TR2/3/3A Front disc brake squeal....
TR3driver
Great Pumpkin - R.I.P
Lots of things you can try. The two that have been most effective for me are to file a small bevel on the leading edge of the friction material; or put an aluminum shim between the pad and the piston. I found the aluminum shims in the "Help!" section at FLAPS. Looks like they have been discontinued, but RockAuto says they have one set in stock (and will ship to Canada) :
https://www.rockauto.com/en/parts/dorman,13099,brake+pad+shim+kit,1740
TR3driver
There is a layer of adhesive on the back, to hold them while installing. Once in place, they're held by the caliper piston. Also, you cut them to fit with scissors. The aluminum is thin and soft, so they're easy to cut.
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
K TR2/3/3A Securing new brake disc to the front hub? Triumph 4
I Bug eye front disc brake conversion. Spridgets 5
Ohiobugeye Front brakes won't release after disc brake conversion Spridgets 10
R BJ7 Front Brake disc hitting Austin Healey 12
maxwedge5281 front disc brake hubs for steel wheels Austin Healey 24
Trevor Jessie Front brake line locating brackets [disc]. Spridgets 6
M BN4 prob with disc brake conversion[front] Austin Healey 2
L Denis Welch Front Disc Conversion Kit 100/6 Austin Healey 6
KVH TR4/4A Front Wire Wheel Hubs Differ from Disc Hubs?? Triumph 5
C Wanted 3000 Front Disc Brakes Austin Healey Classifieds 4
croz TR2/3/3A Moss Replacement front disc pads Triumph 3
steveg Front Toyota disc conversion now complete - photo essay Austin Healey 0
C Bugeye Disc Front Brakes FORUM Navigation Questions 0
C Bugeye Disc Front Brakes Spridgets 4
pkmh Dismantling BJ8 Front Hub From Caliper Disc Austin Healey 20
bighealeysource front disc brakes conversion for 100-4 Austin Healey 21
R TR4/4A Disc wheel studs front and rear TR4a irs Triumph 4
B front disc brakes- 66 sprite Spridgets 8
T Check list to convert to front disc brakes Spridgets 9
T Front disc brakes make a big difference? Spridgets 5
O Front disc's from a 63 Midget Spridgets 0
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 7
AngliaGT 1997 Miata - Anyone Have a Picture on How to Mount the Front License Plate Bracket? Other Cars 12
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
1 TR2/3/3A Rimmer Brothers Replacement Front Wing Quality? Triumph 8
Carlbanan56 MGB Front hub MG 4
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
scottkilpatrick TR4/4A Front Brakes - Basics for Pads Triumph 11
C MGB-GT MGB-GT Front Ride Height MG 0
C MGB-GT Front Ride Height MG 0
J For Sale Bilstein Front Shocks for Jaguar E-Type 727-498-6493 Jaguar Classifieds 0
J TR2/3/3A Mystery knocking sounds at front wheel Triumph 11
E Wanted 1963 Healey 300 mark 2 front grille wanted Austin Healey Classifieds 0
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
AUSMHLY Front Wheel Spin Drag Austin Healey 6
mctriumph TR2/3/3A Front Suspension upgrades for the 59 Triumph 10
CARSINC For Sale Sprite Front Wire Wheel Hubs Spridgets Classified 0
bighealeysource Front Brake Adjusters Austin Healey 0
L Wanted right front turn signal 1975 TR6 Triumph Classifieds 2
TR3Acustodian TR2/3/3A Replacing "H" front badge Triumph 11
G Rebuilding Front Seats Austin Healey 4
drooartz MGB Front suspension rebuild is next MG 57
Joel Lester TR2/3/3A What final front suspension torque settings needed? Triumph 7
