Posi-Rear end in a series 3 Jaguar xj6
dvr
Member
What are my options? A rear end from a XJS? Or, is there a unit that will drop in to the stock pumpkin? Not looking to change the gearing per se. Just prefer the feel of the limited slip differential.
Thanks!
LarryK
Any used 6 unit will work, just find a limited-slip out of XJ6-12, gears may change, but compare tags, they have the ratio on them. All mine were limited-slips so they must be in the breakers yards, hopefully not all went for hotrods.
LarryK
Solid axle?? In Jag, never knew!
DNK
Well, wasn't sure since I thought that was the first "Ford" built car
LarryK
Series 3 was still Jag. Ford did not buy until 92. The XJ8 was Ford and the XJ40 was under GM ( who Jag thought was going to buy them) and to me screwed up the XJ from 88-91 that we called them Buicks.
Roger
Bronze
I know Jaguar used GM autoboxes but I dont think there was ever any other connection, was there?
homebeforedark
The V12 E-Types and maybe 420 used GM power steering pumps. Earlier sedans used Ford based (Eaton) pumps. There are some Delco parts on Series II and II XJ6's and Harrison A/C compressors. And DANA (Salisbury) 44 ring and pinion and Spicer u-joints.
LarryK
When I saw solid axle I was thinking solid not typical geared. I was on drag mode when you weld them solid. My 120/140 and MK1 and MK2 would have the persay solid axle. The Chevy influence throughout was emissions, A/C, computers. As nine chip components and limp home, Jag used the Chevy TH400 tranny since 85? ( in V-12). As for the A/C system, I ran in trouble in concours when I used new GM fastners on a XJ12 as in the original Jag sales brochures and original cars. Was finally overrode by 3-2 in final judging and a National win in 1992.
C
Cliford11
_______________
Spare Parts
PAUL161 General MG Posi Locks, Great Connectors MG 2
B Quaife posi for sale Triumph 1
tomshobby posi-drive screws Triumph 10
Howard_The_Duck Posi-Ground BMC radio MG 5
J SOLD!! Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 1
petnatcar Rear View Mirror Relocation Austin Healey 0
Carlbanan56 MGB Rear axel torque? MG 4
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
Carlbanan56 MGB Rear wheelbearing clicking MG 8
Carlbanan56 MGB MGB rear break rebuild MG 6
bigjones TR2/3/3A Rear tail light not budging Triumph 5
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
Michael Oritt Rear Crank Seal Kit Austin Healey 7
BT7 Owner Rear Crankshaft Bearing Cap Austin Healey 4
O Jaguar rear window trim repair Jaguar 1
Joel Lester TR2/3/3A Is "later" style rear view mirror taller than the "early" style? Triumph 6
S Leaking HD6 Rear Carb Austin Healey 10
Joel Lester TR2/3/3A Do rear leaf springs wear out? Triumph 11
J TR2/3/3A Rear Fuel Line Clips Triumph 3
60BN7 Rear Wheel Opening Austin Healey 9
S TR2/3/3A rear wheel cylinder Triumph 1
T Rear/Differential "Clunk" Austin Healey 2
J 3000 Rear Seats Austin Healey 6
KVH General TR Rear Brake Shoe Orientation Triumph 12
Popeye TR4/4A Rear fender attachment: wing to lamp housing clip? Triumph 7
KVH General Tech Rear Brakes and Solid Axle Triumph 2
P Rear Springs Austin Healey 2
K TR2/3/3A Rear leaf spring brass and Delrin bushings ? Triumph 4
J Rear Main Seal Kit Austin Healey 1
af3683 TR2/3/3A TR-2 / TR-3 Rear Bumper Wrap Around Fender Guards Identification Triumph 0
T Looking for "BillMs rear transmission mount" Spridgets 2
BN6_L1232 Rear Disc Brake Installation Instructions Austin Healey 3
Ed Foster T-Series MG-TD leaf rear leaf spring. MG 0
