Wanted ZS 175 CD-2 Air Valve
JonesZ
Air Valve / piston needed for spare carb rebuild. Metering needle, adjusting screw and locking screw would be a bonus.
Thanks for looking.
CJ
C TR6 ZS 175 CD2 stuck air valve/piston Triumph 5
Brooklands Air Filter for Stromberg 175's Triumph 3
Quackedo TR6 1969 TR6 Stromberg 175 CD-6 Triumph 1
P MGB Zenith 175 cd carb damper oil MG 2
H TR6 1974 tr6 stromberg 175 cd-2 choke Triumph 2
Jake For Sale Denis Welch aluminum works shroud scuttle vent scoop - $175 Austin Healey Classifieds 0
Pythias 175/70 13s. Pirelli! Spridgets 7
C TR6 ZS 175 What does this screw do? Triumph 2
B For Sale 175 CD Strombergs Triumph Classifieds 0
SherpaPilot TR6 Stromberg CD 175 Carb Tuning Triumph 8
aeronca65t BSA 175 Bantam British Motorbikes 2
J MGB Are 175 tires the widest that will fit onto a MGB?? MG 3
J TR4/4A 175 CD needle position? Triumph 5
L Stromberg 175 cd question Other British Cars 5
A Zenith 175 CD's Triumph 19
R Zenith Stromberg CD 175 float replacements? Triumph 3
M stromberg 175 cd? Triumph 5
M stromberg 175 choke cable? Triumph 2
M zenith stromberg 175 cd Triumph 24
M zenith stromberg 175 cd. Triumph 7
B where to buy 175/80r15's? Austin Healey 11
T Hap - 175/70/13 or 185/70/13 for your Superlights? Spridgets 26
ncbugeye Problem: Bugeye and 175/70 tyres on SuperLite rims Spridgets 1
mrv8q Couple ZS 175 questions Triumph 9
H Zenith Stromberg CD 175 Too rich Triumph 7
E Stromberg 175 idle Triumph 2
1 175/70/14 tires, yay or nay? MG 15
philman FREE ZS 175 Carburettors [front and rear] Triumph 2
J Zenith Stromburg 175 carburator tune? Other British Cars 3
J TR6 ZS 175 Mod. 3292 rebuild [70TR6] Triumph 2
R Zenith 175 CD Choke Triumph 0
H stromberg 175 carbs Jaguar 1
jerrybny TR6 73 TR6 ZS 175 CD-2 carb question Triumph 6
W What is the proper procedure for priming S.U.175's Triumph 4
Hegg Carburetor Detective Work 175 CD and 175 CD2 Triumph 3
A TR6 Stromberg CD2 Air Cleaner Covers Triumph 2
M TR4/4A Difference between two Oval Air Filters Triumph 3
K TR2/3/3A Foam air filters for S U's Triumph 7
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
WHT DW ITG Air Filter Austin Healey 3
Carlbanan56 MGB Puling air MG 5
HealeyPassion AH Project: Cool Air to Engine Austin Healey 5
Writer2022 GT6 Overheating after fitting air filters Triumph 4
Celtic 77 MGB Tinny Zenith air regulator MG 0
Celtic 77 MGB Seized air pump issue MG 25
Simmo TR6 Weber Carbs and Redline Air Cleaners Triumph 1
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
K TR2/3/3A TR3 front air vents mounted under the grill...seen on race cars for better air flow to radiator. Triumph 1
D BT7 Air Vent Control Cable Routing Austin Healey 0
DrEntropy MGB Air filter MG 16
