MGB Are 175 tires the widest that will fit onto a MGB??
Mickey Richaud
Jerry -
If your friend's B has stock rims, 175 is the widest safe choice. Anything wider may risk rolling the sidewall while cornering. If he has aftermarket rims, it depends on rim width and offset.
:cheers:
Mickey
J
Jerry
They are stock rims. Thanks for the info. I found a good selection at Walmart, believe it or not. His tires were on the car when he bought it 16 years ago. I told him they were unsafe so he is finally going to replace them. I bet it will even ride better with new tires.
Jerry
drooartz
You do need to be careful with the rears -- that axle is not always really centered, so there may be a bit less room in one side or another. Only really an issue if you're going wider or with non-stock wheels.
I'm running 175/70R14 on Rostyle stock wheels on my GT. Even cheap new tires will ride pretty nicely.
1 175/70/14 tires, yay or nay? MG 15
Quackedo TR6 1969 TR6 Stromberg 175 CD-6 Triumph 1
P MGB Zenith 175 cd carb damper oil MG 2
H TR6 1974 tr6 stromberg 175 cd-2 choke Triumph 2
J Wanted ZS 175 CD-2 Air Valve Triumph Classifieds 0
Jake For Sale Denis Welch aluminum works shroud scuttle vent scoop - $175 Austin Healey Classifieds 0
Pythias 175/70 13s. Pirelli! Spridgets 7
C TR6 ZS 175 What does this screw do? Triumph 2
B For Sale 175 CD Strombergs Triumph Classifieds 0
SherpaPilot TR6 Stromberg CD 175 Carb Tuning Triumph 8
C TR6 ZS 175 CD2 stuck air valve/piston Triumph 5
aeronca65t BSA 175 Bantam British Motorbikes 2
J TR4/4A 175 CD needle position? Triumph 5
L Stromberg 175 cd question Other British Cars 5
A Zenith 175 CD's Triumph 19
R Zenith Stromberg CD 175 float replacements? Triumph 3
M stromberg 175 cd? Triumph 5
M stromberg 175 choke cable? Triumph 2
M zenith stromberg 175 cd Triumph 24
M zenith stromberg 175 cd. Triumph 7
B where to buy 175/80r15's? Austin Healey 11
T Hap - 175/70/13 or 185/70/13 for your Superlights? Spridgets 26
ncbugeye Problem: Bugeye and 175/70 tyres on SuperLite rims Spridgets 1
mrv8q Couple ZS 175 questions Triumph 9
H Zenith Stromberg CD 175 Too rich Triumph 7
Brooklands Air Filter for Stromberg 175's Triumph 3
E Stromberg 175 idle Triumph 2
philman FREE ZS 175 Carburettors [front and rear] Triumph 2
J Zenith Stromburg 175 carburator tune? Other British Cars 3
J TR6 ZS 175 Mod. 3292 rebuild [70TR6] Triumph 2
R Zenith 175 CD Choke Triumph 0
H stromberg 175 carbs Jaguar 1
jerrybny TR6 73 TR6 ZS 175 CD-2 carb question Triumph 6
W What is the proper procedure for priming S.U.175's Triumph 4
Hegg Carburetor Detective Work 175 CD and 175 CD2 Triumph 3
B Wheels and Tires Selection Austin Healey 10
Lutz Kramer Tires Squeaking on Curves Austin Healey 4
Got_All_4 For Sale 2 Vredestein Sprint + S80 Tires 165 R 15 86S Triumph Classifieds 0
red57 Michelin XAS Tires Austin Healey 38
D Vredestein Tires Austin Healey 11
tinman58 TR2/3/3A New Tires Triumph 10
AngliaGT General TR You Might Need Snow Tires for This - Drive Your Triumph Day 2023 Triumph 5
luke44 TR2/3/3A TR3 inside the tires track dimension Triumph 5
drooartz New wheels and tires for Penny Spridgets 16
TR6Canuck TR6 Wire spoke rims to fit Michelin Red Line Tires on TR6 Triumph 12
johnrip Wedge tr7 tires Triumph 1
vette North East Tires Austin Healey 16
F TR6 Wheels and tires Triumph 10
johnrip Wedge Tires for TR7 stock alloy wheels Triumph 1
