Spitfire Just picked up this 73 Spitfire. Hasn't run in ten years. Where do I begin?
Mickey Richaud
Welcome! Looks like a great find - Spitfire's are nimble, robust little guys. Should provide lots of enjoyment (and challenge....)
For starters, take a look at this great checklist and how-to from one of our own on this forum, Tony Barnhill. Though specific to MGB, it's applicable to virtually all older cars that have been sleeping a while: https://tidentenn.com/pdf/AWAKENING A SLEEPING MGB CHECKLIST.pdf
:cheers:
Mickey
Mickey Richaud
You're welcome, and keep us posted.
N
NNY73Spitfire
Will do. I'm looking at sourcing most parts online. Roadster Factory, Moss, and Victoria British seem to be the most popular. Would you lean towards one business? Quality/price fair at most? Following the guide you provided, I need to replace hoses - 5/16" hose at Napa should work for fuel right? Can I get away with a Napa radiator hose? Do you recommend a specific antifreeze for the 1500? It gets -40 here in the winter. Would it be worth it (at my amateur level) to get electronic ignition instead of points? What about spark plugs? Is synthetic oil acceptable for these old cars?
Mickey Richaud
As for parts from "The Big Three" you mentioned, you'll no doubt get several answers and everyone has favorites. In my opinion, they all need to be supported in order to keep them supplying our much-needed goodies. NAPA hoses, as long as they fit, should be fine; same with belts. Name-brand antifreeze (Prestone, etc.) is fine for our cars. As for ignition, I prefer points - again, you'll get differing opinions. Spark plugs? I like NGKs - probably BP6ES (or BPR6ES). And my choice for oil is either Castrol or Valvoline VR 20/50.
Andrew Mace
So many questions; all good ones! Vendors first.
The Roadster Factory is arguably the best of the three you name, with prices usually competitive enough. Moss is the newest player in the Spitfire game and, IMO, is still feeling its way around. Victoria British is, in some ways, the JC Whitney or Western Auto of parts for British cars. Lots of good stuff, lots of less-than-good stuff, tech support well towards the lower end compared to other vendors. Two others very worthy of note and business are Spitbits and TS Imported Automotive, both for price, availability of parts AND technical advice.
NAPA or other generic hoses are ok-ish for radiators (although it's really best to have a hose with the built-in flexibility for the top rad. hose). Fuel hose from them is just fine; so is heater hose IF you can fit same without kinking the hose (some hoses are best replaced with correct molded-to-shape hoses).
"Classic" old-time antifreeze is just fine; nothing special needed. I tend to prefer quality conventional oils simply because leaks tend to make the cost of synthetics even higher. If you've got a well broken-in, leak-free engine, synthetics can be just fine.
I'm a points-and-condensor fan, too. Best argument I can make for a Pertronix or similar electronic ignition update is that it's tough to find especially points for Delco distributors that are worth the packaging they come in, let alone functional and durable in their own right.
I'm a Champion plug fan since...forever, although I also like AC plugs in these. Honestly, I think choice of BRAND of plug is more closely related to your own loyalty or whatever your dad / uncle / favorite corner mechanic swore by than it is to any scientifically proven reality! ;)
3798j
Bronze
Agree with Mickey on the need to support all of our suppliers. Here are three more good parts suppliers (particularly for your Spitfire)...Sports Car Parts Ltd (https://www.sportscarpartsltd.com), Spitbits (https://spitbits.com), and Canley Classics (https://www.canleyclassics.com/triumph-spitfire/). I'm a fan of both electronic ignition (although many here feel otherwise) and synthetic motor oil...some (like Mobil 1's 15w-50) even come with the needed zddp zinc additive. If you really get -40 degree temps, you won't want to be in your Spit.
N
NNY73Spitfire
Andy - thanks for all the information. I see you're located near Albany. I'm up in St. Lawrence County. Would you recommend a club in the area? The Adirondack Chapter seems a bit biased towards the capital region and the next closest is Ottawa, Ontario.
Andrew Mace
Honestly, you might be better off with the Ontario group! Nothing against Adirondack Triumph Association per se, but it is rather more centered around Albany and the Capital District, and it is much less a: active generally and b: Triumph-centric than it was when it started 40 years ago.
WayneB
I'm in the same situation as you are, I bought a 1976 Spitfire 1500 about a month ago. A friend put me onto British Parts Northwest, in the state of Oregon. Found the prices good. I live in Wisconsin and the parts were delivered within days. I have been watching forums for other places to check for parts..
Rut TR4/4A Just picked up my frame Triumph 14
Rut Picked up an enclosed trailer today Spridgets 3
A Picked up this '77 today Spridgets 7
5 Picked Up the Wreath Spridgets 10
Banjo Just picked up a brake lathe Restoration & Tools 1
M_and_P Picked up my Bonnet Spridgets 4
T picked up a spider to part out Triumph 4
J TR4/4A 67 TR4A IRS picked up today! Triumph 23
H Look what I picked up for the Healey today. Austin Healey 13
A MGA hey guys picked up a 60 mga on craigslist MG 20
1 Picked up the car today MG 19
T TR2/3/3A Tush - TR3a louvres or not? Color picked out yet? Triumph 15
C picked up the 62 midget today SALE wire wheel conv Spridgets 0
jaegzie Picked up my first British bike 07 Daytona 675 British Motorbikes 4
B MGB-GT 67 BGT picked up today. MG 1
jlaird Picked up Miss Agatha Spridgets 20
RickB Just picked up some parts... Spridgets 6
hilsideser need something picked up in Virginia Triumph 5
AngliaGT Picked Up Some Older R&T's Triumph 13
losmorob Picked up the motor today MG 5
B Picked up some vintage plates, now... Spridgets 18
PATR8 UGGGG!!!! I saw an 8 same color green I picked Triumph 7
jlaird Picked up trailer yesterday Spridgets 12
B Just Picked Up Spridgets 10
B TR6 Picked up my TR6 Triumph 12
jackq Picked up my XJ6 today...FINALLY Jaguar 10
macino62 Picked up another motor....... Triumph 5
kennypinkerton Just picked up the LTD... Other Cars 24
jackq MGB Picked up the MGB MG 7
B Picked up my BJ8 today - First ever time to drive! Austin Healey 15
G Picked up my new [200] Landcruiser yesterday. Other Cars 3
philman Wedge picked up my "new" 76 tr7 fhc Triumph 6
J Picked up my Midget, question for aeronca65t Spridgets 16
L Spitfire New Acquisition, 1976 Spitfire Triumph 5
motzart007 Wanted In search of used seats for 1969 Triumph Spitfire MKIII Triumph Classifieds 1
B For Sale GT6/Spitfire License Plate Light Assembly Triumph Classifieds 0
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
A Spitfire Spitfire Diff Pinion Seal? Triumph 2
3798j General TR Spitfire up in the Tree Triumph 2
E Spitfire '69 Spitfire hard top Triumph 2
D For Sale 1966 Spitfire 4 MK 2 for sale, Triumph Classifieds 1
R For Sale Spitfire MKIII projects Triumph Classifieds 0
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
G Spitfire Spitfire 1500 differential whining Triumph 6
T Spitfire Spitfire MK2 Clutch Hydraulics Triumph 2
A Spitfire Spitfire Fuel pump issues Triumph 5
P Spitfire 1979 Triumph Spitfire starts then runs rough Triumph 2
Lairhead52 Wanted 78 Spitfire instrument panel lights / lenses Triumph Classifieds 3
D Spitfire 1980 California Spitfire, Help Figuring What To Do With It? Triumph 15
