Pertronix distributor install into Austin Healey 100/6
TonyCap
Hi All,
Today we installed a Pertronix distributor into an Austin Healey 100/6.
The original distributor in this car is a Lucas DM6A and as you can see from the attached picture the vacuum canister is on the left hand side of the distributor.
When we installed the Pertronix the vacuum canister ended up on the right hand side of the distributor (see attached picture) and touches the steering column when you set the timing and also the oil dipstick cannot be accessed because of this.
Has anyone else installed a Pertronix D177600 Flame-Thrower distributor into a 100/6 and had the similar issues? I was thinking of just removing the vacuum canister as I do not use it.
With the new Pertronix distributor installed the car starts and runs really nicely and the only problem is the location of the vacuum advance canister.
Any advice would be greatly appreciated.
steveg
Could you drive the pin out of the tach gear and rotate it 180 degrees?
Edit: Your picture 2 shows the distributor to already be 180 degrees out. The #1 terminal on the cap should be approximately at the 2 o'clock position, not the 8 o'clock position.
From the Bentley manual -
With #1 piston TDC on compression stroke:
Keoke
U Can also put the pertronix components into the original dizzy ?
The dizzy drive shown @ 20-to-2 is correct
T
TonyCap
Thanks for the information.
In order to get the engine to TDC on #1 of the firing stroke do I need to turn over the engine until the tachometer spindle is in the same position (twenty to two) as the diagram 8.5?
At the moment I have spark plug number 1 removed and a whistle screwed into the spark plug hole so when there is a compression stroke you get the whistling sound. But the issue is that there is a compression stroke on every revolution so I am not sure when it's the firing stroke.
The other thing with the Pertronix distributor is that I was required to install the original tachometer drive gear off the DM6A to the Pertronix distributor. What I did was knock out the pin from the Pertronix distributor and using the original holes on the DM6A drive gear I drilled a hole 90 degrees from the original hole on the distributor shaft and put the DM6A drive gear on the distributor shaft. By doing this I have effectively changed the original position of the drive gear on the distributor by 90 degrees so I am not sure whether this will cause any problems?
The reason I could not use the same hole on the distributor shaft is that that hole was a larger diameter than the hole of the drive gear and if I made the hole on the drive gear larger it would reduce the strength of the connection because there was not much metal from the edge of the drive gear to the pin hole.
View attachment 64468 View attachment 64469
Keoke
Well:
Maybe when the distributor drive as shown in pic # 1 is at its 20 to 2 position as it is in the PIC # 1 and your whistle is going that is the correct firing stroke ???
Kind ah tricky to do----
steveg
Tony - Compression stroke is every other revolution. Intake-compression-ignition-exhaust is how the four strokes go.
On the exhaust stroke, the exhaust valve is open so your whistle won't work.
With the engine at TDC on the compression stroke, you should be able to drive out your roll pin and rotate the tach drive gear 180 degrees to move your vacuum unit opposite the steering column.
From memory: the lower distributor drive gear can be withdrawn with a magnet* and inserted by trial and error until it's where you want it. From your description above it sounds like you want it at the 11-and-5 position.
*Edit: Lin Rose reminded me the manual says use a 5/16-24 x 3-1/2" bolt - works better than a magnet.
Lin
Correct me if I am wrong, but on the compression stroke both valves are closed meaning there will be clearance between both of the valves and their rockers. Of course, you would need to have the rocker cover off to see this.
Lin
steveg
Lin
Lin - Tony's using a whistle; I've got a balloon on a spark plug base - with those one doesn't need the rocker cover off.
T
TonyCap
I decided to remove and refit the drive gear to the Pertronix distributor in the same position as the original distributor. (See the attached pictures)
Now the only thing I need to do is get the engine setup in the correct firing position.
I took a video of the valves so you can take a look and let me know what you mean in your previous post.
https://youtu.be/YFWuICb67y8
Jack T
Sorry I'm late to the dance, but when I had an issue with the vacuum unit, I rotated the plug wires in the cap so I could turn the distributor body.
steveg
Tony,
Take the plugs out and push the car in gear or rotate the engine with an adjustable spanner on the big generator nut until, with your whistle and the crank pulley notch, you achieve TDC on the compression stroke.
At that point, with the engine off, you can wiggle the two rockers on the #1 cylinder and they'll both be loose because both valves will be seated.
Keoke
Yeah that will work:
A bit tricky too just be sure U have remembered the firing order to locate the remaining plug wires--LOL
P Pertronix distributor on an early BJ7 Austin Healey 8
A Spitfire 45DE4 Distributor Pertronix Installation Triumph 2
B Pertronix Distributor Wiring? Austin Healey 3
Scotsman Pertronix Flame Thrower Electronic Distributor Triumph 7
E pertronix distributor MG 1
G Pertronix Flame Thrower Distributor Spridgets 9
bluemiata90 Wedge Pertronix distributor for TR8...will it work Triumph 3
M Pertronix Flame Thrower Electronic Distributor Que Spridgets 14
S BJ7 and Pertronix distributor Austin Healey 10
wangdango '67 XKE Mallory dulal point to Pertronix Jaguar 0
T Pertronix Ignitor: reliability & suitability Austin Healey 10
T Pertronix Ignitor: reliability & suitability Spridgets 19
T Pertronix Ignitor - old potential reliability issue is still there Austin Healey 12
T Pertronix Ignitor - old potential reliability issue is still there Spridgets 0
B TR6 Pertronix ignition Triumph 11
Lutz Kramer Ignition timing with Pertronix Ignitor and strobe light Austin Healey 67
R It wasn't the Pertronix Austin Healey 25
R Suspected Pertronix failure Austin Healey 32
max71 MGB Anyone have experience with the Pertronix Ignitor III? MG 11
Marvin Gruber TR5/TR250 Pertronix vs Crane electronic ign Triumph 1
KVH TR4/4A Report on Pertronix Triumph 6
richie TR4/4A Missing since rebuild with Pertronix Triumph 9
dklawson General MG Which Pertronix? 45D with Red Points. MG 4
3798j TR4/4A Pertronix III 25d Install Triumph 1
S Points versus Pertronix Spridgets 22
H TR4/4A Pertronix Ignition Triumph 4
S TR2/3/3A Timing with Pertronix Triumph 12
AUSMHLY Pertronix or points Austin Healey 49
B BN2 Pertronix Question Austin Healey 2
rjc157 Pertronix dist Austin Healey 2
mgbmedic car keeps running after pertronix install MG 11
DRKizer Pertronix Flame-Thrower "HP" dizzy for Brit cars Racing 6
B Ignition wires to use with Pertronix distibutor Austin Healey 9
regularman Pertronix Spridgets 28
mountainman pertronix electronic ignition hepl please Triumph 10
T How do you set the timing on a Pertronix distribu Triumph 13
M TR2/3/3A Pertronix coil for TR3 Triumph 7
britndablood Anyone need a pertronix backup pickup for $40 Austin Healey 1
6 Timing Bugeye with Pertronix Spridgets 2
D Spitfire spitfire pertronix installation question Triumph 25
Go_Dogs_Go Convert Pertronix Pos Ground to Neg Ground? Spridgets 10
Michael Oritt Pertronix Ignitor failure mode Austin Healey 8
drooartz Pertronix back to points MG 28
Jim_Newman Pertronix + MSD ignition problem Austin Healey 6
memphis Pertronix & Mallory Dual Point [Positive] Austin Healey 11
T How bench test Pertronix unit Triumph 3
MTribe need help - pertronix trouble at low idle speeds? Triumph 19
F Pertronix Ignition Austin Healey 9
bighealeysource Pertronix coil verus standard Lucas coil Austin Healey 3
D pertronix for mallory dual point Triumph 5
