TR6 73 TR6 ZS 175 CD-2 carb question
jerrybny
Ok, its been a bad couple of days. I removed the air cleaner with the intention of balancing the carbs. First thing I noticed was the 2 air values were at different heights. The air valve on the front carb was higher than the rear. Is this ok?? Then I proceeded to try and balance the carbs. I followed the steps on the tech page of Buckeye Triumphs. I was unable to get them balanced. I set the Unisyn on the front carb and then tried to get the rear to match the float level. No luck. So then I tried setting the unisyn float on the rear crab and getting the front one to match it. Still no luck. Has anyone else had this problem. Any ideas on what might be wrong or what I might be doing wrong? All help is greatly appreciated. Sure wish I knew a TR6 guru that lived near me. LOL
Oops also does anyone know if this model carb can have the mixture adjusted by using the special tool that Moss sells. All the books I look at seem to say the 73 had a ZS 175 CD-SE unless the 2 means the same as SE(second edition maybe?)
Izual Angel
On the bottom of the carb in the middle of the float bowl you'll find something sticking out. If it's smooth, and brass then you have the adjustable needle. If you have a hex shaped protrusion then you have an adjustable jet. SE should mean something about emission controls.
As for the air valves. Was the engine running when you noticed them sitting at different heights? If not, then you may have gunk built up in the jet (round hole in the bottom of the venturi) or it's hanging up in the bore, or around the dashpot cover.
piman
Hello Jerry,
with the engine switched off, are the pistons free to move, if you lift them do they close off when you release them?. If not they should. With the engine running and if you blip the throttle do both pistons rise, if the rear one does not then the diaphragm is damaged. (Assuming that the first check I mentioned was OK.) Also when you attempted to balance them, is the throttle linkage free, i.e. adjusting one carburettor does not drag the other with it.
Alec /ubbthreads/images/graemlins/thirsty.gif
jerrybny
jerrybny
OK I did some checkout and found the diaphragm had holes in it. Ordered them and will install and see what happens. Thanks guys
V
vagt6
Jerry, the rear carb is the one to which we attach the Unisyn for balancing the carbs. It's the one nearest the firewall.
I found this out the hard way on my first try. The front carb is nearest the radiator, thre rear carb is nearest the firewall.
Easy to confuse without prior knowledge! I hope this helps, but it sounds like you've solved your problem.
Good luck!
Geo Hahn
[ QUOTE ]
Jerry, the rear carb is the one to which we attach the Unisyn for balancing the carbs....
[/ QUOTE ]
Wouldn't you use it on both carbs?
With the linkage between the carbs disconnected you adjust them to match, though some prefer to set the rear carb a bit higher since the torque in the linkage causes the rear carb movement to lag the front carb just a little -- maybe that is what you were saying?
Quackedo TR6 1969 TR6 Stromberg 175 CD-6 Triumph 1
H TR6 1974 tr6 stromberg 175 cd-2 choke Triumph 2
J For Sale Set of Dayton 72 spoke chrome wire wheels for TR6 / TR250 Triumph Classifieds 1
M TR6 TR6- Weber 3236 downdraft conversion Triumph 5
BierRunner TR6 TR6 Trunk Lock Striker Triumph 3
P TR6 Horn issue 1974 TR6 Triumph 5
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
R TR6 TR6 Triumph 6
tr6nitjulius General TR TRIUMPH TR6 the possibilities! Triumph 12
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
A For Sale 1974 TR6 Triumph Classifieds 1
EWD For Sale ‘74 TR6 original wheel trim rings Triumph Classifieds 3
EWD For Sale ‘74 TR6 original radio Triumph Classifieds 0
EWD For Sale ‘74 TR6 original starter Triumph Classifieds 0
EWD For Sale ‘74 TR6 original steering wheel Triumph Classifieds 0
JPSmit TR6 at lunch today Spotted 0
E Wanted looking for a tr6 bell housing Triumph Classifieds 12
jfarris For Sale TR6 Yellow Fan - new Triumph Classifieds 0
