BMW 320i front brakes locked up
eejay56
1979 320i. What would cause the front brakes to not be releasing.
Steve
Platinum
Is it both sides, or just the one?
My first thought is that it might well be a flexible barke line that has collapsed internally, not allowing the hydraulic pressure to release.
eejay56
eejay56
Both sides just the front. Flexible brake lines seem OK.
jessebogan
Frozen pistons in the front calipers, Master cylinder pushrod mal-adjusted, master cylinder failure,Heavy corrosion in calipers "holding" the pads against the rotors, rusty rotors. Thats about all that comes to mind.
eejay56
eejay56
Thanks.I going to order a master cylinder rebuild kit and see if that does it.
Bugeye58
EJ, The front hoses may look OK from the outside, but they deteriorate from within. Then they act like check valves. There is enough pressure from the M/C to actuate the brakes, but not enough residual pressure to allow the pistons to retract fully.
Jeff
mikespain
when they are stuck on-try cracking the bleed nipple on the caliper-if the brake releases then the problem is before the caliper,press the brake gain to lock them and crack the union above the brake hose-if it is still stuck on then the problem is the brake hose .don't forget to have something to catch the fluid that comes out.Again if it releases the problem is before that point.then probably the master cylinder .
Eric
I'm not familiar with 320 brakes, but on many modern cars (that I consider the 320 a modern car betrays my age....) with single piston calipers, the slide mechanism needs lubrication, especially if it is somewhat worn and allows the caliper to cock sideways a little.
On my Miata, I need to lube the sliders (esp. the rears) yearly, as a maintainance item, or they'll stick.
J For Sale Land Rover Discovery workshop manual 1995-1999 models, 4.0, 4.6 V8 & BMW diesel Other British Classifieds 0
jfarris BMW M Coupe Spotted 1
Basil More BMW Z4 trials Other Cars 21
Basil Wife's BMW Z4 - pulling my hair out! Other Cars 29
AngliaGT Bmw 700 Spotted 2
3798j John Surtees' BMW 507 up for auction Other Cars 0
69MGC BMW 3.0 Le Mans Race Car Other Cars 0
TomMull V10 in a BMW e30 [325] Other Cars 4
AngliaGT BMW i8 Spotted 0
JPSmit Motorcycle, likely BMW Spotted 2
P Distributor and coil BMW in my Austin Healey BJ8 Austin Healey 10
3798j Elvis' BMW 507 Other Cars 6
glemon New BMW/Mini? Other Cars 1
Moseso TR2/3/3A PeterK, or others -- How did you mount your BMW fan on the TRactor motor? Triumph 3
C BMW or other Modern engine-What would you use? Austin Healey 33
K 1976 BMW 530i Other Cars 3
T Looking for info on BMW K cylinder head conversion British Motor Corp 2
Basil BMW Z8 Enough to make a grown man cry Spotted 3
drooartz My new ride, '06 BMW F650 British Motorbikes 4
Jim_Gruber BMW E30 5 Speed Kit for Spridgets Spridgets 22
6 Eurofest @ the BMW plant in Spartanburg, SC, anyon Triumph 5
drooartz Not exactly British, but my BMW R75/5 is for sale British Motorbikes 11
trrdster2000 English wife wants BMW Triumph 10
tomshobby 1931 BMW IHLE 600 Sports Roadster Other Cars 4
NutmegCT BMW popularity? Other Cars 8
Trevor Jessie BMW M3 Spridgets 14
jackq BMW Other Cars 2
jackq 2000 Deville and 90 BMW 525i Other Cars 5
F Major BMW problems Other Cars 9
B Current BMW restoration Other Cars 6
Johnny BMW and AH similarities Austin Healey 17
T Wedge BMW Recaro seats in a wedge Triumph 22
DanNagy Spitfire Spit with BMW Engine Triumph 8
T BMW 2002 race car Other Cars 20
SilentUnicorn 1934 BMW R7 British Motorbikes 2
glemon TR6 BMW 6 into a TR6 Triumph 5
T BMW K100 DOHC FI head on 1275 block Spridgets 7
T TR6 bmw m powered tr6 Triumph 2
T MGB-GT Clean MGBGT cheap on BMW forum MG 5
vping 1990 BMW 525I - Questions Other Cars 17
weewillie bmw 330i Other Cars 3
Bret Ok this is sweEt BMW 8 Series! Other Cars 15
DrEntropy BMW 318i waterpump R&R? Other Cars 5
Hap Waldrop Euro Auto Festival, Greer, SC BMW plant, Saturday! Austin Healey 6
angelfj1 New Triumph[BMW] Triumph 9
eejay56 weber vacumn line connection for BMW Other Cars 3
T BMW To Resurrect Triumph? Triumph 17
Kirk_Fisher BMW Euro Autofestival 2007 Austin Healey 2
T BMW Z3 Other Cars 4
Hap Waldrop Euro Auto Festival @ BMW Greer, SC October 20 . Spridgets 18
