Front Wheel Spin Drag
AUSMHLY
Hello all. My BJ8 is up on jack stands. I noticed when I spun the front left tire it has more drag than the right tire. I can hear and feel the resistance more.
What is causing that? Is there an adjustment I can make?
roscoe
There is a spacer, referred to as a distance piece, that slides onto the axle stub and contacts the inner races of both the inner and outer wheel bearings. It is fitted with shims of different thicknesses to result in the proper preload on the two bearings. It may be that there are too few shims on one side. That is assuming there is no other issue such as pitted or somehow damaged bearings on that side. The procedure is outlined in the workshop manual but I'm sure if you do a search here you'll find a thread on the process. The distance piece is sometimes not installed, whether out of ignorance or believing it isn't needed. Austensibly it makes the axle stub more resistant to stress but the presence or absence of the parts can't be known unless you disassemble the hub. I drove my late model BN2 without them for a while before I bought the parts and set it up properly.
red57
Do you think the drag is from wheel bearings or brake pads? Jon may be correct with the bearing being improperly preloaded but its' also possible the brake calipers have a little residual pressure and/or something on the pads that is causing slight drag. Try pulling the pads out and spinning the wheels to see if the problem still exists. Yours is a later car with a booster and I don't know if they have a 2psi residual pressure valve or not (it's common on lots of more modern cars) to combat 'pad knock back' to keep the pedal travel short. If your car has one, it may be malfunctioning.
BobHaskell
And how old are the rubber brake lines? They can fail internally. You can force brake fluid through them when you press the brake pedal. But when you release the pedal, the line is too restricted to allow the fluid to return.
AUSMHLY
AUSMHLY
With pads removed, spins freely. I sprayed the disc and pads with brake clean and installed.
New stainless hose. All brakes bleed fine, no air in the lines.
Spin is not equal to the passenger side. It just take a little more effort and wanted to look into it.
Thanks guys for joining in.
Dandare
Sometimes just seal drag can change the feel when moving by hand? Usually though when new ones are installed and in this case having the pads removed seems to negate this.
Danny
John Turney
If there is no difference with the pads removed, it's fine.
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
J TR2/3/3A Mystery knocking sounds at front wheel Triumph 11
CARSINC For Sale Sprite Front Wire Wheel Hubs Spridgets Classified 0
P 100/6 Front Wheel Alignment Austin Healey 10
K TR2/3/3A Front wheel bearing felt seals too large? Triumph 9
Z 3000 Front Wheel Bearings Austin Healey 3
K TR2/3/3A Greasing the Front Wheel Hubs? Triumph 9
B Front Wheel Camber Setting Austin Healey 8
K TR2/3/3A Front wheel bearing adjust and end float?? Triumph 10
A Front wheel bearing issues Austin Healey 11
Rob Glasgow Front Wheel Bearingsknow Austin Healey 4
TRclassic3 TR2/3/3A Front wheel bearing adjustment Triumph 5
J TR2/3/3A Outer Front Wheel Bearing Triumph 22
K TR2/3/3A Front wheel hub "felt" again? Triumph 2
R Front wheel bearing - end float Austin Healey 40
K TR2/3/3A Front hub wheel bearing nut? Triumph 1
KVH General TR Front Wheel Bearing Felt Seal Direction Triumph 9
KVH TR4/4A Front Wire Wheel Hubs Differ from Disc Hubs?? Triumph 5
AHS TR2/3/3A Residual brake pressure valve - how much front wheel drag? Triumph 18
Jim_Gruber New MOSS Tapered Front Wheel Bearings - WTH are the instructions Spridgets 16
G TR4/4A Front Wheel Bearing Seal Triumph 19
N Front wheel bearings?? Spridgets 8
4tecdog BJ8 front wheel alignment Austin Healey 11
Jeepster Front wheel tracking-toe in Austin Healey 21
pan Front wheel bearings [BN1] Austin Healey 6
BN6_2197 Front Wheel Clearing of BN7 Austin Healey 35
M BN1 front wheel bearings Austin Healey 5
certifiedcarnut pipe between front brake wheel cylinders on 948 midget [drum brakes] Spridgets 4
C TR2/3/3A Front wheel bearings Triumph 8
charleyf TR2/3/3A Front wheel bearing--inner tr3 Triumph 4
T TR2/3/3A Front wheel bearings direction and torque Triumph 1
S Problem removing front wheel bearing retaining nut Austin Healey 9
N Spitfire Front wheel bearing seal??? Triumph 11
Jim_Gruber Removing front wheel bearings from hub Spridgets 6
K TR2/3/3A Front wheel bearing grease seal with felt packing? Triumph 4
bthompson Relationship of bachelor lean to front wheel camber? Spridgets 5
7 General TR Chirping front wheel bearing Triumph 6
mgbmedic TR2/3/3A Modern Seal for Front Wheel Bearings TR3 Triumph 8
G MGB Front Wheel Bearings MG 2
D Reinforced Front Wheel Arches Spridgets 35
P Bugeye Front Wheel Bearings? Spridgets 1
Morris Front wheel bearing installation Spridgets 4
Morris Front wheel bearings Spridgets 9
Scotsman TR2/3/3A tr3 front wheel hub stud removal Triumph 2
N Front Wheel Bearings?? Spridgets 4
Rut Front wheel bearings [again] Spridgets 12
hondo402000 TR6 TR6 front end alignment and wheel balancing Triumph 4
TulsaFred Front wheel bearing grease packing Spridgets 26
R 5mm wheel spacers on front when switching Minilite Triumph 2
R TR 3b front wheel bearings Triumph 5
