TR2/3/3A Front turn signal wiring question on my post 60000 TR3A
Tinkerman
So, I'm sitting here looking at the terminals on my 2 repro front turn signal lampe and not quite sure where to put the wires. I know where the ground goes and I know which pigtail goes to the drivers side and which one goes to the passenger side. There are two barrel terminals on the lamp at the top. I suspect that it matters which terminal the striped wire goes to and which one the red goes to.
There are two filiments in each bulb, should be a clue but still not sure.
So any guidance would be very much appreciated!
Thanks, Tinkerman
Geo Hahn
You want to end up with the red wire going to the lower wattage filament in the dual filament bulb.
Every time I work with these I have to again look up how to tell which bulb terminal is which.
TR3driver
Great Pumpkin - R.I.P
I just try them out. Pull the switch to the first position, which should make the red wire hot. Connect the ground, then touch the red wire to each terminal. The one that gives a visibly dimmer light is where it goes.
Of course usually, I connect the short subharness to the bulb holder first; in which case I use a DC power supply for the test. A 12v battery would do as well, but you have to be a bit more careful not to short it out. But in a pinch, you could do it on the car.
Yet another alternative : Use an ohmmeter to determine which filament has the highest resistance. That one gets the red wire.
Geo Hahn
Here's the sort of diagram I usually have to look up:
Tinkerman
Tinkerman
Thanks guys! that answers my question.
Geo where do you look that type of info up?
Dick
tinman58
It must be a Lucas diagram.
TR3driver
Am I missing something, or does this diagram contradict itself? IIRC, the bulb on the RH side of the diagram is correctly identified as to which filament is which.
It does seem to contradict itself. But I have no idea which is correct.
Geo Hahn
Geez -- you can't believe everything you find on Google. And that was the neatest, clearest illustration I could find.
I think they confused rotating the bulb in the horizontal plane with rotating it in its axis -- anyway, they got confused.
Try this, noting that [tail = parking light] & [stop = brake or turn signal] and that you're looking at the side of the bulb with the 'higher' pin:
Or just pick your own:
https://www.google.com/#q=1157+diagram
L Wanted right front turn signal 1975 TR6 Triumph Classifieds 2
G Correct location of front turn signal on bj8 3000 Austin Healey 3
Patrick67BJ8 1967 Phase-2 BJ8 - Front parking & turn signal lights alignment Austin Healey 8
Coyote1 TR6 74 TR6 Front Turn Signal Alternative Triumph 9
theleisure Front Turn Signal Bulb Spridgets 6
Brooklands TR2/3/3A TR3B front bumper and turn signal woes. Triumph 18
zimmy front turn signal lens Spridgets 4
regularman 71 midget front turn signal lens question Spridgets 2
steveg Picture needed - front turn light Austin Healey 4
Jim_Gruber BE Quiz for Today - Beehive front Turn Signals take a ? possibly 6/32 screw Spridgets 1
Jim_Gruber BE Quiz for Today - Beehive front Turn Signals take a ? possibly 6/32 screw Spridgets 2
jfarris TR2/3/3A Front Turn Signals / Marker lights Triumph 3
D front turn lights Austin Healey 15
I Bugeye wiring help for front turn indicator Spridgets 13
Brooklands TR2/3/3A Front Turn Signals on TR3B grill Triumph 7
M Front Park Turn Lamps 66 Sprite Spridgets 7
zimmy front park turn lamp lens Spridgets 3
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 7
AngliaGT 1997 Miata - Anyone Have a Picture on How to Mount the Front License Plate Bracket? Other Cars 12
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
1 TR2/3/3A Rimmer Brothers Replacement Front Wing Quality? Triumph 8
Carlbanan56 MGB Front hub MG 4
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
scottkilpatrick TR4/4A Front Brakes - Basics for Pads Triumph 11
C MGB-GT MGB-GT Front Ride Height MG 0
C MGB-GT Front Ride Height MG 0
J For Sale Bilstein Front Shocks for Jaguar E-Type 727-498-6493 Jaguar Classifieds 0
J TR2/3/3A Mystery knocking sounds at front wheel Triumph 11
E Wanted 1963 Healey 300 mark 2 front grille wanted Austin Healey Classifieds 0
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
AUSMHLY Front Wheel Spin Drag Austin Healey 6
mctriumph TR2/3/3A Front Suspension upgrades for the 59 Triumph 10
CARSINC For Sale Sprite Front Wire Wheel Hubs Spridgets Classified 0
bighealeysource Front Brake Adjusters Austin Healey 0
TR3Acustodian TR2/3/3A Replacing "H" front badge Triumph 11
G Rebuilding Front Seats Austin Healey 4
drooartz MGB Front suspension rebuild is next MG 57
Joel Lester TR2/3/3A What final front suspension torque settings needed? Triumph 7
H TR4/4A Advise asked for front repair Triumph 1
A BN7 Front Hub Stud Nuts Austin Healey 5
P 100/6 Front Wheel Alignment Austin Healey 10
Prof. T Wanted 1974 - TR 6 Front Chrome License Plate Holder Triumph Classifieds 1
