TR6 74 TR6 Front Turn Signal Alternative
Coyote1
I am finding it difficult and/or expensive to find complete front turn signals for a 74 TR6. Is there an alternative that will work as a replacement? I would like to stay with original but they are hard to find.
Deleted member 8987
Get some of those big 4 or 5" round amber units from a truck supply company. Drill a big hole in the top of your wing, bolt it in and wire it up.
But gefore you do that, what's wrong with the ones you have?
Sometimes a new socket cn be fitted......
Coyote1
Coyote1
I just bought the car which had been partly restored when the owner died, 10 years ago. A lot of parts were lost including the front turn signals. In searching for replacements I could not find complete units and incomplete used are $160+ each.
hondo402000
doubt there are any that will fit the holes and look decent, keep looking on ebay, maybe someone on here has a spare set they will sell you
Hondo
DNK
Wrong part Elliott. IIAR He's looking for the front
Gliderman8
Oh... maybe that's the one for the '74 1/2.
I would check Rimmer Bros anyway to see if they have what you want... many times I've found that they have parts that others may not have.
www.rimmerbros.co.uk
L Wanted right front turn signal 1975 TR6 Triumph Classifieds 2
C TR4/4A Advice for grafting TR6 frame front to TR4A frame rear Triumph 15
M Wanted WTB Late model TR6 Front Brake Caliper Brackets Triumph Classifieds 0
R Wanted 75/76 TR6 front licence holder Triumph Classifieds 1
J Wanted TR6 Chrome Front License Plate Holder Triumph Classifieds 0
A TR6 '73 tr6 passenger front brake dragging Triumph 2
G TR2/3/3A TR6 Front Suspension A-Arms on a TR3A? Triumph 5
M TR6 TR6 Gas Leak From Front Carb Triumph 5
D TR6 1976 TR6 Front Brakes & Shocks Triumph 3
hondo402000 TR6 TR6 Heavy duty front Stub axles Triumph 12
K TR6 TR6 front end Triumph 2
W TR6 TR6 front wheels Triumph 7
hondo402000 TR6 TR6 front end alignment and wheel balancing Triumph 4
davidk TR6 Information for front crank seal - TR6 Triumph 11
hondo402000 TR6 TR6 Front Wiring harness on its way Triumph 0
B TR6 TR6 Front Oil Seal Sleeve Triumph 3
R TR6 Front TR6 Suspension Question... Triumph 7
charlie74 TR6 TR6 front bearing cap Triumph 4
T TR6 TR6 front wheel bearing ? Triumph 5
L TR6 TR6 Front Suspension Resto Project Part One Triumph 11
N TR6 How to check TR6 front wheel bearings Triumph 1
hondo402000 TR6 TR6 Lower front valance section replacement Triumph 2
I TR6 TR6 - how to pack front wheel bearings? Triumph 8
I TR6 This can't be good. TR6 front suspension rebuild Triumph 25
R TR6 Late TR6 Front Fender Removal Triumph 5
I TR6 TR6 front shock help Triumph 2
I TR6 Tinster's TR6 front suspension restoration part 1? Triumph 7
I TR6 TR6 front suspension rebuild suggestions Triumph 19
T TR6 Question on TR6 lower front inner wishbone bracket Triumph 1
hondo402000 TR6 TR6 rebuilt the Front Calipers, second time Triumph 2
hondo402000 TR6 Front Brake issues TR6 Triumph 2
T TR6 Tr6 front suspension ? & downside of Cali cars Triumph 1
A TR6 TR6 Front lower wishbone mount [rear] broken Triumph 1
N TR6 TR6 Front Spring Height?? Triumph 3
T TR6 TR6 front suspension re-bushing question Triumph 18
T TR6 tr6 front wheel bearings Triumph 15
jjbunn TR6 TR6 Front Hood Seal Triumph 6
zekjet TR6 Longer Front Wheel Studs for a TR6? Triumph 3
N TR6 Clip wires on front brakes for TR6 Triumph 9
SCguy TR6 TR6 front sway bar on a TR4 Triumph 1
T TR6 Decided to repair TR6 front valance rather than... Triumph 4
C TR6 Proper way to adjust front hubs, TR6? Triumph 13
hondo402000 TR6 TR6 front glass question Triumph 4
2wrench TR6 Pictures of TR6 dash refinished front + back Triumph 22
A TR6 Motor mount position--front/back?? TR6 Triumph 2
E TR6 TR6 front engine seal leak Triumph 11
R TR6 Lowering TR6 front end Triumph 15
E TR6 TR6 Front Suspension... Is there a trick? Triumph 8
R TR6 TR6 front brakes Jack Drew Triumph 13
G TR6 [TR6] removal of front transmission seal Triumph 5
