Mass Air Flow Sensor 1997 XJ6L
drpulpit
Hello Jag Friends:
I have a'97 XJ6L that my wife loves, but the Jag is having some issues.
My mechanic has boiled down to what he thinks is the Fuel Pump (least likely) or the Mass Air Flow Sensor.
the symptoms: engine sputters and quits, when starting from a stopped position, or when accelerating quickly from a steady speed.
the fuel pump, he has tested as producing the correct flow and psi.
He had earlier repaired the alternator which had several burned out diodes.
Any suggestions?
Most of the issue we had with those cars were related to bad gas, ie. water, destroying the pumps, filters and injectors.
Assuming you have established good spark, clean air filter and good fuel pressure.
drpulpit said:
Hello Jag Friends:
Any suggestions?
I'm with Steve. By '97 they at least got rid of the dual tanks.
There's a "lift pump" in the tank that may be intermittantly working due to age/crud/water, too. Pick one.
I'd be for getting that pump out and replacing it.
Is it setting a "code"/check engine light on? Anyone check the Throttle Position Sensor? Is the fuel filler drain area clear? Take a fuel sample, and let it settle, and inspect for water in the fuel. What do the plugs look like? What kind of plugs? Never use platinum plugs....Have the mechanic connect a fuel pressur guage, and drive the car and observe it when the car stumbles. You can do the same thing with the air mass meter, and a DVOM.
Jim_Gruber Weapons of Mass Destruction Have Been at Work Spridgets 25
A How install a radio with negative mass Austin Healey 3
T TR6 TR6 resto project/parts car in SE Mass Triumph 2
J Day of Triumph Brookline Mass Triumph 7
Rhodyspit75 Autojumble 5/7/11 in Mass. Triumph 2
J Mass DMV Triumph 15
T outrageous Mass sales tax for TR Triumph 11
Dave Richards Does anyone know this car in Mass? MG 2
beaulieu Shipping car from Mass out west ? Restoration & Tools 9
T Anyone know good triumph mechanic in Central Mass Triumph 3
A TR6 Stromberg CD2 Air Cleaner Covers Triumph 3
M TR4/4A Difference between two Oval Air Filters Triumph 3
K TR2/3/3A Foam air filters for S U's Triumph 7
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
WHT DW ITG Air Filter Austin Healey 3
Carlbanan56 MGB Puling air MG 5
HealeyPassion AH Project: Cool Air to Engine Austin Healey 5
Writer2022 GT6 Overheating after fitting air filters Triumph 4
Celtic 77 MGB Tinny Zenith air regulator MG 0
Celtic 77 MGB Seized air pump issue MG 25
Simmo TR6 Weber Carbs and Redline Air Cleaners Triumph 1
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
K TR2/3/3A TR3 front air vents mounted under the grill...seen on race cars for better air flow to radiator. Triumph 1
D BT7 Air Vent Control Cable Routing Austin Healey 0
DrEntropy MGB Air filter MG 16
JPSmit Product Review - air compressor drain valve. Harbor Freight Restoration & Tools 9
F TR4/4A Replacement air filter for SU HS6 Triumph 6
A MGB MGB flap and air box MG 60
R For Sale TR6 AIR CLEANER BOX Triumph Classifieds 1
T Air Filter Recommendations for My Tri-Carb Austin Healey 7
tahoe healey Cooper Air Filters Austin Healey 7
petnatcar Air Scoops Behind the Grille Austin Healey 0
D Wire Wheels and Air Leak Austin Healey 16
rr64 Wanted WTB: Weber 45 DCO 3 Carburetor Air Horns Other British Classifieds 2
PC air back there... Spotted 0
equiprx Air Compressor Moisture mitigation Restoration & Tools 17
S TR2/3/3A restore my original air filters Triumph 5
J Wanted ZS 175 CD-2 Air Valve Triumph Classifieds 0
D Wanted TR6 exhaust manifold w/air rail Triumph Classifieds 2
E MGB Oiling foam air filter MG 3
E MGB SU carb air cleaners MG 10
RAC68 Cold Air Bilge Blower update Austin Healey 13
P TR6 New front shocks & air in clutch Triumph 15
N Air filters Austin Healey 5
M Cooper's Air Filter on H1 Carbs Spridgets 5
TomMull Scroll Air Compressor Restoration & Tools 13
K For Sale TR4A Intake Manifold..Put one on your TR3...improves air intake....cheap like borsht. Triumph Classifieds 2
M TR6 Tr6 fresh air vent replacements Triumph 1
S TR2/3/3A Stock air cleaners and aftermarket air cleaners. Triumph 7
T TR6 Air vent rod connection Triumph 1
