Pertronix dist
rjc157
i just got a new pertronix flame thrower dist for my neg ground bj8 has anyone done this conversion ,which way does the vacume advance face
Keoke
Same way as the original. Angled towards the back of the engine
AUSMHLY
My car is negative ground and I've installed a nav/mp3 player which gets it's power from the car.
Is it ok to have the key on, car not running, so as to power the unit. Sometimes I'll set up the nav or listen to music without the car running.
Not concerned with draining the battery, more concerned about the Petronix unit. Will it do it any harm to the Petronix?
B Pertronix and Dist Rebuild - Car not starting Austin Healey 63
T Pertronix distributor install into Austin Healey 100/6 Austin Healey 12
wangdango '67 XKE Mallory dulal point to Pertronix Jaguar 0
T Pertronix Ignitor: reliability & suitability Austin Healey 10
T Pertronix Ignitor: reliability & suitability Spridgets 19
T Pertronix Ignitor - old potential reliability issue is still there Austin Healey 12
T Pertronix Ignitor - old potential reliability issue is still there Spridgets 0
B TR6 Pertronix ignition Triumph 11
Lutz Kramer Ignition timing with Pertronix Ignitor and strobe light Austin Healey 67
P Pertronix distributor on an early BJ7 Austin Healey 8
R It wasn't the Pertronix Austin Healey 25
R Suspected Pertronix failure Austin Healey 32
max71 MGB Anyone have experience with the Pertronix Ignitor III? MG 11
Marvin Gruber TR5/TR250 Pertronix vs Crane electronic ign Triumph 1
KVH TR4/4A Report on Pertronix Triumph 6
richie TR4/4A Missing since rebuild with Pertronix Triumph 9
dklawson General MG Which Pertronix? 45D with Red Points. MG 4
3798j TR4/4A Pertronix III 25d Install Triumph 1
S Points versus Pertronix Spridgets 22
A Spitfire 45DE4 Distributor Pertronix Installation Triumph 2
H TR4/4A Pertronix Ignition Triumph 4
S TR2/3/3A Timing with Pertronix Triumph 12
AUSMHLY Pertronix or points Austin Healey 49
B BN2 Pertronix Question Austin Healey 2
B Pertronix Distributor Wiring? Austin Healey 3
mgbmedic car keeps running after pertronix install MG 11
Scotsman Pertronix Flame Thrower Electronic Distributor Triumph 7
DRKizer Pertronix Flame-Thrower "HP" dizzy for Brit cars Racing 6
B Ignition wires to use with Pertronix distibutor Austin Healey 9
regularman Pertronix Spridgets 28
mountainman pertronix electronic ignition hepl please Triumph 10
T How do you set the timing on a Pertronix distribu Triumph 13
M TR2/3/3A Pertronix coil for TR3 Triumph 7
britndablood Anyone need a pertronix backup pickup for $40 Austin Healey 1
6 Timing Bugeye with Pertronix Spridgets 2
D Spitfire spitfire pertronix installation question Triumph 25
Go_Dogs_Go Convert Pertronix Pos Ground to Neg Ground? Spridgets 10
Michael Oritt Pertronix Ignitor failure mode Austin Healey 8
drooartz Pertronix back to points MG 28
Jim_Newman Pertronix + MSD ignition problem Austin Healey 6
memphis Pertronix & Mallory Dual Point [Positive] Austin Healey 11
T How bench test Pertronix unit Triumph 3
MTribe need help - pertronix trouble at low idle speeds? Triumph 19
F Pertronix Ignition Austin Healey 9
bighealeysource Pertronix coil verus standard Lucas coil Austin Healey 3
E pertronix distributor MG 1
D pertronix for mallory dual point Triumph 5
G Pertronix Flame Thrower Distributor Spridgets 9
KVH TR4/4A Tubular Headers/Pertronix for TR4 Triumph 12
mountainman Pro & Con's of Pertronix vs Points Triumph 43
