Bugeye wiring help for front turn indicator
ichthos
I am still at it with the wiring. I need help with the front turn indicator lights. I have a black, red, and green/red wires going to my front indicator. I know that the black has goes to the single connection attached to the light fixture itself. The red and green/red both connect just behind the bulb. My question is, does it matter what side the red or green/red wires go to? Thanks as always for all of your help everyone.
Kevin
Jim_Gruber
One of those wires is for the running light and the other is for the turn signal. As I recall the red is for the running lamps. Your beehive lamps should have room for 3 wires to connect. If only two you've got the tail lamps installed.
I
ichthos
I aleady did the back behives - there were only two wires, so the red went to the base of the buld and the black to the side of the socket. Yes, I do have three wires going to the front beehive, so how do I know which wire goes to which side?
Kevin
smaceng
Your turn indicator bulb has two circuits-one for the running lights(low brightness) and one for the turn signal lights (higher brightness). the red wire goes to the running lights and the green/red (LH) or the green/white (RH) goes to the turn signals. Your bulb sockets have to accept the type of bulb which has two filaments. If you interchange the running and the blinker light wires, the blinker will be dim and the running lights will be bright. Just switch them around.
Good luck.
Scott in CA
I
ichthos
So, if you look at the back of the socket, the black goes to the bottom, the red goes to the left side, and the green/red goes to the right? Would it be the same on both sockets?
Kevin
Platinum
:iagree:
You can't hurt anything if you get the two power leads mixed, the result is just as Scott described. If the red (running light) wire is connected to the signal side of the socket the lamp will blink "dull" and the running lamp will be brighter... just reverse 'em. The sockets should both be the same. The tracers on the green leads are to tell right and left, again as Scott describes. I've used the "white/right" rhyme to remember one from the other.
...Or if ya prefer: "red/port" (as in wine). :wink:
As an aside, in Italian "left" is "sinistra"... red can be considered sinister, left-handed folk were considered so back-when.
JPSmit
we still are :devilgrin:
Platinum
...figures...
:jester:
JPSmit
I
ichthos
I was worried about damaging my new wiring harness, so it is good to know I won't cause damage if I reverse the wires, thanks. I plan on putting a fuse inbetween the positive cable connection from my battery just in case when I finally get my car back together (not sure what amperage fuse I will use yet). Are you saying the solid red wire would go to the left side of the socket? (left being my left if I were sitting in the car?)
Kevin
Platinum
I can't recall which is which, just be sure none of the green ones are connected to a ground terminal. All else is easily sorted if bas-ackwards.
Platinum
Random thought: As a sorta-kinda "general guide": All black wires are ground circuit, brown wires are generally constant "hot" when battery is connected, green ones are ~mostly~ powered thru the iggy switch... tho there are exceptions. The other colors are specific to devices. Blue ones are headlamp, purple for horns, red for instrument and running lights. Various tracers distinguish function. A black tracer generally means a "switched ground" circuit. White or red, a "switched hot" one. Solid and tracer'd white ones are ignition circuit.
bthompson
[nonsequitur]
I love British wiring! Ever since I figured out the 'code', it's saved me untold hours tracing down all the little problems I'd inherited from the DPO.
[/nonsequitur]
Platinum
:lol:
I bugeye wiring help please Spridgets 2
I Bugeye wiring harness pathway help Spridgets 4
I bugeye bonnet wiring harness fasterner help Spridgets 16
I Bugeye heater wiring help Spridgets 5
I Bugeye headlight wiring help Spridgets 6
I Bugeye wiring harness help Spridgets 21
B Bugeye Electrical Wiring Diagram in Logic Format Spridgets 17
B Bugeye Sprite Wiring Diagram Spridgets 4
D Bugeye Wiring Progress. Spridgets 3
D Bugeye Wiring Diagram - First Draft Spridgets 10
Rut Wanted, Bugeye wiring harness Spridgets 0
Rut Bugeye wiring harness Spridgets 2
AN5Sprite WTB Bugeye/Lucas Wiring Piece Spridgets 1
D New custom Bugeye wiring harness Spridgets 39
Rut Bugeye wiring harness Spridgets 32
E Bugeye Wiring - New Fuse Block Spridgets 9
tony barnhill Bugeye Wiring Harness Spridgets 0
I New Bugeye wiring harness? Spridgets 17
Ohiobugeye Bugeye Rear Wiring Harness Route???? Spridgets 1
I Bugeye wiring pic needed Spridgets 4
marcm Bugeye Wiring and Brake Line Diagrams Spridgets 0
Bruce_B Wiring up my 58 Bugeye - Questions Spridgets 9
drooartz Bugeye Wiring pictures Spridgets 1
T Bugeye wiring question [last one - really!] Spridgets 10
N Bypassing/Hot wiring a bugeye Spridgets 10
T Bugeye Ignition Wiring Spridgets 10
G Wiring an electric tach in a Bugeye Spridgets 5
R Bugeye ignition switch Spridgets 2
T Music Video with a Bugeye, plus a hill climb video Spridgets 1
D For Sale 1958 A-H Bugeye Sprite Austin Healey Classifieds 3
Todd78d Bugeye carpet Spridgets 7
L For Sale original Bugeye SU H1-1 1/8 Carbs Spridgets Classified 0
Todd78d Bugeye choke linkage Spridgets 5
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
R Wanted Bugeye ignition switch Spridgets Classified 2
drooartz Replacing Bugeye windshield rubber Spridgets 6
CARSINC 1965 Sprite Bugeye Spridgets 5
drooartz The great Gordon Murray has a Bugeye! Spridgets 0
W Bugeye Tudor Wash Bottle Decal Spridgets 0
R Bugeye drum brakes Spridgets 7
SNClocks Bugeye Alignment Spridgets 4
S For Sale Bugeye wheels, steel with round holes set of 5 available Spridgets Classified 0
D Wanted Bugeye bonnet (hood) fiberglass or steel Austin Healey Classifieds 0
M Wanted Need 59 Bugeye Dashboard. LHD. Spridgets Classified 1
drooartz Restoring Penny the Bugeye Spridgets 22
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
