Spitfire Turn signal wiring Spitfire
Richardspur
1974 Spitfire lefthand drive. Trying to figure out wiring for the turn signals. Colors are faded, can someone post a picture of the wires coming down the steering column and plugging into the correct wires below the dash. I have some female ends that have a place for two wires to plug in and just can't get it figured out. Thanks.
Trevor Triumph
Yes, the colors should match, but on my recent (two o three years ago - or more) puchase the colors are different. The green white seemd correct, but the cooors of the remaining wires were confusing. I had to use a test light to determine the proper connections. I checked the Haynes diagram and it shows a different color for later cars.
T. T.
Andrew Mace
T.T.: That seems odd (except for the fact that the reference is from Haynes, not always known for absolute clarity and accuracy! ;) ). All wiring diagrams I've looked at, including several very nice ones found at Triumphspitfire.com, show the colors as I noted above. The only other color that comes to play for the flasher circuit is a light green w/brown.
R TR2/3/3A Turn signal wiring Triumph 1
P TR2/3/3A TR3 turn signal and horn control wiring check Triumph 4
jaegzie Turn signal wiring on back of switch. What goes where. Spridgets 6
Tinkerman TR2/3/3A Front turn signal wiring question on my post 60000 TR3A Triumph 8
apbos Turn Signal Wiring Problems Spridgets 3
T XKE Series 2 Turn Signal Lever Stalk Wiring Jaguar 5
Jim_Gruber 68 Spridget - Turn Signal Wiring Colors Spridgets 2
Woodie turn signal buzzer wiring Spridgets 17
Cain Turn signal wiring Triumph 20
T TR2/3/3A Replacement Turn Signal Switch Triumph 4
jfarris TR2/3/3A Light show in the turn signal indicator bulb Triumph 2
K TR2/3/3A Turn signal flasher issue.....electrical is not my strong point. Triumph 13
K TR2/3/3A The horn and turn signal assembly. Triumph 3
KVH General TR Green Turn Signal Dash Indicator Triumph 8
L Wanted right front turn signal 1975 TR6 Triumph Classifieds 2
6 Turn Signal Flasher Spridgets 8
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
B General MG Turn Signal Issue MG 1
K TR2/3/3A Inside the horn and turn signal control head. Triumph 3
M Europa turn signal problem Lotus 7
S TR2/3/3A Rear turn signal lamp and trim installation Triumph 5
C TR6 TR6 TURN SIGNAL PROBLEM Triumph 13
S TR2/3/3A LED turn signal -- panel flasher not working Triumph 5
R Turn Signal Knob goes off center Austin Healey 9
E MGB Turn signal bulb MG 5
Nelson Turn signal beeper. Spridgets 14
M TR2/3/3A 1960 TR3A turn signal harness Triumph 6
M TR6 Turn signal switch stalk Triumph 1
J BJ8 Phase 1 left turn signal [driver side] Austin Healey 16
K TR2/3/3A Turn signal and control head memory refresh..... Triumph 9
K TR2/3/3A Turn Signal Control Head Alignment Again Triumph 1
J 1997 Vanden Plas X300 ,Help With Turn Signal Blowing Fuses Jaguar 3
T TR2/3/3A Is it possible to buy stronger springs for turn signal lever in control head? Triumph 14
B Turn Signal Indicator Light Always Flashing Austin Healey 10
R TR2/3/3A The Turn Signal Challenge Triumph 2
TR3TR6 TR6 TR6 turn signal puzzle Triumph 11
S Turn signal nightmare ! Spridgets 4
S Turn signal nightmare ! Austin Healey 4
N Turn signal flasher?? Spridgets 8
J BJ8 Turn signal help needed. Austin Healey 6
PAUL161 T-Series Turn Signal Flasher MG 8
glemon General Tech Turn Signal Issue Triumph 12
TR3TR6 TR6 Turn signal lights don't flash when under load. Triumph 5
R Turn signal switch [trafficator] Austin Healey 1
S Bizarre turn signal issue Austin Healey 10
bighealeysource Turn signal gremlins on BN2 Austin Healey 2
bighealeysource Turn signal issues Austin Healey 6
J LED Brake / Turn Signal Austin Healey 4
77MidgetMkIV High Beam/Turn Signal switch issue? Spridgets 21
M Turn signal problem Austin Healey 3
