1997 XJ6 Fuel Filter Location
TonyPanchot
Good day all
looking into replacing the fuel filter prior to winter layup
Could someone direct me as to the location of the ff
Thx,
equiprx
I'm pretty sure it's screwed to the under-body, located within the left side framework of the rear sub-frame or just in front, behind the exhaust pipe.
T Just bought a 1997 Xj6 L Jaguar 1
S No power to starter [1997 XJ6] Jaguar 4
J 1997 XJ6 engine vibration Jaguar 4
C 1997 xj6 part Jaguar 1
AngliaGT 1997 Miata - Anyone Have a Picture on How to Mount the Front License Plate Bracket? Other Cars 12
J 1997 Vanden Plas X300 ,Help With Turn Signal Blowing Fuses Jaguar 3
B For Sale 1997 Bentley Azure convertible, 2,600 orig 1-owner miles!!!! Indiana Other British Classifieds 0
DornTRoriginal Miata 1997 MX-5 Shock Absorber repalcement assistance Other Cars 2
69mgbgt No cabin heat in my 1997 jaguar xj-6 Jaguar 1
D Mass Air Flow Sensor 1997 XJ6L Jaguar 5
TonyPanchot tork settings for 1997 front hub Jaguar 1
PATR8 Opinions on a 1997 Volvo 960? Other Cars 2
D 1997 Rover 600 cv boot removal. Rover / Land Rover 0
rick_ingram 1997 MGF seen in Ketucky MG 19
M 1997 XK8 interior Jaguar 2
R For Sale For Sale 1990 Jaguar XJ6 Jaguar Classifieds 0
E 1996 XJ6 Jaguar 1
ROARRR Series 2 XJ6 with cert for chev eng for parts or refurb Jaguar Classifieds 4
W XJ6 Series I bumper swap to Series II Jaguar 0
V 89 XJ6, How to adjust front camber? Jaguar 2
A For Sale 1986 jaguar xj6 Jaguar Classifieds 0
S XJ6 Mk1 clutch slave question Jaguar 0
SherpaPilot Wiring Harness for XJ6 Jaguar 1
T 1971 Series I XJ6 parked for 12 years - fuel pump problem Jaguar 4
C tachometer for XJ6 Jaguar 0
Marvin Gruber XJ6 engine swap into XK 150 Jaguar 4
krswen Looking for advice on XJ6 overdrive unit speedo drive Jaguar 2
krswen Question about XJ6 cam covers Jaguar 6
J Question about Series III XJ6 Motor in E Type? Jaguar 2
smaceng Help with a XJ6 [sort of] Clutch Jaguar 3
D Posi-Rear end in a series 3 Jaguar xj6 Jaguar 12
W Removing wiper arm on 74 XJ6? Jaguar 0
B '72 XJ6 Door Seal Installation Jaguar 2
D XJ6 series III front end rattle Jaguar 5
D XJ6 SIII, idle adjustment Jaguar 7
T 10000k HIDs for 96 XJ6 Jaguar 4
D 85 XJ6 brake fluid reservoir leak Jaguar 4
D 85 XJ6 Heater Core Replacement Advice Wanted Jaguar 19
D XJ6 Seat Removal Q. Jaguar 5
D 85 XJ6 No start, coil problem. Please Help Jaguar 11
K 72 Jaguar XJ6 4.2 litre motor reliability? Jaguar 4
CZ_Dave A Redneck Jaguar XJ6 Spotted 9
CZ_Dave A Redneck Jaguar XJ6 Jaguar 2
C Remove/Install New '93 XJ6 Door Lock Actuator Jaguar 0
C 1999 xk8 steering wheel swap out '93 xj6 Jaguar 3
W Removing windows in 74 Jaguar XJ6 Jaguar 1
R Jaguar XJ6 Door Locks Jaguar 8
B 85 jag XJ6 improve it's performance ? Jaguar 4
eschneider xj6 purge valve / air bleed valve Jaguar 4
dklawson Early '80s XJ6 Speedometer Transducer? Jaguar 0
