TR4/4A Front Brakes - Basics for Pads
scottkilpatrick
Hi All, I am doing a full brake inspection on my new 62 TR4 as I don't know when they were last done prior to buying and they feel odd. So front brakes first and I am a newbie with brakes.
It appears these are newer calipers and there is NO leaking from the flex lines but I am probably gonna replace them with steel ones while I have the wheel off.
Question: I was gonna swap out the pads but to me they look like they still have a lot of meat left...appears about 3/8" thickness. Can you tell usually if they have sufficient life left by looking or do you need to pull off the caliper and pull them out? Opinions. Pics below of passenger side and drivers side.
Also I thought wheel cylinders were for all wheels but I think they are only on the rear. Can someone confirm? Thanks Everyone
charleyf
I agree that the calipers appear to be at least restored. The pads look to be really close to original thickness. What you see on the front is all that should be there. A close look at the condition of the rubber boots would verify if the restoration is recent. Older rubber boots would be dirty and maybe even cracked.
No wheel cylinders on the front. Only with the rear drum brakes.
Your calipers are a type used on a TR3. Can you tell tell us what is the commission number of your car? Should not be a problem except when ordering replacement parts.
Charley
scottkilpatrick
scottkilpatrick
Thanks Charleyf...the calipers look replaced to me...like not original - see pics.
The boots - if these are the ones you are speaking of - don't look brand new but I have inspected them and they are not ripped or super old.
Commission number - not sure which number that is but i shot both engine and vin tag...i think its early 62 from my research. thanks again for all the info. Do you think these calipers are ok for this car? There is no leaking and the rotors look in good condition - very smooth. Hopefully this mean good luck with the front brakes and maybe I only focus on the rear brakes.
Opinions - Flex Line Hoses...should I replace these if they are not leaking? Im hesitating because they are not cheap and so maybe i just keep an eye on them. they seem fine to me
charleyf
Just a little more information tells a lot. Your car is an early TR4 which came with the TR3 style calipers. Up through CT 4689. This is something to keep in mind when ordering any parts. Some parts were carried over from the previous model ( TR3) and later changed after the new model( TR4) came out.
The calipers do appear to be refreshed. The rubber boots that I was referring to are not the ones in your pictures ( which are the steering rack boots) but rather the ones that are between the actual brake pad and the caliper body. You only get a small look at them as they stick out only about 1/8" from the caliper.
Take a close look at the brake lines on the car. If they are clean and look new they likely are recently replaced. Additionally you may be able to see a date printed in white on the rubber line. I continue to use the standard rubber lines on my cars. That includes about 40 years of driving TRs with no failures.
Your commission number is the one on the black plate.
As clean as your engine looks I would guess that there has been recent work completed. It would be very helpful to you to find out just what all was done. Then you will not be wondering if you should be concerning yourself with any upgrades or restorations.
Best of luck with your TR4. May you have many enjoyable miles ahead.
Charley
sp53
I agree with Charley, the front brakes look new. I find on these cars the rear brakes need to be adjusted tight to the drum so there is very little play to make the pedal hard. When they are adjusted, I like to hear a little drag from shoe on the drum. The rear shoes are adjustable and the little square adjuster is often difficult to move and last turn of adjustment is most difficult. The adjusting square moves a cam that has a high spot then drops down. They make a special wrench for adjusting the brakes. I think it is a ¼ inch square, maybe 5/16. Be careful not to leave the adjustment on the high spot of the cam. You will see when you move it around. Clockwise tightens the brakes. This also tightens up the E-brake.
Steve
scottkilpatrick
scottkilpatrick
Silly question for the rear brakes:
I have the e brake on to keep the wheels from spinning - is there a trick to getting off the four lug nuts pictured here - i want to get the drum off on each side to examine the wheel cylinder and the shoes but they seem pretty tight - is it just muscle with a ratchet?
charleyf
If the wheel still turns have a helper push the brake pedal -hard!
Otherwise a socket and if necessary a cheater bar.
They should only be about 50-60 lbs. torque ( for when you put them back on).
Charley
mctriumph
Scott, welcome to a new world of "what should I do" You have a very early car and the factory
used any and all leftover bits and bobs to clear out the bins.
JUNK your Tr3 brakes! (IMHO) The Tr4 calipers are not terribly $. But first decide if you will ever
need /want the good stuff.(autocross ,ralleys). I am a firm believer in Wilwood brakes. for a few more $$
you have the best and will ,in todays traffic, need them sooner than you suspect .
The discs need to have the latter diameter( machined down) the new calipers will then bolt on.
This will save 12 pounds per wheel of un-sprung weight and give you 4 pistons of stopping power.
Then you can pick the pads that best suit your driving needs.
Your splines have ,doubtlessly nuts Loctited in place, they will require some effort. Don't forget
to do this on re-assembly.
Mad dog
sp53
On way is to have impact wrench and use that. An impact wrench hits with a force that spins the nut and not the wheel.
Steve
mctriumph
Hamish, my contention is that the early 15 lbs each calipers should go in the bin. If you spend $ on brakes,
compare the costs of refurbished later brakes to Wilwoods . Then figure in what your driving needs will
demand for safety. I have Wilwoods on my 59 as it is capable of 100mph in 3rd gear(5speed Supra trans)
Just feels good to have the extra margin....
Mad dog
K TR2/3/3A Sticking front brakes? Triumph 9
K TR2/3/3A The flexing front spindle and no brakes syndrome? Triumph 5
John_Mc TR6 Front brakes won't release Triumph 20
Ohiobugeye Front brakes won't release after disc brake conversion Spridgets 10
C 100-6 front drum brakes? Austin Healey 36
C Wanted 3000 Front Disc Brakes Austin Healey Classifieds 4
C For Sale BN1 Front Drum Brakes assemblies and hubs for sale Austin Healey Classifieds 0
P Front drum brakes - fluid lines Austin Healey 12
certifiedcarnut pipe between front brake wheel cylinders on 948 midget [drum brakes] Spridgets 4
C Value of BN1 Original Front Drum Brakes? Austin Healey 4
BN6_2197 Disassembling BN6 Front Brakes Austin Healey 14
trrdster2000 Post-War Other Front brakes on the Roadster Triumph 5
R BJ8 Front Brakes drag some Austin Healey 9
T TR2/3/3A TR3A front brakes Triumph 2
mgedit TR2/3/3A Front Drum Brakes 56 TR3 Triumph 2
D TR6 1976 TR6 Front Brakes & Shocks Triumph 3
M Stuck front brakes? Spridgets 8
M Front brakes are sticking Spridgets 33
C Bugeye Disc Front Brakes FORUM Navigation Questions 0
C Bugeye Disc Front Brakes Spridgets 4
coj 1960 Healey 3000 front and rear brakes Austin Healey 2
bighealeysource front disc brakes conversion for 100-4 Austin Healey 21
O TR2/3/3A 1960 TR3 Front Brakes Triumph 2
Stewart Dragging front brakes MG 7
B front disc brakes- 66 sprite Spridgets 8
RickB Front brakes seizing - what's with that? Spridgets 23
M Slight bind in front brakes Spridgets 7
R Front Brakes... Spridgets 7
sparkydave Dragging front brakes Spridgets 4
T Check list to convert to front disc brakes Spridgets 9
T Front disc brakes make a big difference? Spridgets 5
T Time to redo all my brakes and front suspension... Triumph 14
S TR2/3/3A tr3 front brakes hoses Triumph 9
drooartz Installing front suspension/brakes - review Spridgets 1
zschicago my first Healey and questions about front brakes Austin Healey 10
v8mgbal front brakes Spridgets 9
M Difference between MK IX and XK 150 Front Brakes? Jaguar 6
Brosky Front Suspension & Brakes -Done Triumph 5
N TR6 Clip wires on front brakes for TR6 Triumph 9
eejay56 BMW 320i front brakes locked up Other Cars 8
1 front brakes Spridgets 3
19_again leak front brakes MG 6
M front brakes Spridgets 12
M front brakes Austin Healey 3
jmwuva05 Front drum brakes. Spridgets 2
ncbugeye Front wheels won't spin, dsic brakes binding? Spridgets 13
zimmy front disk brakes Spridgets 9
T TR4/4A Early TR4 - Front Brakes Triumph 3
zimmy front brakes and calipers Spridgets 3
R TR6 TR6 front brakes Jack Drew Triumph 13
