1997 Vanden Plas X300 ,Help With Turn Signal Blowing Fuses
JL's 97 Jag
  • Hello fellow jaguar enthusiasts I have a 1997 Vanden Plas that keeps blowing the front passenger side fuse for the right side flasher , the bulb out indicator stays on when the fuse is blown and when I put a new one in the bulb out indicator still comes on when the brake pedal is pressed and the right side flasher is used. No brake lights are blown no flashers are blown but the indicator still comes on and use of the right side flasher blows the fuse in about ten minutes of use. Any and all suggestions would be helpful.
    :concern:
LarryK
Might check right side ground and trace wires thru fender for cuts or cracks. Old enough for wires to chaff. Find a wiring schematic and see where everything comes together.
Deleted member 8987
It has been a LONG time since I dove into one of those.
But:
Isn't the inside of the assembly a circuit board?
If it takes that long to blow the fuse, and you have a dead bulb indication....I'd be looking at the socket and circuit board carefully for corrosion, burn marks, et cetera.
If this was the MG or TRiumph forums, I'd say replace the coil.
AngliaGT 1997 Miata - Anyone Have a Picture on How to Mount the Front License Plate Bracket? Other Cars 12
B For Sale 1997 Bentley Azure convertible, 2,600 orig 1-owner miles!!!! Indiana Other British Classifieds 0
DornTRoriginal Miata 1997 MX-5 Shock Absorber repalcement assistance Other Cars 2
69mgbgt No cabin heat in my 1997 jaguar xj-6 Jaguar 1
D Mass Air Flow Sensor 1997 XJ6L Jaguar 5
TonyPanchot tork settings for 1997 front hub Jaguar 1
TonyPanchot 1997 XJ6 Fuel Filter Location Jaguar 1
T Just bought a 1997 Xj6 L Jaguar 1
PATR8 Opinions on a 1997 Volvo 960? Other Cars 2
S No power to starter [1997 XJ6] Jaguar 4
D 1997 Rover 600 cv boot removal. Rover / Land Rover 0
rick_ingram 1997 MGF seen in Ketucky MG 19
M 1997 XK8 interior Jaguar 2
J 1997 XJ6 engine vibration Jaguar 4
C 1997 xj6 part Jaguar 1
Racer-X- Looking for old parts catalog(ue)s with listings/part numbers for early 1960s Vanden Plas 4 Litre Princess Restoration & Tools 3
G FOR SALE - 2002 XJ8 Vanden Plas Jaguar Classifieds 0
NutmegCT J-P's Vanden Plas? Other British Cars 1
Mickey Richaud Princess Vanden Plas Other British Cars 11
B '95 Jaguar Vanden Plas Jaguar 2
jackq 90 vanden plas Jaguar 0
B 2004 vanden plas Jaguar 1
martx-5 '88 Jag Vanden Plas Jaguar 3
1965_MGB Junkyard Find - Vanden Plas Princess Other British Cars 27
O Vanden Plas Princess Other British Cars 6
B Vanden Plas Jaguar 6
I 1994 vanden plas: brake job questions ?? tips ?? Jaguar 9
ADIPaul Newbie with SII Daimler Double-Six Vanden Plas Jaguar 8
C Free Front&rear bumpers for 89'xj6 Vanden Plaus Jaguar 0
E 1996 vanden plas stereo questions??? Jaguar 1
jackq 89 Vaden Plas Jaguar 2
tony barnhill '85 Vaden Plas Interior Light Jaguar 5
P A pair of Van Den Plas 4 liter cars. Other British Cars 3
MattP Vaden Plas Jaguar 3
