Tri Carb Camshaft
mwagon
Is the stock cam grind the best for street use, or is there a better grind the gives some improvement at all rpm's? Elgin camshafts seems like a good source, but looking for feedback
GregW
dougie
It really depends on what your goal is, good street driver, gas milage, performance, etc. Elgin is a great source, but to get any real benefit you need to have your head flow tested first. Fellow racer Richard Mayer and I use Oregon Cam in Vancouver, WA https://calyxmanifold.com/products/products.htm for are re-grind work. My current race cam is pretty mild and could easily be used on the street. Ooop............... I guess I do use it on the street already.
https://youtu.be/nsmFs5J4qKo
Zitch SOLD!! SOLD - Tri-Carb Exhaust manifold for a 3000 Austin Healey Classifieds 0
T Air Filter Recommendations for My Tri-Carb Austin Healey 7
HealeyPassion For Sale Tri-Carb Complete Set including manifolds Austin Healey Classifieds 13
Healey Nut Tri-Carb Throttle Controls Austin Healey 4
D Tri carb: order of installation question. Austin Healey 5
Healey Nut Tri-Carb Project Austin Healey 213
CLB62 1962 BT7 Tri-Carb for sale on BaT Austin Healey 2
D 62 tri-carb upper fulcrum pins Austin Healey 4
M engine stutter of rebuild BT7 engine [tri-carb] above 2500 rpm Austin Healey 27
lbcspinners 1962 Austin-Healey 3000 Mk II BN7 Tri-Carb 2-Seat Roadster: for sale on BaT Austin Healey 2
D Grose valves / Tri-carb Austin Healey 11
D Tri-carb PCV valve Austin Healey 61
D 62 tri-carb fuel line connection Austin Healey 10
C Tri carb Austin Healey 7
T Tri-carb questions. Austin Healey 10
J BT7 [Tri-Carb] Restoration Upgrades Austin Healey 2
D 62 tri-carb tuning question Austin Healey 8
D BT7 Tri-Carb Distributor Cap Austin Healey 9
D BT7 tri-carb linkage set up Austin Healey 23
D BT-7 tri-carb Two more questions Austin Healey 18
D BT-7 tri-carb ring gap Austin Healey 10
D BT7 tri-carb installing my crank Austin Healey 4
D 62 / BT7 tri-carb engine Austin Healey 16
D 62 tri-carb wiring harness Austin Healey 10
HealeyPassion Tri-carb intake manifold balance tube size Austin Healey 10
steveg Rare colored tri-carb BT7 on eBay Austin Healey 13
davidb AH 3000 tri-carb throttle shafts Austin Healey 13
W Barrett Jackson Auction 62 2 Seater Tri-carb only brings 48k Austin Healey 19
Norman Tri carb - overheating issue ???? Austin Healey 10
K Tri-carb help Austin Healey 11
K Tri-carb help please Austin Healey 0
AH67 62 MKII Tri Carb, done with some pictures Austin Healey 9
M WTB: Tri Carb Choke Linkage Parts Austin Healey 8
BoyRacer What are MK II [tri-carb] 2 seaters selling for? Austin Healey 12
D BT7 Tri carb Backfire Austin Healey 2
B tri carb problems Austin Healey 17
B Gas mileage Tri-Carb Austin Healey 2
A tri carb on ebay Austin Healey 14
C Cold air box for Tri Carb 3000 BT7 ??? Austin Healey 9
G tri carb vapor lock Austin Healey 30
J Seeking tri carb help Austin Healey 16
M 100-6/ 3000 tri carb set up Austin Healey 13
Patrick67BJ8 Ruddspeed Tri-Carb Set-up Austin Healey 9
6 BN7 tri-carb will not start Austin Healey 7
6 BJ8-BT7 Tri-carb Conversion? Austin Healey 7
B PCV Valve Tri Carb Austin Healey 11
C Tri - Carb assistance ! Austin Healey 5
Dave Richards WOW! a "RARE" tri-carb Austin Healey 12
C AH 3000 Tri-Carb conversion. Austin Healey 4
V Choke cables for tri-carb Austin Healey 5
