TR4/4A Where do the ground straps connect
shoopal
TR4A
I guess the cable ground from the battery goes to the chassis somewhere. Then there must be a strap that joins the engine block to the chassis.
Can someone enlighten me.
I think I can figure out the grounds on the harness, behind the dashboard and in the trunk (boot).
Thanks in advance
Al Shoop
Geo Hahn
There is a wide braided cable from the battery to the firewall. The body-to-engine ground goes (as I recall) from the left hand motor mount to one of the bolts holding the timing cover.
There is also small braided ground connection from the steering rack to the rack mount to allow the horn to function. Also similar ground wires that 'jumper' around each rubber flex connection on the steering column.
I have photos - which would be very helpful - but they are on Photobucket who now charges something like $400 for you to look at them.
S
shoopal
Thanks George
I got the horn grounds on already but I was concerned that the starter current would ground up some wire that was not designed to handle it. I remember when I stripped the car down that there was a ground cable going to chassis but someone could have changed it. What I was most concerned was the engine to chassis ground strap. I don't recollect anything bolted to the timing cover but that would make sense. That is from lower part of motor mount to timing chain cover.
A picture is worth a thousand words but not $400
ghawk16
Soooo, here is a pic of mine and this is where mine was. However, mine was grounded to a hole JUST behind the engine mount hole. Soooo, essentially the same part of the frame. But the other end was one bolt down from where the engine hoist bracket is. See pic..
ghawk16
Yeah, sorry about that. Was more showing where it attaches to the engine. The other end goes in the motor mount on the frame or in my case there was another hole right near there and I figured that was for the ground so I just used that.
Jim_Stevens TR2/3/3A Where's the horn ground? Triumph 15
doughairfield Where to put the ground. Triumph 6
K TR2/3/3A TR3A: Petronix Pos ground...which wire goes where? Triumph 6
Luke_Healey Where do the headlamps ground at? Spridgets 4
B MGA Where to Buy, What to Buy? Axle Nut MG 9
Scotsman TR4/4A Chimney nuts, where do they go Triumph 5
jehuie Where to post for parts that fit many cars? FORUM Navigation Questions 1
Pythias Where to post FOR SALE Spridgets 1
A Where to get key blanks for SD1 in the U.S.? Rover / Land Rover 5
F Off Topic Personal update/ Where is Frank? Triumph 4
Basil Where's Walter? Spotted 8
Q TR2/3/3A Where to start?! Triumph 13
jlaird MGB Up date. Where to begin? MG 7
B Windshield glass, where to buy Restoration & Tools 4
steveg TR6 '74 - Where is the Starter Relay located? Triumph 1
C MGA Where to tap into 12v for a power outlet MG 2
S TR2/3/3A I have this miss where the car will start and kinda idle Triumph 23
C Anyone know where to get one of these? Austin Healey 6
P Area where pillar, shroud, and drainage channel meet. Austin Healey 3
P Drainage Channel Where It Meets The Shroud Austin Healey 6
M TR4/4A Where to buy a new crown wheel & pinion for TR4A Triumph 5
PAUL161 T-Series Where My TF Came From MG 1
FlyingCat Spitfire What hoses go where... Triumph 6
A Phase 1, Phase 2, Where's Phase 3 Austin Healey 14
Got_All_4 General TR Someone asked where to get DOT5 silicon brake fluid a while back Triumph 4
Got_All_4 TR6 triumph tr6 wrist pins where to get them Triumph 5
T TR2/3/3A Where is best spot to check temp with infrared thermometer? Triumph 17
Got_All_4 General TR Anyone know where to get one of these? Triumph 5
R J-H Stromberg carb connections? Where do they go? Other British Cars 2
Paulus General TR Where to get HVDA parts and vibration when engaging clutch. Triumph 13
B TR2/3/3A Where on the clutch pedal? Triumph 4
N Spitfire Just picked up this 73 Spitfire. Hasn't run in ten years. Where do I begin? Triumph 10
P T-Series Where's my last TD? MG 2
R engine removal- where to connect hoist? Austin Healey 16
C Where and how to "disconnect" my two SU's? Austin Healey 3
55modified TR2/3/3A warning indicator bulbs need replacing where and what to buy? Triumph 4
Jim_Gruber Hubs a Rocking on side where Speedi Sleeve was installed Spridgets 5
warwick-steve Where did the smell go? Austin Healey 11
Gliderman8 TR6 Convertible cover snaps... where to install? Triumph 2
M TR4/4A Where to buy this aluminium extrusion? Triumph 7
C Gauge faces - where to get Austin Healey 9
G Where can I get bottle jack seals? Restoration & Tools 2
R TR4/4A Where can I get Triumph Midnight Blue carpet? Triumph 0
Got_All_4 TR2/3/3A Where to place the switch for the windshield washer & bottle Triumph 8
C Where to wire a Pusher fan - BN1 Austin Healey 16
Rob Glasgow Brackets, where do they go? Austin Healey 3
Got_All_4 TR2/3/3A Where can i get these door handle parts Triumph 1
M BT7 restoration, Where to start and sill reinforcement Austin Healey 3
M TR2/3/3A Two black wires on control box E where do they g0 after alternator conversion? Triumph 9
