FYI - Hardie Board for Heat Shields not Recommended
MikeAH100M
Like many AH'ers, I was searching for ideas to reduce the heat transfer from the engine/exhaust to the passenger compartment. I saw several posts here and on other BCF's proposing the use of Hardie Boards. I contacted the manufacturer, James Hardie, and they strongly recommended NOT using their product for this application because the it has a very high heat transfer rate and offers no insulation value, even with an air space behind it.
RDKeysor
Bronze
It will be back to the drawing board for those of us who recommended Hardie backer. I particularly don't look forward to dropping the muffler again when I find a substitute. Perhaps this explains why I didn't realize any noticeable improvement in my car after installing the full complement of "insulation" pieces.
Lotuswins
Hi Mike,
If you look how the original shields were designed, with standoffs to hold them away from the sheet metal, it is apparent that they were meant to prevent the effects of radiation heat transfer, not conduction (direct contact) nor convection (fluid transfer I.E. air moving around in the engine compartment/muffler area). So, considering that, even if you put a sheet of copper or aluminum in their place, which we know has a much better heat transfer coefficient, it would still block the radiation, and since air is circulating around them, they won't achieve the temperatures that the muffler or exhaust piping attains and therefore won't re-radiate and transfer the heat to the sheet metal of the passenger compartment. So, considering this bit on the configuration, I think even hardie backer does achieve a measure of insulation while still simulating the appearance of the original asbestos pieces.
As an aside, Moss does offer a muffler insulator that appears to be a better alternative to the hardie backer, but a bit pricey.
Keoke
Well I am just curious as to how a product alleged to be made up of cement and sand can have a high thermal conductivity.:feedback:
Generally, materials that are not highly conductive in the electrical sense are also Poor thermal conductors.
MikeAH100M
MikeAH100M
Just passing along what two Tech's at James Hardie said so can't answer the questions. I did let them know about having an air space which diud not change their recommendation.
For between the floor and muffler, I found this ceramic product with aluminum facing and spacers that fit and works well. https://www.tomsimport.com/new/parts/parts.asp?sect=28&new=1
Also found a hear shield kit on AH Spares that I plan to check into. Have been very pleased with their products. https://www.ahspares.co.uk/austin-h...ls-IBP101-to-IBP286A/HEAT-SHIELD-KIT-RHD.aspx
Keoke
OK Michael I understand you;
They probably were just side stepping any potential liability for this application.
steveg
Keoke wrote:
...They probably were just side stepping any potential liability for this application.
That sounds reasonable. It's hard to believe having a sheet of hardiebacker is the same as not having anything there at all.
One would think the air gap would be doing most of the insulation work, anyway. Someone should try applying several layers of reflective mylar on the back side of the hardiebacker plates. How to measure the heat transference with and without the hardiebacker...
Too bad none of us is in high school - this forum would be a good source for ideas for science projects!
HealeyRick
I don't think the use of Hardie Board was ever meant to be anything other than something for the originality folks to use as a similar looking replacement for the original asbestos shields. Just look at the firewall. Above the original asbestos is an uninsulated panel of sheet metal with bunches of holes that just lets heat pour into the cockpit. I'm convinced there are a number of different ways to keep our cars cool using modern materials. It becomes a lot more difficult (perhaps impossible) to do so if you try to keep it concours. If I was trying to keep a stock appearance, I'd use Lizard Skin https://www.lizardskin.com/ throughout the interior and try to put some other insulation between the original asbestos or Hardie Board.
TimK
I still have the original asbestos insulation in place. It is not hazardous unless you break it up. So it is probably worse to remove it than leave it. On the other hand, it doesn't seem to keep my car cool at all. I put some rock wool insulation with an aluminum shield between the muffler and the floor. I also covered the floor with Dynamat Extreme. The transmission tunnel is probably a major source of interior heat as are the holes in the fire wall.
glemon
I did a two phase heat reduction plan on my old 100, not planned but just because phase one didn't work that well, phase 1, was this aluminum foil looking stuff with the bubble layer in between you can use as water heater insulation etc. in the floors and tranny tunnel, it helped, but the cockpit was still hot, phase two was sealing up air leaks, especially around the tranny tunnel both where it meets the floor and where it meets up with the firewall, and also the various holes in the firewalls. After phase two the cockpit was pretty much as cool as whatever the ambient air was, even on a hat day with the motor fully warmed up.
One of the reasons the cars run hot, and probably the reason the factory put the vents in the front fenders of the rally cars, is that the air that comes through the radiator doesn't have an easy exit, so it tries to get out wherever it can including seeping into the cockpit, before I did the sealing up the heat wasn't just radiating into the cockpit, it was blowing in pretty hard (with the car going at highway speeds) through the various leaks, also forgot to mention it likes to come through the shift boot too if that is not all sealed up.
HealeyPassion FYI - AH BJ8 super car for sale Austin Healey 3
DrEntropy E-Type windshield FYI: Jaguar 1
Editor_Reid FYI re "What Did You Do On Your Austin Healey Today?" Austin Healey 0
tr6nitjulius TR5/TR250 FYI: Ford Blue 250/6 Triumph 12
T Clutch Issues continue. FYI Triumph 4
T cast iron welding info and repair-FYI Triumph 1
jaegzie Triumph Bike Owners and others, FYI on Triumph mag British Motorbikes 1
M FYI-How to find out if you MG is pos ground Spridgets 9
T TR6 FYI on TR6s for sale Triumph 2
theleisure FYI, "Bugeye Racer" on Bringatrailer Spridgets 1
steveg FYI--Needle comparison website Austin Healey 4
prb51 TR2/3/3A FYI TR3 Brake Caliper Seals/Pistons Triumph 0
JPSmit FYI - LBC heaven - consolation trip Spridgets 10
soren_ak Dont kno if ya seen this but here is FYI Austin Healey 1
B Moss Orders FYI Spridgets 16
t8nwa Spitfire FYI - Miata seats in a Spitfire 1500 Triumph 5
RickB Bugeye grille on ebay - FYI Spridgets 10
T FYI - Carb cleaner and IBM laptops don't mix Triumph 5
Alan_Myers Wedge FYI '81 Triumph TR-7 Convertible - $875 runs/drive Triumph 5
Alan_Myers Spitfire FYI - "Like new" '73 Spitfire, SF Bay area, $4500 Triumph 10
JPSmit FYI - engine for sale? Rover / Land Rover 1
JPSmit FYI Tiger Sunbeam (Rootes) 8
Z Installing Toe Board Panels Austin Healey 1
B The Prince of Darkness on the dash board finally conquered Austin Healey 10
Joe Schlosser correct Dash board color Austin Healey 6
Marvin Gruber BJ8 dash board Austin Healey 5
TRMark Body Filler Mixing Board on the cheap Restoration & Tools 2
Tinkerman TR2/3/3A 1960 TR3A Tonneau Trim Mill board Triumph 10
JPSmit MG 2015 - anyone going [or coming] repost from MG board Spridgets 1
D Back to the Drawing Board Triumph 21
Superwrench Dash board edging Restoration & Tools 0
G Starting Mega squirt main board assembly Spridgets 16
S bj8 mk 3 phase 2 dash board Austin Healey 2
J BJ8 tonneau cover attachment to heel board. Austin Healey 5
E Clutch issue with 1973 Midget, moved from MG board Spridgets 16
Rhodyspit75 Spitfire Rhodyspit75 on board Triumph 23
tomshobby fiber board panel between boot and interior Spridgets 8
amcboy Limited time offer for board members. Calibration! Triumph 3
J cross post from Triumph board - Painting parts. Restoration & Tools 0
J Hello from the triumph board - Looking at a Jag Jaguar 5
M Dash Board Re-Do Triumph 0
tony barnhill T-Series MG TD Running Board MG 10
U BN6-7 Trunk Board Austin Healey 2
J TR6 tr6 floor board replacement Triumph 14
delisaj TR6 Need help replacing TR-6 dash board knobs Triumph 7
M New here, Is there a MK1 MK2 specific board? Jaguar 2
T Black Tar - Backer board Triumph 7
jlaird Thought this thread from the big Healey board was Spridgets 0
mgbnew Red light on dash board MG 13
M New to board MG 17
