Hello Jag Friends:
I have a'97 XJ6L that my wife loves, but the Jag is having some issues.
My mechanic has boiled down to what he thinks is the Fuel Pump (least likely) or the Mass Air Flow Sensor.
the symptoms: engine sputters and quits, when starting from a stopped position, or when accelerating quickly from a steady speed.
the fuel pump, he has tested as producing the correct flow and psi.
He had earlier repaired the alternator which had several burned out diodes.
Any suggestions?
Any suggestions?
