Front Park Turn Lamps 66 Sprite
MCS
Hello,
My week of vacation is almost over, been busy doing yard mtc. I have made some progress. Fenders on, sway bar installed and many little items found and installed. Just found the front park turn lamps, they are in bad shape. The lens are ok and the chrome ring is ok , the lamp body is rusted. VB and Moss show them as NA. Any ideas as where I can get two new ones or what is a good substitute. Going to try to patch them together for now but hoping someone has a solution.
Thanks Phil
zimasprite
not sure how rusted yours are, but mine were fairly well rusted. I wire-brushed the heck out of them, cleaned them off w/solvent then painted the front with a gun-metal like finish, while covering the bulb area. Don't want to paint the back since you want the ground when you bolt it on. I actually ran individual ground leads to each marker to make sure I have good ground. Don't know if your going for greatness or want a driver, but you can't see what's under the lenses!
best of luck - Drew
middleagecrazy
I was at Pauls week before last and he has NEW front lamps. Base Bezel and Lens. I could have really hurt my budget at his place. He had new chrome for just about every part of a Spridget.Call 270-825-2994 e-mail bmcltd@spis.net for more info, or to order parts .
M
MCS
Thanks I sent him a email, waiting for a reply, where is he located.
Phil
He is in Madisonville, KY
M
MCS
Hi Drew,
I spent a few hours today and did a temporary rebuild. I soldered a ground wire onto the bulb holder case. Going out to the garage to see if they will work. Thanks for your help
Phil
M
MCS
Trevor your fast.
I will give him a call Monday. Off to the garage, now that all the family jobs are done. Monday is my last day of vacation, hoping to get a little more done
Phil
zimmy front park turn lamp lens Spridgets 3
AweMan TR2/3/3A Tr-3 front park light wireing Triumph 13
bcliff MGB MGB Front park/signal light question MG 3
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 7
AngliaGT 1997 Miata - Anyone Have a Picture on How to Mount the Front License Plate Bracket? Other Cars 12
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
1 TR2/3/3A Rimmer Brothers Replacement Front Wing Quality? Triumph 8
Carlbanan56 MGB Front hub MG 4
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
scottkilpatrick TR4/4A Front Brakes - Basics for Pads Triumph 11
C MGB-GT MGB-GT Front Ride Height MG 0
C MGB-GT Front Ride Height MG 0
J For Sale Bilstein Front Shocks for Jaguar E-Type 727-498-6493 Jaguar Classifieds 0
J TR2/3/3A Mystery knocking sounds at front wheel Triumph 11
E Wanted 1963 Healey 300 mark 2 front grille wanted Austin Healey Classifieds 0
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
AUSMHLY Front Wheel Spin Drag Austin Healey 6
mctriumph TR2/3/3A Front Suspension upgrades for the 59 Triumph 10
CARSINC For Sale Sprite Front Wire Wheel Hubs Spridgets Classified 0
bighealeysource Front Brake Adjusters Austin Healey 0
L Wanted right front turn signal 1975 TR6 Triumph Classifieds 2
TR3Acustodian TR2/3/3A Replacing "H" front badge Triumph 11
G Rebuilding Front Seats Austin Healey 4
drooartz MGB Front suspension rebuild is next MG 57
Joel Lester TR2/3/3A What final front suspension torque settings needed? Triumph 7
H TR4/4A Advise asked for front repair Triumph 1
A BN7 Front Hub Stud Nuts Austin Healey 5
P 100/6 Front Wheel Alignment Austin Healey 10
Prof. T Wanted 1974 - TR 6 Front Chrome License Plate Holder Triumph Classifieds 1
S For Sale Triumph TR 2-3 Front Left Fender Triumph Classifieds 2
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
P MGB 1974 MGB front spring length. MG 0
B TR4/4A Spax, Gaz and Koni on Front Triumph 12
G TR2/3/3A TR3A Front Sway Bars - Choice? Triumph 3
K TR2/3/3A TR3 front air vents mounted under the grill...seen on race cars for better air flow to radiator. Triumph 1
G MGB '71 MGB Front End Rebuild MG 2
Popeye TR4/4A Latest thoughts on TR4A front springs? Triumph 8
X Front End Alignment Austin Healey 14
FrogPond "57 100E Front Hubs on E494A Spindles ? Other British Cars 6
A SOLD!! TR3A Girling Type A brake caliper for right front Triumph Classifieds 0
M Front caliper rebuild 1970 Series 2 E-Type Jaguar 0
