Where's Walter?
Administrator
Boss
Walter White that is. This is the RV that Walter White (Brian Cranston) drove in Breaking Bad. That's the car was (Called A1A in the show) that was featured in Breaking Bad. This is actually where I get my car washed regularly.
waltesefalcon
I thought this was about me at first.
This sighting would have only been better if it had been spotted at the car wash WW owned in Breaking Bad.
AngliaGT
I see a line of people in the first picture.
Were they giving out free samples?
Administrator
Boss
That is the same car wash that is in the show…they just changed the name for the show, but this is the physical location.
waltesefalcon
I didn't look closely enough before. That's pretty cool.
JPSmit
Car Wash. One of my favorite B pictures. Irwin Corey as the Pop Bottle Bomber.
+1 guilty pleasure (OTOH I have never seen breaking bad) :rolleyes2:
equiprx
Breaking bad was something I binged on last year.
Until then I had never seen an episode.
Freaked me out.
B MGA Where to Buy, What to Buy? Axle Nut MG 9
Scotsman TR4/4A Chimney nuts, where do they go Triumph 5
jehuie Where to post for parts that fit many cars? FORUM Navigation Questions 1
Pythias Where to post FOR SALE Spridgets 1
A Where to get key blanks for SD1 in the U.S.? Rover / Land Rover 5
F Off Topic Personal update/ Where is Frank? Triumph 4
Q TR2/3/3A Where to start?! Triumph 13
jlaird MGB Up date. Where to begin? MG 7
B Windshield glass, where to buy Restoration & Tools 4
steveg TR6 '74 - Where is the Starter Relay located? Triumph 1
C MGA Where to tap into 12v for a power outlet MG 2
S TR2/3/3A I have this miss where the car will start and kinda idle Triumph 23
C Anyone know where to get one of these? Austin Healey 6
P Area where pillar, shroud, and drainage channel meet. Austin Healey 3
P Drainage Channel Where It Meets The Shroud Austin Healey 6
M TR4/4A Where to buy a new crown wheel & pinion for TR4A Triumph 5
PAUL161 T-Series Where My TF Came From MG 1
FlyingCat Spitfire What hoses go where... Triumph 6
A Phase 1, Phase 2, Where's Phase 3 Austin Healey 14
Got_All_4 General TR Someone asked where to get DOT5 silicon brake fluid a while back Triumph 4
Got_All_4 TR6 triumph tr6 wrist pins where to get them Triumph 5
T TR2/3/3A Where is best spot to check temp with infrared thermometer? Triumph 17
Got_All_4 General TR Anyone know where to get one of these? Triumph 5
R J-H Stromberg carb connections? Where do they go? Other British Cars 2
Paulus General TR Where to get HVDA parts and vibration when engaging clutch. Triumph 13
B TR2/3/3A Where on the clutch pedal? Triumph 4
N Spitfire Just picked up this 73 Spitfire. Hasn't run in ten years. Where do I begin? Triumph 10
P T-Series Where's my last TD? MG 2
R engine removal- where to connect hoist? Austin Healey 16
C Where and how to "disconnect" my two SU's? Austin Healey 3
55modified TR2/3/3A warning indicator bulbs need replacing where and what to buy? Triumph 4
S TR4/4A Where do the ground straps connect Triumph 5
Jim_Gruber Hubs a Rocking on side where Speedi Sleeve was installed Spridgets 5
warwick-steve Where did the smell go? Austin Healey 11
Gliderman8 TR6 Convertible cover snaps... where to install? Triumph 2
M TR4/4A Where to buy this aluminium extrusion? Triumph 7
C Gauge faces - where to get Austin Healey 9
G Where can I get bottle jack seals? Restoration & Tools 2
R TR4/4A Where can I get Triumph Midnight Blue carpet? Triumph 0
Got_All_4 TR2/3/3A Where to place the switch for the windshield washer & bottle Triumph 8
C Where to wire a Pusher fan - BN1 Austin Healey 16
Rob Glasgow Brackets, where do they go? Austin Healey 3
Got_All_4 TR2/3/3A Where can i get these door handle parts Triumph 1
M BT7 restoration, Where to start and sill reinforcement Austin Healey 3
M TR2/3/3A Two black wires on control box E where do they g0 after alternator conversion? Triumph 9
M TR2/3/3A Where can I get British Racing Green, 1958 Triumph tr3a touch up paint in the USA? Triumph 3
M TR2/3/3A Where does this screw go? Triumph 6
vette Any Suggestions As to Where to Buy a New BJ7 Gasoline Tank? Austin Healey 24
M TR2/3/3A Where have you guys put your stereos and speakers? Triumph 3
