Positive-Ground LED Light Strip
Blake62spite
Basic question. New to the AH world.
I ordered positive-ground LED bulbs for dash, so I think I’m good there. My question is, can I wire regular LED light strip (12vdc) to the battery and not worry about the positive or negative ground on the car since it will not be using the car's ground system? It will be standalone off the battery not making contact with the grounding. Hope this is making sense. This should be cut and dry, but so far nothing has been so on this car!
Legal Bill
Where did you get the positive ground LED strip? I would use positive ground as I would wire the lights to come on with the operation of the light switch, no a separate circuit.
B
Blake62spite
The light strip is negative ground.
but if I am putting it on it’s on switch for interior lights and it would never touch the positive ground system. Would it still work ?
BigGreen
I am with Bob, it will work.
When connecting both leads directly to the battery, no ground is used (pos or neg)
Legal Bill
So you didn’t buy a positive ground LED light strip? Did you see them for sale somewhere?
B
Blake62spite
I will give it a try this weekend. I have searched everywhere for a positive-ground LED light strip or one that is reversible. No luck. I’ll update the post with results soon. I’ll also add before and after photos of my Sprite rebuild. So proud of the results so far!
BigGreen
The extra attention to positive and negative connections especially applies when replacing a lamp in the existing wiring.
In existing wiring, a light bulb can receive current from both sides.
An additionally connected LED strip, with its own (new) connection, only requires connection to a source that sends a current in one / correct direction.
Wiring a LED-strip from the battery should therefore be simple and pose no problems.
R TR2/3/3A Positive-ground LED lights Triumph 13
T TR2/3/3A LED tail lights for TR3A and positive vs. negative ground Triumph 11
M LED lamps for Austin Healey with positive ground Austin Healey 0
V MGB Never occurred to me that my '66 would be positive ground. Does the presence of an alternator show that it's been converted? MG 22
red57 Positive ground radio Austin Healey 17
S Wanted Original Style Positive Ground Radio Austin Healey Classifieds 0
S Positive Ground to Negative Ground Power Inverter Austin Healey 11
apbos Positive Ground Alternator wiring. Spridgets 9
6 Relay wiring positive ground Spridgets 4
M BJ8 Positive-Negative Ground Conversion Austin Healey 7
M 66 ‘ BJ 8 Positive ground identification Austin Healey 4
doc50 Nash Metro Positive to Negative Ground Other British Cars 2
S TR2/3/3A Positive Ground Question Triumph 2
Marla TR4/4A Positive ground inverter Triumph 9
M TR2/3/3A Positive or negative ground? Triumph 6
P Jump starting a positive ground BJ8 Austin Healey 4
Jim_Gruber Am I set up as Positive or Negative Ground? Spridgets 12
M Question about positive vs negative ground Spridgets 13
K TR2/3/3A Converting to Positive Ground....... Triumph 1
M_Pied_Lourd TR2/3/3A Identifying positive or negative ground.... Triumph 14
B Smiths RVI Positive Ground Tachometer Bench Test ? Austin Healey 24
drambuie Converting a smiths clock to positive ground Austin Healey 12
Lukens What's the down side of "positive ground system"? Triumph 8
P How to use timing light with positive ground? Austin Healey 14
R 66 midget tach positive ground Spridgets 2
Mowgli81 Positive Ground Disconnect in Trunk Austin Healey 4
E Positive ground or Negative ground. What have you? Austin Healey 12
C Positive Ground History with Triumph Motorcycles British Motorbikes 1
Geo Hahn Brakelight Flasher for Positive Ground Triumph 2
cbrvfr Running modern accessories with positive ground? Austin Healey 4
S positive and negative ground Triumph 7
BOBBYR Positive ground dwell Austin Healey 23
T Why positive ground? Austin Healey 17
S Size 34 Optima Battery w/positive ground Austin Healey 33
M Jump start positive ground car Austin Healey 10
I Bugeye-better to have negative or positive ground? Spridgets 17
JohnnyMead Relays for Positive Ground Triumph 6
D Positive or Neg ground, should I switch? Austin Healey 51
newmexTR3 positive/negative ground coil question Triumph 14
TR4 Pertronix - Positive Ground Triumph 4
livinginthepast Positive ground tach/dwell meter hook up Spridgets 1
Newkie Converting Positive ground to Negative ground MG 4
19_again flamethrower coil on positive ground B MG 4
Magyar How to convert from positive to negative ground? Spridgets 10
Sarastro An option for a radio in a positive-ground car Spridgets 6
66healey Positive to negative ground conversion Austin Healey 2
jvandyke positive to negative ground conversion Spridgets 11
J Positive Ground Radio- Other British Cars 1
athenssprite positive to negative ground Spridgets 4
F Pertronix Positive Ground Question Austin Healey 9
