I have a new ground wire from Moss. It is a bare copper stranded wire with terminal ends at both ends.
The distributor, for whatever reason, is from a early 1960 Sprite (40919), not a TR3
The old ground wire is somewhat permanently attached, with the metal terminal end under the end of the pin in the contact breaker plate. The end of the pin has been spread out in a cross hatch pattern to secure the pin to the plate. It is not a rivit, but a 3/8-inch long pin with a groove near the end for the base contact breaker plate to ride in.
The question is how does one remove the old ground wire without damaging the pin?
Perhaps cutting the old wire off, leaving the terminal end under the pin, and then sodering the new wire to the old wire terminal end is the only solution. Or buy a new plate, if available.
