100-6/ 3000 tri carb set up
mmotors
Hello, does anyone know if you can bolt up a tri carb set on a car that does not have the tri carb exhaust manifold? I hate to pull everything off only to find out ot wont fit. Thanks
BlueRidge1
You will need the tri carb exhaust manifolds. Do a search for Bill Bolton in Oregon and he can most likly fix you up with all your needs.
BR1
healeynut
Not sure about that, but several vendors sell the 2" tricarb manifolds...
M
mmotors
there was recently a set modified to fit 2 inch on e-bay from Healey Haven(no bids so he still should have). Some tig welding was required, so simply boring out apparently isn't possible. I would wonder if the bonnet clear. would be an issue.
GregW
Denis Welsh makes two styles of headers. One of them I'm sure would work, they work for my tri-carb setup. CLICK ME
mmotors said:
Thank you. Where can the Al Kirk tube headers be sourced? Did a google search with no results. Thanks
(205) 608 1156
E-mail: info@kirkracing.com
A while back, someone said they were temporarily not available, due to fitment issues, but if anyone had bought regular steel headers from any of the usual sources in the last thirty years, Al was the guy that made them (my 1st set came from Sports & Classics, in 1978).
If he says he doesn't want to make them, be persistent (but pleasant)!
Patrick67BJ8
Randy Forbes said:
(205) 608 1156
I believe PAECO still makes them.
Patrick
HealeyPassion
mmotors, I have a set of AH tricarb exhaust manifolds if you find the intakes but not the exhaust...mine have been ceramic coated off black. You can contact me off forum if you want to pursue. scthomton@yahoo.com
Cheers,
Steve
Patrick67BJ8
anthony7777 said:
mmotors, ya got me thinking, can a tricarb intake manifold be drilled/bored to accept 2 inch (bj8) carbs? :savewave:
I've been told that you can go to 1.75" hole, but that is a lot of work. It would be probably better to locate a Ruddspeed manifold that is already set-up for 1.75" carbs. They came in L/H(USA)& R/H(UK)versions.
Going to 2" HD8's involves having to have Headers(a must) according to Nick at Nical Engineering in UK.
Patrick
E For Sale Austin Healey 100 and 3000 parts Austin Healey Classifieds 1
kodpkd For Sale Alloy valve cover for AH 100-6 3000 PRICE DROP! Austin Healey Classifieds 1
S Wanted Used Austin-Healy 100/100-6/3000 Restoration Guide By Gary Anderson And Roger Moment Austin Healey Classifieds 14
B Austin-Healey 100-6/3000 Electrical Drawing Austin Healey 2
S For Sale Austin Healey 100-6 and 3000 Factory Service Manual on CD/ROM. Austin Healey Classifieds 0
B Wanted 100-6 or early 3000 upper and lower grille opening pieces Austin Healey Classifieds 1
BN6 Healey 3000 and 100/6 Factory Hardtops serial numbers Austin Healey 5
J For Sale Healey Books: Anderson/Moment Restoration Guide; Robert Bentley; 100-6/3000 Factory Austin Healey Classifieds 7
J 3000 [BT7] with 100-6 Grill Austin Healey 2
T Trade 3000 Speedometer for 100/4 Speedometer TRADE Austin Healey Classifieds 0
BoyRacer 100/6, 3000 Disc wheels Austin Healey 4
T 100/6 vs 3000 driving experiences Austin Healey 71
C 100/6 & 3000 door handle - a puzzle Austin Healey 5
B Wanted I'm looking for a boot [trunk] lid and drivers rear fender for a 100/6 or 3000 Austin Healey Classifieds 0
D 100-6 and 3000 Child Seat Austin Healey 5
O For Sale AKD1179H 100/6 & 3000 factory manual Austin Healey Classifieds 0
BoyRacer Sloppy 100-6, 3000 door hinges Austin Healey 4
AN6-TX New Book: Factory Original Austin-Healey 100-6 & 3000 Austin Healey 8
J Drum brake instructions for 100/6 or 3000 Austin Healey 4
H Austin-Healey 100, 100-6, 3000 Restoration Guide Austin Healey 14
D 100-6 and 3000 MK-I Feeler Gauge Austin Healey 1
mrdibbles Austin Healey 100-6 & 3000 Disc Wheels - Ebay Austin Healey 2
pbraun I thought it was a 100-6, but it's a BT7 3000 Mk I Austin Healey 5
ronzet Spin-On Oil adaptor for AH 100-6 and 3000 Austin Healey 9
Bruce Bowker Book -Austin-Healey 100 & 3000 Series Austin Healey 0
Michael Oritt Looking for a good 100 crankshaft Austin Healey 3
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 7
A 100/6 BN4 Restoration Austin Healey 7
Editor_Reid Healey 100 Frame Diagram Austin Healey 1
A 100/6 BN4 Door Lock Austin Healey 15
R 100-4 Transmission Austin Healey 1
W For Sale Selling 1958 100-6 w/ hardtop Austin Healey Classifieds 4
R Healey 100 Dipstick Stuck Austin Healey 12
T 100 BN2 Possible Ignition Issue Austin Healey 10
T For Sale New Premium Water Pump for 100-6 Austin Healey Classifieds 0
R Big Healey 100 Head Austin Healey 4
G For Sale 100 Year Grille Badges Other British Classifieds 3
Guido36 Webers on a Healey 100 Austin Healey 6
R For Sale 100 engine block w/head Austin Healey Classifieds 3
A SOLD!! 1959 100-6 Austin Healey Classifieds 0
dougie '56 100-4 Racer For Sale Austin Healey 12
longbridgehealey SOLD!! 1957 100-6 BN-4 Austin Healey Classifieds 0
longbridgehealey Letting the 100-6 Go Austin Healey 26
P Wanted Wanted: Healey 100-4 frame Austin Healey Classifieds 4
M For Sale Austin Healey 100-4 Lemans Kit OEM Austin Healey Classifieds 5
A 100-6 Brake Lights Austin Healey 2
prb51 100-6 Brake Master Cylinder Bore Austin Healey 5
C What to do with my late father's Healey 100 Austin Healey 5
P 100/6 Front Wheel Alignment Austin Healey 10
