Bugeye Wiring Progress.
David_Doan
I was searching the web for relay panels and relay mounting ideas. I was inspired by the stuff I found at ceautoelectricsupply.com. The pic below reflects what I want to do.
This gave me the idea to make a relay/fuse panel. To keep the wiring organized in my head and on the car, I broke it up into 4 sections that all meet at the relay or interconnect panel.
  • Dash – switches, gauges, controls, …
  • Engine – alternator, coil, wipers, horn, …
  • Bonnet – all frontal lighting
  • Rear – rear lighting, fuel pump, fuel gauge
There’s a terminal strip for each section on the relay panel. The relay panel will be located on the right fender near the original regulator and heater fan, or in the passenger foot well under the heater fan location.
The entire wiring diagram and the rest of the details are in my blog: https://doan.us/blog/2014/06/22/re-wiring-take-3-almost-done/
JPSmit
Probably overkill, but impressive!!!! (and very well thought out) :bow::bow::bow:
David_Doan
I really did "try" to keep it simple. My headlight set up using the heater switch for hi-beams takes 3 relays. And technically the ignition and lighting relays could go away...
Here's the brake-down of the loads per circuit:
All around 10 amps worst case. The wipers will never be used (topless car). I guess the 2 original fuses worked OK because some stuff was not fused and no fuel pump.
With a 6 fuse block, I have a spare slot for an electric radiator fan.
B Bugeye Electrical Wiring Diagram in Logic Format Spridgets 17
B Bugeye Sprite Wiring Diagram Spridgets 4
D Bugeye Wiring Diagram - First Draft Spridgets 10
Rut Wanted, Bugeye wiring harness Spridgets 0
Rut Bugeye wiring harness Spridgets 2
AN5Sprite WTB Bugeye/Lucas Wiring Piece Spridgets 1
D New custom Bugeye wiring harness Spridgets 39
Rut Bugeye wiring harness Spridgets 32
E Bugeye Wiring - New Fuse Block Spridgets 9
I bugeye wiring help please Spridgets 2
I Bugeye wiring harness pathway help Spridgets 4
I bugeye bonnet wiring harness fasterner help Spridgets 16
I Bugeye heater wiring help Spridgets 5
I Bugeye headlight wiring help Spridgets 6
I Bugeye wiring help for front turn indicator Spridgets 13
I Bugeye wiring harness help Spridgets 21
tony barnhill Bugeye Wiring Harness Spridgets 0
I New Bugeye wiring harness? Spridgets 17
Ohiobugeye Bugeye Rear Wiring Harness Route???? Spridgets 1
I Bugeye wiring pic needed Spridgets 4
marcm Bugeye Wiring and Brake Line Diagrams Spridgets 0
Bruce_B Wiring up my 58 Bugeye - Questions Spridgets 9
drooartz Bugeye Wiring pictures Spridgets 1
T Bugeye wiring question [last one - really!] Spridgets 10
N Bypassing/Hot wiring a bugeye Spridgets 10
T Bugeye Ignition Wiring Spridgets 10
G Wiring an electric tach in a Bugeye Spridgets 5
R Bugeye ignition switch Spridgets 2
T Music Video with a Bugeye, plus a hill climb video Spridgets 1
D For Sale 1958 A-H Bugeye Sprite Austin Healey Classifieds 3
Todd78d Bugeye carpet Spridgets 7
L For Sale original Bugeye SU H1-1 1/8 Carbs Spridgets Classified 0
Todd78d Bugeye choke linkage Spridgets 5
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
R Wanted Bugeye ignition switch Spridgets Classified 2
drooartz Replacing Bugeye windshield rubber Spridgets 6
CARSINC 1965 Sprite Bugeye Spridgets 5
drooartz The great Gordon Murray has a Bugeye! Spridgets 0
W Bugeye Tudor Wash Bottle Decal Spridgets 0
R Bugeye drum brakes Spridgets 7
SNClocks Bugeye Alignment Spridgets 4
S For Sale Bugeye wheels, steel with round holes set of 5 available Spridgets Classified 0
D Wanted Bugeye bonnet (hood) fiberglass or steel Austin Healey Classifieds 0
M Wanted Need 59 Bugeye Dashboard. LHD. Spridgets Classified 1
drooartz Restoring Penny the Bugeye Spridgets 22
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
