7 hardtop. Austin Healey 15
B Cold Start Problems BN7 Austin Healey 21
S For Sale Austin Healey 3000 and 3000 MK II Factory Parts Manual - BN7 & BT7 on CD/ROM Austin Healey Classifieds 0
G 1960 3000 BN7 Top Help Austin Healey 0
F Which Original Oil filter assembly for BN7 Austin Healey 19
F BN7's left Austin Healey 9
F For Sale Disc Wheel Hub, From Bn7 Austin Healey Classifieds 5
jnew >>> Austin-Healey Parts Lists for BN4-BN6, BN7-BT7, & BJ7-BJ8 Available Online Austin Healey 17
Healey Nut BN7 Austin Healey 6
R BN7 Speedometer issues Austin Healey 1
T BN7 wiring diagram in color Austin Healey 7
F Throw away BN7 Gas tank Austin Healey 3
F For Sale BN7 gas tank, original. [I think]. Austin Healey Classifieds 0
HealeyRick Nasty BN7 Sells for $75k Austin Healey 6
busybrit Healey BN4/6 bell housing vs BN7/BT7 differences. Austin Healey 2
stretchit2 Question regarding BN7 Hardtop Austin Healey 7
rjc157 bn7 electronic choke Austin Healey 0
BN6_2197 Front Wheel Clearing of BN7 Austin Healey 35
David Townsend BN7/BT7 Limited Edition Fine Art Prints Austin Healey 6
F VIN Problem / Whats difference between BN6 and BN7, bare car. Austin Healey 21
J 1960 BN7 2 seater roll bar. Austin Healey 5
R BN7/BT7 Windscreen Installation Advice Austin Healey 5
Marvin Gruber BN7 on Craigslist, Nashville Austin Healey 0
J Wood dash for 60 BN7 Austin Healey 16
S Green/white BN7 Chequered Flag Austin Healey 7
R How to erect at BN7 hood [top]? Austin Healey 4
bighealeysource BN7 sells for crazy money Austin Healey 22
R Proper Timing Technique '60 BN7 Austin Healey 0
Healey Nut Red bn7 Austin Healey 7
D Original BN6 / BN7 Battery Switch Wiring Question Austin Healey 15
B BN7 with BT7 VIN on eBay Austin Healey 11
R BN7 Windscreen removal Austin Healey 7
L 3000 BN7 insulation Austin Healey 11
R BN7 Coil Wires Austin Healey 3
R Need picture [s] of a BN7 or BT7 Servo installation Austin Healey 3
M Steering Wheel modification for a BN7 Austin Healey 15
R How to install a BN7 hood [top] Austin Healey 3
R BN7 / BJ7 Dash Top Removal Austin Healey 11
AH67 The size of battery for 62 BN7 Austin Healey 16
AH67 Spinning starter motor BN7 Austin Healey 13
AH67 exhaust & Battery kill switch- mkii bn7 Austin Healey 13
dougie 1960 BN7 For Sale Austin Healey 6
Jim_Newman Bn7 fan Austin Healey 6
R Headlight switch replacement on BN7 or BJ7 cars Austin Healey 3
AH67 ‎62 BN7 for $69,000? Seemed low to me.. Austin Healey 21
