MGB Front Wheel Bearings
GaryBeu
Banned
Well, I have both my front and rear suspensions done on the MGB...Wheeeew. Now I'm trying to replace the front wheel bearings. I ordered kits from VB. I've never done this before.
My trusty Bentley manual gives me the typical "Withdraw the bearing retaining washer, outer bearing, shims, spacer, inner bearing, oil seal collar, and oil seal. The outer bearing races should be left in the hub unless they are to be renewed." The VB kit contains everything. The bearing retaining washer and outer bearing come out easily. The oil seal collar stayed on the swivel axel. How the **** do I get the oil seal out? AND I assume that I'll leave the outer bearing race in place since I don't have proper equipment to press it out and new one back in. Any problem you see with that? Guess I mostly need instruction on the oil seal. Thanks ya'll...
Gary
PAUL161
Gary, The front hubs on the MGBs have a spacer in between the hub and inter bearing, something American cars never had. Because of this, the nut on the spindle is supposed to be torqued up to the proper setting. Because of this there are shims that go between the spacer and hub. If when torqued up and the hub has resistance when turning, pull the hub and add another shim or pull a thin shim and add a thicker one, they come in various thicknesses. The hub should turn freely but not be loose. They can be a PITA to do, but once done properly, you'll not over stress the bearings. Some guys eliminate the spacers and set everything as an American car is, put the nut on snug and have no problems, but I would do it as the factory did. I forget the torque setting, but that's easy to find. JMHO. PJ
Platinum
That collar is a snug fit. If it has not been grooved, leave it in place. If the thing has a wear groove, a suitable puller will get it off the stub-axle. The stub axle has a radius "shoulder" so pay attention to which side of the replacement collar goes next to it, too.
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
Z 3000 Front Wheel Bearings Austin Healey 3
Jim_Gruber New MOSS Tapered Front Wheel Bearings - WTH are the instructions Spridgets 16
N Front wheel bearings?? Spridgets 8
pan Front wheel bearings [BN1] Austin Healey 6
M BN1 front wheel bearings Austin Healey 5
C TR2/3/3A Front wheel bearings Triumph 8
T TR2/3/3A Front wheel bearings direction and torque Triumph 1
Jim_Gruber Removing front wheel bearings from hub Spridgets 6
mgbmedic TR2/3/3A Modern Seal for Front Wheel Bearings TR3 Triumph 8
P Bugeye Front Wheel Bearings? Spridgets 1
Morris Front wheel bearings Spridgets 9
N Front Wheel Bearings?? Spridgets 4
Rut Front wheel bearings [again] Spridgets 12
R TR 3b front wheel bearings Triumph 5
D Front wheel bearings Austin Healey 48
P front wheel bearings for 79 midget? Spridgets 4
Jer re-packing front wheel bearings Spridgets 3
tomshobby front wheel bearings Spridgets 13
N TR6 How to check TR6 front wheel bearings Triumph 1
58Custom Any tricks to changing front wheel bearings? Spridgets 7
Atrus INeed opinions/experience - front wheel bearings Spridgets 7
I TR6 TR6 - how to pack front wheel bearings? Triumph 8
W Front Wheel Bearings Austin Healey 3
K TR2/3/3A TR3 front wheel bearings [again] Triumph 3
T Front Wheel Bearings Triumph 26
T TR6 tr6 front wheel bearings Triumph 15
MGFever Upgraded Front Wheel bearings Spridgets 8
T "How To" front wheel bearings Triumph 18
prb51 Front wheel bearings Triumph 13
fmichaels front wheel bearings Spridgets 5
healeyneil front wheel bearings Spridgets 5
M TR2/3/3A TR3 Front Hubs/Wheel Bearings Triumph 7
txtr3 TR2/3/3A TR3A front wheel bearings and seals Triumph 4
Simon TR4a Front wheel bearings Triumph 2
S Repacking Front Wheel Bearings Austin Healey 16
77MidgetMkIV Front Wheel Assembly Question [bearings] Spridgets 8
M Front Wheel Bearings Spridgets 7
N Front Wheel Bearings [...Removal Of ] Austin Healey 14
J TR2/3/3A Mystery knocking sounds at front wheel Triumph 11
AUSMHLY Front Wheel Spin Drag Austin Healey 6
CARSINC For Sale Sprite Front Wire Wheel Hubs Spridgets Classified 0
P 100/6 Front Wheel Alignment Austin Healey 10
K TR2/3/3A Front wheel bearing felt seals too large? Triumph 9
K TR2/3/3A Greasing the Front Wheel Hubs? Triumph 9
B Front Wheel Camber Setting Austin Healey 8
K TR2/3/3A Front wheel bearing adjust and end float?? Triumph 10
A Front wheel bearing issues Austin Healey 11
Rob Glasgow Front Wheel Bearingsknow Austin Healey 4
TRclassic3 TR2/3/3A Front wheel bearing adjustment Triumph 5
