front disc brakes conversion for 100-4
bighealeysource
Bronze
Hey all,
Anyone know of a conversion kit available for a BN2 100-4 ? Think I have seen one offered but cannot recall where or more important how much?
Thanks,
Mike
elrey
Check the web. AH spares has one. Dennis Welch also, I'll bet many of our members have done this with photos to boot...
bighealeysource
bighealeysource
Bronze
Thanks Y'all ! Knew I had seen this somewhere and this is the exact info I needed. Going over my entire braking system this weekend and was looking for options if everything checks out okay. My BN6 had a servo along with the standard brakes and always felt real comfortable with its brakes.
REgards,
Mike
bighealeysource
bighealeysource
Bronze
Meant to ask, it would seem that Genos2 idea would work, is that correct ? Could I simply install the front disk brake components from a 3000 as opposed to spending about $800 for the system from Denis Welch or others ? Sure there is some expensive reason why it won't work but worth asking.
Thanks,
Mike
Michael Oritt
Mike--
I have a 3000 disc setup on my 100--works fine!
Genos2
Mike, it will work & I'm going to convert my '53, but on her I have to change kingpin-axle assemblies!! BN2's that isn't required! cheers Genos2
John Turney
I was just reading page 204 of 485 of these AH 100 articles and saw that if you use the front disc brakes from a 3000, you have to use the rear wheel cylinders from a 3000 to have proper brake balance:
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]I was recently contacted by a club member for advice on installing disc brakes to his 100/6. This is
a rather straightforward exercise, as the later 3000 series components will literally bolt straight on to
the 100/6 front suspension.
However, two important points should be kept in mind:
1. When replacing the front drum brakes with disc brakes, the 1" diameter rear brake cylinders
MUST also be replaced with the 3/4" dia. brake cylinders as used on the 3000 series. If this
is not done, your brake system will be thrown out of balance, and under emergency braking
situations, particularly on a wet road, your rear wheels will lock up, causing the car to swap
ends with possibly very serious, perhaps even fatal results.[/QUOTE]
bighealeysource
bighealeysource
Bronze
Thanks for all the additional comments about this swap. I have checked and the cost of a "kit" from either Denis Welch or AH Spares is in the 735 pound range so going that direction would not be cheap. Haven't really looked at maybe trying to get the main parts on a used basis and not sure I would want to with it being my brakes. In the meantime I did find one of the problems with my original brakes on the 100M - the posts on the bottom front brake shoe was not installed correctly so the adjuster did not make contact and as a result you could not adjust them properly. Changed that around by switching from one side to the other and viola, have better braking.
Regards,
Mike
VTHealey
Does anyone have any experience with a disk brake conversion on the rear of a bj8? I guess the parking brake could be an issue...
John Turney
The parking brake is an issue. I'm still trying to come up with a solution for my BN4.
OTOH, the regular brakes work great. I'm using a Nissan master cylinder which seems to provide good front/rear balance, provides a two-circuit system and installs relatively easily.
glemon
Regards,
Mike
The parts you replace with used in the conversion from a later Healey are the various hard metal suspension bits, hangers etc. These parts would be used but newer than what is on the car, and could be magnafluxed if suspect or for your piece of mind.
I assume you and most would go with new or rebuilt calipers, new discs or checked to be in spec, new hoses and pads etc. If you could find the donor parts still much cheaper than it sounds like the kits are, it is all bolt on.
Your money and choice, just eleborating a little on the later healey swap, my 100 had the brakes from an early 3000, worked fine, and of course you can order all the wear parts from the usual suspects when they need to be replaced.
big6
John, What specific model Nissan master cylinder are you using?
BobAH100
Mike--
I've converted my early '53 100 to front-disc brakes, using the Denis Welch kit, and retain the stock early 100 rear drums, which are virtually new. The Welch kit usses what are essentially BN/BT7 front calipers. Also used their beefed-up front stub axles, which take BJ8 bearings and distance pieces. Not cheap nor easy to install, but slick.
THE ISSUE: With the standard early 100 master brake cylinder, the front brakes tend to lock up due to too much residual pressure being held against the calipers when the brake pedal is released. We're adjusting the brake-pedal free play and switching from DOT 5 (which was in the car) to DOT 4. Assuming these don't solve the problem, which Nissan master cylinder might work with this setup? I'd heard the old Datsun 510 master might be a candidate. Dual master cylinder setups are another option, but require yet more intensive work and lots more money. Thanks!
maxwedge5281
mike, i just sent you a pm regarding a disc brake setup. thanks, maxwedge5281
roscoe
I needed new hubs and wheels (which I got from Moss) and I decided to bite the bullet and get front disc brakes as well and I am very happy with what I got from Dennis Welch. Well, except for the price but I figure I'll recoup that when I'm too old to drive and sell the car:highly_amused:.
Ohiobugeye Front brakes won't release after disc brake conversion Spridgets 10
C Wanted 3000 Front Disc Brakes Austin Healey Classifieds 4
C Bugeye Disc Front Brakes FORUM Navigation Questions 0
C Bugeye Disc Front Brakes Spridgets 4
B front disc brakes- 66 sprite Spridgets 8
T Check list to convert to front disc brakes Spridgets 9
T Front disc brakes make a big difference? Spridgets 5
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
K TR2/3/3A Securing new brake disc to the front hub? Triumph 4
I Bug eye front disc brake conversion. Spridgets 5
L Denis Welch Front Disc Conversion Kit 100/6 Austin Healey 6
KVH TR4/4A Front Wire Wheel Hubs Differ from Disc Hubs?? Triumph 5
K TR2/3/3A Front disc brake squeal.... Triumph 4
croz TR2/3/3A Moss Replacement front disc pads Triumph 3
R BJ7 Front Brake disc hitting Austin Healey 12
maxwedge5281 front disc brake hubs for steel wheels Austin Healey 24
steveg Front Toyota disc conversion now complete - photo essay Austin Healey 0
pkmh Dismantling BJ8 Front Hub From Caliper Disc Austin Healey 20
R TR4/4A Disc wheel studs front and rear TR4a irs Triumph 4
O Front disc's from a 63 Midget Spridgets 0
Trevor Jessie Front brake line locating brackets [disc]. Spridgets 6
M BN4 prob with disc brake conversion[front] Austin Healey 2
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 7
AngliaGT 1997 Miata - Anyone Have a Picture on How to Mount the Front License Plate Bracket? Other Cars 12
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
1 TR2/3/3A Rimmer Brothers Replacement Front Wing Quality? Triumph 8
Carlbanan56 MGB Front hub MG 4
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
scottkilpatrick TR4/4A Front Brakes - Basics for Pads Triumph 11
C MGB-GT MGB-GT Front Ride Height MG 0
C MGB-GT Front Ride Height MG 0
J For Sale Bilstein Front Shocks for Jaguar E-Type 727-498-6493 Jaguar Classifieds 0
J TR2/3/3A Mystery knocking sounds at front wheel Triumph 11
E Wanted 1963 Healey 300 mark 2 front grille wanted Austin Healey Classifieds 0
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
AUSMHLY Front Wheel Spin Drag Austin Healey 6
mctriumph TR2/3/3A Front Suspension upgrades for the 59 Triumph 10
CARSINC For Sale Sprite Front Wire Wheel Hubs Spridgets Classified 0
bighealeysource Front Brake Adjusters Austin Healey 0
L Wanted right front turn signal 1975 TR6 Triumph Classifieds 2
TR3Acustodian TR2/3/3A Replacing "H" front badge Triumph 11
G Rebuilding Front Seats Austin Healey 4
drooartz MGB Front suspension rebuild is next MG 57
Joel Lester TR2/3/3A What final front suspension torque settings needed? Triumph 7
