Drainage Channel Where It Meets The Shroud
PeterB
I am getting towards the end of a very long restoration. So long I think it may need another before it hits the road. I purchased a new drainage channel because mine was cut into pieces and installed incorrectly years ago by an autobody shop. My question is should the drainage channel come all the way to the end of the shroud so the chrome finisher has another point to attach to or should it really be like in my picture.
RAC68
Hi Peter,
Simple answer, yes the channel goes to the end of the shroud...at least that is how it is on my Healey with the original shroud and channel. Keep in mind that the top has a flap extending down into the channel when errected to drain water into the channel.
All the best,
Ray(64BJ8P1)
healeyblue
It doesn't go to the end on my unrestored BJ7. Here are some reference pics.
Healey Nut
Two BJ8s and they both finish with the drain channel slightly short of the end just like the pics .
RAC68
Hi All,
Since the channel has flat ends and the inner rear panel securing strip extends from very close to the door opening (thickness of panel) on an angle, I guess there would be a small space to allow these to reside next to each other.
Keep in mind that the drain channel is ridged one piece item and, when positioned, must be close to the drain tubes in each rear corner. These relatively fixed connections will only allow small positional movement and, as a result, the channel's ends will be set by where they fall.
All the best,
Ray(64BJ8P1)
RestoreThemAll
My BJ7. Installed in original holes
P Area where pillar, shroud, and drainage channel meet. Austin Healey 3
B BJ7 / BJ8 drainage channel Austin Healey 13
AUSMHLY Drainage channel Austin Healey 5
Simon TR4a Drainage hoses, best route. Triumph 1
bmurphy7369 Body drainage rituals? Save the Jags Campaign.... Jaguar 3
J SOLD!! Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 1
Popeye TR4/4A Door seal channel near top of windscreen Triumph 6
algot1901 Window Channel Ford Prefect Other British Cars 5
chicken Holes for Drain Channel Pipe Austin Healey 4
Tr3aguy TR2/3/3A Started a Car revival channel for the TR3 Triumph 12
HealeyRick New Healey YouTube Channel Spridgets 2
HealeyRick New Healey YouTube Channel Austin Healey 0
D 1965 Sunbeam Tiger featured on my YouTube channel Sunbeam (Rootes) 0
T BJ8 Drain Channel Removal Austin Healey 2
B Rain channel colour Austin Healey 5
G BJ7 Window channel position Austin Healey 1
maxwedge5281 side curtain felt placement in channel Austin Healey 4
P Is there a seal between the drain channel and drain box? Austin Healey 8
Zitch TR4/4A Door Weather Strip Channel - Was this added? Triumph 4
Scotsman TR4/4A Need FELT for window channel Triumph 8
KVH General Tech Help With Rusted Weather Strip Channel Triumph 1
B BJ7 Drain Channel and Small Waist Trim piece question Austin Healey 13
Joe Reed General MG Cars that Rock on Velocity Channel - tonight [8/20/16] MG 2
Elva164 A new Cortina video AND a new Youtube channel! Racing 1
Healey Nut Another drain channel question . Austin Healey 21
Lutz Kramer Drain channel and trim rail Austin Healey 4
chicken Hood drain channel Austin Healey 18
A TR4/4A Velocity Channel Fantomworks TR4A Triumph 12
M TR4/4A Door glass bayley channel clearance measurement. Triumph 4
S TR2/3/3A Cool YouTube channel - Cheftush Triumph 7
K TR6 TR6 Restoration on Velocity Channel Triumph 6
HealeyDave Healey on Velocity Channel tv show - USA Austin Healey 6
60TR3A "Car Crazy" on Speed Channel: "Healey Week" Austin Healey 6
Patrick67BJ8 Top/Hood/Drain Channel Gray color needed Austin Healey 2
Rut Bonnet 'channel' Spridgets 20
K drain channel paint Austin Healey 9
P FROGEYE on the Velocity Channel Spridgets 4
fogliner Moss Motors YouTube Channel MG 3
Randy Forbes BJ8 top drain channel questions... Austin Healey 10
C Racing Sprite in SC on Food Channel Spridgets 5
L On History Channel Tonight--"Pawn Stars" Austin Healey 5
V Speed Channel Jaguar 1
L Seal-Top to water channel Austin Healey 7
dougie Discorvery Channel HD - GT Racer Season 2 Racing 5
T Door glass, bottom channel Spridgets 4
zimmy midgets racing on SPEED channel Spridgets 3
Jim_Gruber Removing Aluminum Channel on top of door - Trick? Spridgets 5
J Bugeye on Discovery Channel Spridgets 14
R BJ7 rear drain channel- Seal or not? Austin Healey 6
Randy Harris Ran across cool car-guy show on DIY channel Austin Healey 5
