Ruddspeed Tri-Carb Set-up
Patrick67BJ8
Anyone have any/all information about these set-ups?
Anything else about the car engine mods?
Thanks
I'm pretty sure that they used 1-3/4" SUs. Camshaft profile and likely the ignition timing and/or advance was optomized. Not sure if the compression ratio was changed.
I "might" have a few pictures of a car I saw at a Cypress Gardens Healey Club show from about 1985. There was a running chassis (about to be restored, body already removed) that had the Rudd setup on it.
Patrick67BJ8
Patrick67BJ8
I would appreciate any photos!
I heard that they used the 1.75" HD6 carbs. I understand that the compression ration used required 100 octane. I don't know anything about what carb needles were used, etc. etc.
I'll have to do some digging, and then scanning, as those were pre-digital days /bcforum/images/%%GRAEMLIN_URL%%/wink.gif
Even at that, I don't have any technical details about the car, or its history.
Whatever details I do know, must've been from reading any of the available Healey Marque history books available. If I get the time, I'll glance through the index of some of them looking for content on Ken Rudd.
Patrick67BJ8
Patrick67BJ8
There was a website for Ruddspeed earlier this year and they were selling manifolds, valve covers and I think cams, but it's now gone and typing in Ruddspeed takes you to "Brooklands".
Sometimes you just get lucky; these pictures were where I thought they were...
For more details on this car, you might try contacting the Tampa Bay Austin-Healey Club and see if they have the participant's list from the Cypress Gardens show held June 6-7-8, 1985.
BTW, that's a white BN6L-942 in the background (took 1st place for "Keep 'Em on the Road" and 3rd for "Modified Roadster").
Higher resolution shots are at: https://www.rfdm.com/gallery/album08?page=5
Edit: I should add, that while the owner was somewhat "local" to the club, he drove the car to the show on the Saturday afternoon.
It was at this event that I met Paul Tsikuris, who was to do the bodywork on my car almost twenty (20) years later.
Leibinger
The setup was 3 SU HD6, some had special finned manifolds. The ignition and cam was also optimized and I think that the compression ratio was higher.
There is a very comprehensive write-up about the setup of a similar configuration regarding the carbs at a british healey club (see link: https://www.austinhealeyclub.co.uk/tech-tricarb.html). I am running the “good” setup for the DWR8 cam on my car with good results. I think it must come close to the Ruddspeed setup, which gave the engine about 175hp.
The Ruddspeed Website is offline, unfortunately, the manifolds appear at eBay once in a while.
By the way: There is a test of a Ruddspeed car in one of those Healey test collections (Austin Healey Ultimate Portfolio). In this feature, the car is running without air filters and with longer, finned manifolds. If I remember correctly, the setup is described well in this article.
Patrick67BJ8
Patrick67BJ8
Thanks for the info and I'll be checking out what I've received. FYI: The "finned" manifolds were for RH drive cars.
johnea
Hi Patrick,
Only RHD cars had finned manifolds. LHD manifolds were of slightly different construction to clear the steering column. The carbs were 3 HD6. The camshaft used was similar to the MK2 profile.
John
HealeyPassion AH Sebring/Ruddspeed EFI project car Austin Healey 6
HealeyPassion Survey of Ruddspeed valve covers Austin Healey 37
BN6 Austin Healey Ruddspeed Engine Serial Numbers Austin Healey 4
C Ruddspeed carbs Austin Healey 28
B Looking for some Ruddspeed help Racing 0
B Looking for some Ruddspeed help Austin Healey 12
T Ruddspeed Conversion Austin Healey 6
D Top installer recommendations NYC tri-State area Austin Healey 0
Zitch SOLD!! SOLD - Tri-Carb Exhaust manifold for a 3000 Austin Healey Classifieds 0
T Air Filter Recommendations for My Tri-Carb Austin Healey 7
HealeyPassion For Sale Tri-Carb Complete Set including manifolds Austin Healey Classifieds 13
Healey Nut Tri-Carb Throttle Controls Austin Healey 4
D Tri carb: order of installation question. Austin Healey 5
Healey Nut Tri-Carb Project Austin Healey 213
CLB62 1962 BT7 Tri-Carb for sale on BaT Austin Healey 2
D 62 tri-carb upper fulcrum pins Austin Healey 4
M engine stutter of rebuild BT7 engine [tri-carb] above 2500 rpm Austin Healey 27
lbcspinners 1962 Austin-Healey 3000 Mk II BN7 Tri-Carb 2-Seat Roadster: for sale on BaT Austin Healey 2
D Grose valves / Tri-carb Austin Healey 11
D Tri-carb PCV valve Austin Healey 61
D 62 tri-carb fuel line connection Austin Healey 10
C Tri carb Austin Healey 7
T Tri-carb questions. Austin Healey 10
J BT7 [Tri-Carb] Restoration Upgrades Austin Healey 2
D 62 tri-carb tuning question Austin Healey 8
D BT7 Tri-Carb Distributor Cap Austin Healey 9
D BT7 tri-carb linkage set up Austin Healey 23
D BT-7 tri-carb Two more questions Austin Healey 18
D BT-7 tri-carb ring gap Austin Healey 10
D BT7 tri-carb installing my crank Austin Healey 4
D 62 / BT7 tri-carb engine Austin Healey 16
D 62 tri-carb wiring harness Austin Healey 10
J Wanted tri-SU carbs, manifold and linkage for '69 series 2 4.2 Jaguar Classifieds 3
HealeyPassion Tri-carb intake manifold balance tube size Austin Healey 10
steveg Rare colored tri-carb BT7 on eBay Austin Healey 13
davidb AH 3000 tri-carb throttle shafts Austin Healey 13
W Barrett Jackson Auction 62 2 Seater Tri-carb only brings 48k Austin Healey 19
Bremer TR2/3/3A 4-2-1 headers [or Tri-Y] Triumph 5
Hap Waldrop King Tri metal Bearing MG 10
Norman Tri carb - overheating issue ???? Austin Healey 10
K Tri-carb help Austin Healey 11
K Tri-carb help please Austin Healey 0
AH67 62 MKII Tri Carb, done with some pictures Austin Healey 9
M WTB: Tri Carb Choke Linkage Parts Austin Healey 8
BoyRacer What are MK II [tri-carb] 2 seaters selling for? Austin Healey 12
D BT7 Tri carb Backfire Austin Healey 2
M Tri Carb Camshaft Austin Healey 4
R HD tri metal main bearings? Spridgets 5
B tri carb problems Austin Healey 17
stretchit2 Side Shifting Tri Carp Austin Healey 14
