Posi-Ground BMC radio
Howard_The_Duck
hey guys. went I was going through some stuff last night I found a AM radio with "British Motor Corporation" on it and in permanent marker on the side was written positive ground. the plate and bezeling are in gorgeous condition. and the knobs and push buttons work well as well apparently.
my question is how do I go about testing this thing to see if it works. I am not very good with wiring or electrics and I don't have a posi ground car at my disposal any ideas?
thanks!
jlaird
Hook ground or case to battery positive terminal. Hook power lead to neg side of battery.
Hook up antana and turn on.
A couple of wires with allagator clips works great.
wrenchpuller
Be very careful not to let the radio case touch anything on the car. This is a job that I prefer to do on the bench, with a spare battery and antenna (old coat hanger works in a pinch)
Cheers Ric
trrdster2000
Zack, on a lot of the BMC radios there is a round plug on the side of the radio that allows you to switch it to NEG. ground. If you have this little plug, just unplug it and turn it around and plug back in. Wayne
Platinum
Hey Zack... just box it up and send it on down to me!
BWUUHAAHAAHAAAA!!!! /ubbthreads/images/graemlins/wink.gif
tony barnhill
Great Pumpkin - R.I.P
Zack - I've got a couple of them - hook up a speaker & apply 12V
PAUL161 General MG Posi Locks, Great Connectors MG 2
D Posi-Rear end in a series 3 Jaguar xj6 Jaguar 12
B Quaife posi for sale Triumph 1
tomshobby posi-drive screws Triumph 10
M MGB Ground polarity '67 MGB MG 2
B Positive-Ground LED Light Strip Austin Healey 8
V MGB Never occurred to me that my '66 would be positive ground. Does the presence of an alternator show that it's been converted? MG 22
A Muffler/Ground Clearance Austin Healey 13
K TR2/3/3A The engine ground strap? Triumph 6
jfarris TR2/3/3A Ground location for center panel lights 56 TR3 Triumph 5
R Ground wires under dash Spridgets 5
T TR2/3/3A Should there be a body ground strap to battery on TR3 Triumph 7
Jim_Stevens TR2/3/3A Arcing & Sparking at the battery terminal to ground Triumph 7
steveg 100-4 Distributor Internal Ground Wire Austin Healey 6
B TR4/4A Engine ground strap Triumph 5
R TR2/3/3A Pic of installation of ground strap-TR-2 Triumph 2
T Location of ground wire for BJ8 Austin Healey 6
K Is my BJ8 horn switch connected to ground positively or negatively? Austin Healey 3
red57 Positive ground radio Austin Healey 17
S Wanted Original Style Positive Ground Radio Austin Healey Classifieds 0
S Positive Ground to Negative Ground Power Inverter Austin Healey 11
S TR2/3/3A TR3 with Ground Conversion Triumph 18
apbos Positive Ground Alternator wiring. Spridgets 9
6 Relay wiring positive ground Spridgets 4
M BJ8 Positive-Negative Ground Conversion Austin Healey 7
M 66 ‘ BJ 8 Positive ground identification Austin Healey 4
doc50 Nash Metro Positive to Negative Ground Other British Cars 2
R TR2/3/3A Positive-ground LED lights Triumph 13
D TR2/3/3A Main ground connection Triumph 2
G TR4/4A Negative Ground Conversion Question Triumph 11
S TR4/4A Where do the ground straps connect Triumph 5
Joe Schlosser BN1 Ground cable Austin Healey 3
S TR4/4A Horn ground strap Triumph 6
S TR2/3/3A Positive Ground Question Triumph 2
Marla TR4/4A Positive ground inverter Triumph 9
M TR2/3/3A Positive or negative ground? Triumph 6
P Bugeye Negative Ground Spridgets 15
S MGA 1956 MGA negative ground, True Spark Ignition distributor MG 3
P Jump starting a positive ground BJ8 Austin Healey 4
D TR4/4A Ground strap, ammeter Triumph 3
Jim_Gruber Am I set up as Positive or Negative Ground? Spridgets 12
M TR2/3/3A Engine/tranny angle with the ground? Triumph 7
K TR2/3/3A Fuel gauge and switching to Neg ground? Triumph 2
PAUL161 General MG LED Dash and Instrument Bulbs POS or NEG ground. MG 8
Jim_Stevens TR2/3/3A Where's the horn ground? Triumph 15
M Negative ground conversion : what about OD ? Austin Healey 9
M Question about positive vs negative ground Spridgets 13
J General TR Pos/Neg ground determination? Triumph 14
R Distributor ground wire Austin Healey 8
R TR2/3/3A Distributor ground wire Triumph 7
