Front wheel bearings
Simon TR4a
I have had the car 10 years so decided to change the bearings as preventive maintenance. Is it difficult to change these, or can I do it myself? I have the original shop manual and the chassis is all cleaned up but the body still off, so now is a good time to do it.
Simon.
Rick O.
Simon--The front bearings are a walk in the park. The hardest part is breaking the caliper mounting bolts free. If you use the felt grease seal, be sure to pack it well with grease and compress it down by turning the axle nut until the wheel doesn't move. Then do the Bentley endfloat adjustment.
Don Elliott
I changed mine in Iowa on the way to VTR in Colorado in 2001. I tightened them in to what I thought was the seating shoulder position. But at the pre-inspection before doing the autocross in Breckonridge, the judge told me that my front wheel bearings were loose. I had put on about 1000 miles. Sure enough, I had to really set them into the shoulder. He was right.
Don Elliott
https://mysite.wanadoo-members.co.uk/trebor/don3a_big.JPG
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
Z 3000 Front Wheel Bearings Austin Healey 3
Jim_Gruber New MOSS Tapered Front Wheel Bearings - WTH are the instructions Spridgets 16
N Front wheel bearings?? Spridgets 8
pan Front wheel bearings [BN1] Austin Healey 6
M BN1 front wheel bearings Austin Healey 5
C TR2/3/3A Front wheel bearings Triumph 8
T TR2/3/3A Front wheel bearings direction and torque Triumph 1
Jim_Gruber Removing front wheel bearings from hub Spridgets 6
mgbmedic TR2/3/3A Modern Seal for Front Wheel Bearings TR3 Triumph 8
G MGB Front Wheel Bearings MG 2
P Bugeye Front Wheel Bearings? Spridgets 1
Morris Front wheel bearings Spridgets 9
N Front Wheel Bearings?? Spridgets 4
Rut Front wheel bearings [again] Spridgets 12
R TR 3b front wheel bearings Triumph 5
D Front wheel bearings Austin Healey 48
P front wheel bearings for 79 midget? Spridgets 4
Jer re-packing front wheel bearings Spridgets 3
tomshobby front wheel bearings Spridgets 13
N TR6 How to check TR6 front wheel bearings Triumph 1
58Custom Any tricks to changing front wheel bearings? Spridgets 7
Atrus INeed opinions/experience - front wheel bearings Spridgets 7
I TR6 TR6 - how to pack front wheel bearings? Triumph 8
W Front Wheel Bearings Austin Healey 3
K TR2/3/3A TR3 front wheel bearings [again] Triumph 3
T Front Wheel Bearings Triumph 26
T TR6 tr6 front wheel bearings Triumph 15
MGFever Upgraded Front Wheel bearings Spridgets 8
T "How To" front wheel bearings Triumph 18
prb51 Front wheel bearings Triumph 13
fmichaels front wheel bearings Spridgets 5
healeyneil front wheel bearings Spridgets 5
M TR2/3/3A TR3 Front Hubs/Wheel Bearings Triumph 7
txtr3 TR2/3/3A TR3A front wheel bearings and seals Triumph 4
S Repacking Front Wheel Bearings Austin Healey 16
77MidgetMkIV Front Wheel Assembly Question [bearings] Spridgets 8
M Front Wheel Bearings Spridgets 7
N Front Wheel Bearings [...Removal Of ] Austin Healey 14
J TR2/3/3A Mystery knocking sounds at front wheel Triumph 11
AUSMHLY Front Wheel Spin Drag Austin Healey 6
CARSINC For Sale Sprite Front Wire Wheel Hubs Spridgets Classified 0
P 100/6 Front Wheel Alignment Austin Healey 10
K TR2/3/3A Front wheel bearing felt seals too large? Triumph 9
K TR2/3/3A Greasing the Front Wheel Hubs? Triumph 9
B Front Wheel Camber Setting Austin Healey 8
K TR2/3/3A Front wheel bearing adjust and end float?? Triumph 10
A Front wheel bearing issues Austin Healey 11
Rob Glasgow Front Wheel Bearingsknow Austin Healey 4
TRclassic3 TR2/3/3A Front wheel bearing adjustment Triumph 5
