tri carb vapor lock
Galen
Member
I have a re-built engine and re- built tri-carb with 500 miles. I am experiencing vapor lock at the carbs preventing the flow of gas to the carbs. I have been through the entire fuel system and upon pulling the fuel lines I get a back pressure. The result is a cutting out at 3000 rpms. Any ideas or suggestions on how to fix this?
Thanks Bruce Galen
GregW
Do you have the heat shields installed under the carbs? I here more tales about vapor lock happening where the fuel pump sits over the exhaust pipe.
G
Galen
Member
I replaced the asbestos panels with hardiplank. I suspect that heat is the issue here and possibly the fuel lines are at issue. I have just standard rubber fuel hose. You know the british did not spend extra money on manufacturing these cars but they did go to the extra expense of braided fuel lines for some reason. The fuel line is also at the highest point of the fuel system and air in the lines is the issue.
HEALEYJAG
Do not use gas with ANY alcohol additives or what used to be gasahol. I prefer high octane Sunoco only. Had big vapor lock with my V-12 e-type, only to figure out it happened when I used the wrong gas.
Pete
G
Galen
Member
The fuel pump is on the driver's side opposite the muffler.
I use the highest gas octane which all of the types in Texas have ethonal.
I have completely isolated the fuel tank, changed fuel pumps, etc. Checked static flow every where and no flow issues except under load.
I have run down the road watching the clear in-line gas filter as I go thru the gears pumping from a 1 gallon gas jug. (This takes 2 people and a wide unoccupied street)
There exists a back pressure from the carbs because I can see bubbles blowing back into the filter.
The filter is not filling with gas because of the back pressure. This eliminates all issues past the fuel pump.
There is vapor lock because when I pull the fuel hose from the back carb (tri carb) there is back pressure. (Whoosh- air)
I am going to change the fuel lines at the carbs to braided line and if that doesn't work Im going to try a 7 psi fuel pump (regulated to 5 psi).
GregW
I don't think I've ever heard (I know I've never seen) those filters ever filling up. They shouldn't be made see-thru. :eeek:
Patrick67BJ8
A higher pressure pump regulated to an even higher 5.0psi, than 3.5psi max for SU's might not be a good thing. When whatever is broke, fixes itself, you'll have other problems. Just my 1.5psi thought.
Patrick
GregW
I don't know much about SUs, but isn't there a vent in the float bowl that should keep that from happening?
SideShifter Tri-Carb
No, it has the check valve connected to the float. Gas would also come out if it did. The only way the check valve opens is if the gas level is too high or it's stuck :wall:
Actually, there is a washer that has a cloverleaf internal pattern under the center bolt. I'm guessing it is a vent of sorts.
Are you using a vented gas cap?
G
Galen
Member
Yes I am using a vented gas cap. But I have eliminated all potential issues from the carbs back to the fuel tank. the back pressure is at the carbs.
AH100M
Wow. Curious one.
A woosh back through the fuel line means that the air that's in the carb bowls has no place to go as it's being displaced by fuel being pumped in. You need a vent there someplace, like tahoe healey said above.
richch
We experienced a similar situation when getting a fully restored tricarb ready for the road a few years ago. Turned out to be a really bizzare situation.... Even though the carbs had been fully rebuilt by a professional, we finally found an old blockage in the vent tube on one of the float lids. It had been previously inhabited by some sort of insect which had virtually crawled in and mummified there, blocking the air passage. It was about the size of a large grain of rice but had to be dug out with a dental pick. Problem was solved.
Patrick67BJ8
I'm betting my money on this solution since I've heard of this happening once before.
Patrick
Ed_K
The top cover of the fuel bowl has to have a vent in it or;
1.. The fuel level would never be able to rise high enough to float the float up to close the little valve to stop the gas flow into a full fuel bowl.
2.. The build up of pressure in the top of the fuel bowl would force fuel out into the carb when it wasn't needed making for a very rich mixture entering the engine when at partial throttle.
3.. The build up of pressure in the top of the fuel bowl would slow down or stop the fuel in the fuel line from entering the carb until the pressure was released. This is the only way a rush of air would come out of a disconnected fuel line as described.
PS ... I have one of those glass inline filters and it is always 1/2 filled with air at the top of the glass when the engine is running.
Ed
Ed_K
I forgot to mention that unless you take the cover off the fuel bowl to the rear carb, you don't really know for certain that any fuel is entering the rear carb. Maybe the screen is blocked with trash or perhaps the float valve body is blocked with trash.
Ed
Zitch SOLD!! SOLD - Tri-Carb Exhaust manifold for a 3000 Austin Healey Classifieds 0
T Air Filter Recommendations for My Tri-Carb Austin Healey 7
HealeyPassion For Sale Tri-Carb Complete Set including manifolds Austin Healey Classifieds 13
Healey Nut Tri-Carb Throttle Controls Austin Healey 4
D Tri carb: order of installation question. Austin Healey 5
Healey Nut Tri-Carb Project Austin Healey 213
CLB62 1962 BT7 Tri-Carb for sale on BaT Austin Healey 2
D 62 tri-carb upper fulcrum pins Austin Healey 4
M engine stutter of rebuild BT7 engine [tri-carb] above 2500 rpm Austin Healey 27
lbcspinners 1962 Austin-Healey 3000 Mk II BN7 Tri-Carb 2-Seat Roadster: for sale on BaT Austin Healey 2
D Grose valves / Tri-carb Austin Healey 11
D Tri-carb PCV valve Austin Healey 61
D 62 tri-carb fuel line connection Austin Healey 10
C Tri carb Austin Healey 7
T Tri-carb questions. Austin Healey 10
J BT7 [Tri-Carb] Restoration Upgrades Austin Healey 2
D 62 tri-carb tuning question Austin Healey 8
D BT7 Tri-Carb Distributor Cap Austin Healey 9
D BT7 tri-carb linkage set up Austin Healey 23
D BT-7 tri-carb Two more questions Austin Healey 18
D BT-7 tri-carb ring gap Austin Healey 10
D BT7 tri-carb installing my crank Austin Healey 4
D 62 / BT7 tri-carb engine Austin Healey 16
D 62 tri-carb wiring harness Austin Healey 10
HealeyPassion Tri-carb intake manifold balance tube size Austin Healey 10
steveg Rare colored tri-carb BT7 on eBay Austin Healey 13
davidb AH 3000 tri-carb throttle shafts Austin Healey 13
W Barrett Jackson Auction 62 2 Seater Tri-carb only brings 48k Austin Healey 19
Norman Tri carb - overheating issue ???? Austin Healey 10
K Tri-carb help Austin Healey 11
K Tri-carb help please Austin Healey 0
AH67 62 MKII Tri Carb, done with some pictures Austin Healey 9
M WTB: Tri Carb Choke Linkage Parts Austin Healey 8
BoyRacer What are MK II [tri-carb] 2 seaters selling for? Austin Healey 12
D BT7 Tri carb Backfire Austin Healey 2
M Tri Carb Camshaft Austin Healey 4
B tri carb problems Austin Healey 17
B Gas mileage Tri-Carb Austin Healey 2
A tri carb on ebay Austin Healey 14
C Cold air box for Tri Carb 3000 BT7 ??? Austin Healey 9
J Seeking tri carb help Austin Healey 16
M 100-6/ 3000 tri carb set up Austin Healey 13
Patrick67BJ8 Ruddspeed Tri-Carb Set-up Austin Healey 9
6 BN7 tri-carb will not start Austin Healey 7
6 BJ8-BT7 Tri-carb Conversion? Austin Healey 7
B PCV Valve Tri Carb Austin Healey 11
C Tri - Carb assistance ! Austin Healey 5
Dave Richards WOW! a "RARE" tri-carb Austin Healey 12
C AH 3000 Tri-Carb conversion. Austin Healey 4
V Choke cables for tri-carb Austin Healey 5
