No cabin heat in my 1997 jaguar xj-6
69mgbgt
Hello all,
Looking for some help. I lost cabin heat in my wife's 1997 xj-6 the other day(we are in New England). I was thinking the first(and cheapest) place to start was a thermostat thinkin it may be stuck open. The local dealer also told me I might want to try the electric heater pump and the heater flow control valve. I was looking for your thoughts and also location of the two latter items(electric heater pump and heater flow control vv. Are these big jobs to do or can a weekend mechanic get thru it. Is there also a relay associated with the electric heater pump and the location of it.
Thanks in advance.
Ray
StagByTriumph
Just fixed this on my 96 VDP, yep, check the aux coolant pump. the brushes go bad, or the magnetically coupled impeller gets gunked up. Later is an easy fix as the pump comes apart easily. If it is the brushes, those can be replaced if you have that talent to solder and take care of some cleaning of the stator.
You can get replacement pumps from Rock Auto, guaranteed, for less than $100. Used same price at Matthews Foreign Car Parts in Birmingham Alabama.
Cheers!
healeyboz I must have cabin fever!! Spridgets 0
bcbennett Tiny clutch cabin leak Triumph 6
HealeyPassion Reducing Muffler Heat Austin Healey 2
steveg Heat Shields Austin Healey 17
K TR2/3/3A Can heat from exhaust downpipe ..... Triumph 2
V heat shield Triumph Classifieds 7
EWD TR6 Sound/Heat Mat installation - 74 TR6 Triumph 14
M Heat-related carb issue on BN1 Austin Healey 7
EWD TR6 ā€˜74 TR6 Interior - Padded dash and heat/sound material Triumph 4
AH67 Heat Shield finish 66 Type Jaguar 5
J Bj8 intake manifold to heat shield to carb gaskets Austin Healey 4
BLong63AH Moss Supplemental Heat Shield Austin Healey 2
E BJ8 Seats, Exhaust Hanger, Heat Shield Locations in Floor Austin Healey 7
K TR2/3/3A Revington alternator heat shield. Triumph 0
60TR3A Is It Safe to Heat My Garage All Winter While I Am In Florida? Austin Healey 34
K TR2/3/3A DIY Alternator heat shield>>> Triumph 2
L 100/ Moss Heat Shield Austin Healey 2
wangdango Keeping the heat out? Austin Healey 11
DornTRoriginal TR2/3/3A Heat Shield Issues Triumph 6
T TR4/4A Tips on controlling heat coming up through shifter opening? Triumph 14
GTP1960 TR2/3/3A Carb. Heat shield location? Triumph 11
C Correct color of carb heat shield, starter, and generator? Austin Healey 12
T TR2/3/3A Fuel line heat shield Triumph 39
NutmegCT heat valve control cable Other Cars 0
MikeAH100M FYI - Hardie Board for Heat Shields not Recommended Austin Healey 9
H The heat shield for the Longbridge between the exhaust manifold and carbs Austin Healey 1
I Spitfire If you can't stand the heat.... Triumph 7
J Side exhaust heat shield Austin Healey 23
M Making a manifold/carb heat shield - any suggestions? Spridgets 14
T TR4/4A Heat shield for tranny cover Triumph 4
R Heat Shield Detail Austin Healey 3
KVH TR4/4A Carburetor Heat Shield for HS6 SUs Triumph 4
T General TR heat proofing floor boards Triumph 10
R Heat shields and other hot topics Austin Healey 36
tahoe healey Dynamat heat shield Austin Healey 8
R securing heat shields Austin Healey 11
KVH Carb Heat Shield Installation Triumph 2
D Carb Heat Shield Spridgets 12
HealeyDave Intake manifold heat shield fitting issue Austin Healey 2
NutmegCT heat barrier Restoration & Tools 3
NutmegCT TR2/3/3A TR3 cockpit - summer heat! Triumph 12
M Supercharge Heat Sheild Question [pics] Triumph 3
Russ Austin Heat ah at least warmth. Triumph 11
R TR4/4A Tr4a, alternator heat shield Triumph 9
E Asbestos heat shielding. Austin Healey 8
R Need more heat - which thermostat MG 15
J T-Series electrical heat and smoke from the switch MG 4
G HEAT SHIELD! Austin Healey 10
R No Heat Shield Cause Dieseling? MG 1
I How do I install Bugeye heat shield? Spridgets 4
